This is a discussion thread titled "Just ordered a Rough Country 2.5" lift kit....any input on this??", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-02-2006, 07:00 PM
MD8181's Photo Albums
Last Online: 05-09-2007 06:25 PM
MD8181 is on a distinguished road.
Default Just ordered a Rough Country 2.5" lift kit....any input on this??
I just ordered this kit today for $250 shipped from Suspension Lift Kits, Body Lifts, Leveling Kit, 4x4, Jeep, Chevy, Dodge, Ford, Off-road Truck
roughcountry.com
It comes with rear shocks...Are these shocks good or just same as stock??
I have looked on this forum and didn't find any info on this kit.
ANyone know anything about this kit?? GOOD, BAD????
CHEAP MADE or anything??????
Looks pretty good and easy to intall.
THe only thing I am worried about is that the front spacers are the poly rather than aluminum...is that ok?? Will they compress and lower the truck down?? Also I am worried about these shocks since I don't know what kind they are.
Any input would be great!!!!
Thanks
Mark
Old 08-03-2006, 03:08 AM
xxSIKO's Avatar
Dealer : Sierra Toyota
2000 Toyota Tacoma
xxSIKO's Photo Albums
Last Online: 07-24-2007 02:12 AM
xxSIKO is on a distinguished road.
Send a message via AIM to xxSIKO
Default Re: Just ordered a Rough Country 2.5" lift kit....any input on this??
I had this kit for about a year before I went long travel. Held up to my jumping and abuse. Yes it did settle a little.
The rear shocks are okay, seemed to me that it was the same ride as when it wasn't lifted. All in all was great and cheap for me while I was saving up for something better.
If your truck is 4x4 I suggest getting a drop down spacer from TOTAL CHAOS. I broke CVs for a months before getting it and never replaced a CV once drop down was installed. Well worth the $20.
If you have any questions, I will try my best to help out.
Old 08-03-2006, 08:58 PM
Thanks a lot!!!
I don't plan on doing any off roading or jumping so I should be good.
I noticed that you have a tacoma, I have a tundra, did you use this kit on the tundra or on your tacoma????
If tundra what size tires were you able to use??? I am using stock rims..
ALso was it a pretty simple install???????????
Thanks
Mark
Old 08-03-2006, 09:41 PM
4cloud9's Avatar
Dealer : Poway Toyota
2003 Toyota Tundra
4cloud9's Photo Albums
Last Online: 11-20-2008 12:34 AM
4cloud9 is on a distinguished road.
Originally Posted by MD8181
.... was it a pretty simple install???????????
Thanks
Mark
You are going to need coil compressors to get the spacer into the coil pack and also to change out the bolts on the top plate. It would be helpful if you have someone give you a hand.
My 03 Tundra v6 AC SR5 mods: URD lightened crankshaft pulley(soon) | Xtreme Alloy 1079 | 285/75-16 BFG's | Spintech ProStreet dumped | Total Chaos str/rck bushings | Camburg UCAs | TRD 4X4 v8 coil | Daystar 2.5" spacers | TRD yellow-blue shocks | 5100's | No-Slip Locker w/Mobile1 synthetic dif. oil | B&M transmission cooler | 911 performance brake pads | Hellwig swaybar(need quick disconnects) | Front seat covers | 35% Tint 2 front windows | Drop-in bed liner | clear-red-clear tail lights | Clear corners | AMI 21" polished antenna | Challenger steps | Toyota skid plate | Demello bed bar w/ cheapo fogs re-wired and running 100w H3's | Color matched mirror covers | Debadged | PermaShield teflon
Old 08-04-2006, 03:55 AM
xxSIKO's Avatar
2000 Toyota Tacoma
I just rented the coil compressor from Auto Zone. I forget how much it was though, maybe $20? Then when I brought it back I was refunded my money. Took me 4 hours, was my 1st time installing a lift.
Similar Threads for: Just ordered a Rough Country 2.5" lift kit....any input on this??
Lift Kit for Tundra Reggie Ours 1Gen-Tundra 4 07-25-2006 06:03 PM
Lift kit choice for 2001 2wd access cab SmokeySevin 1Gen-Tundra 6 07-13-2006 02:20 PM
Lift kit question MATRDguy 1Gen-Tundra 1 01-05-2006 05:44 PM
2005 Lift Kit Advice jholman Suspension & Axle 2 01-27-2005 08:23 PM
Tough Country 4x4 lift Plus Coilovers? trooper04 Suspension & Axle 10 09-03-2003 11:02 PM
