This is a discussion thread titled "Stock 4wd TRD ride height?", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-05-2006, 04:29 PM
mtcheral's Avatar
Dealer : Price Leblanc Toyota
2005 Toyota Tundra,
2007 Toyota Sequoia
mtcheral's Photo Albums
Last Online: 11-19-2008 01:33 PM
mtcheral is on a distinguished road.
Default Stock 4wd TRD ride height?
Hello all. I am looking for someone with a stock suspension 4wd TRD like mine to see what the ride height is. I am measuring from the ground, through the center of the wheels, to the bottom of the TRD fender flares. I currently have the cornfed system on and am at 27.5" in front and 28" in the rear. It is the 2.5" in front and 1" AAL in rear. I want to see how much things have settled in a year and a half. Thanks in advance.
___________________________________________
2005 4wd TRD Doublecab- Silver Sky Metallic
2.0" SAW coilovers at 3" with rear 1" AAL, 285/75/16 BFG AT's on MT Classic II's, Pioneer Premier HU with XM, Rhinoliner, UWS aluminum truck box, Husky liners
Old 08-05-2006, 06:39 PM
4cloud9's Avatar
Dealer : Poway Toyota
2003 Toyota Tundra
4cloud9's Photo Albums
Last Online: 11-20-2008 12:34 AM
4cloud9 is on a distinguished road.
Default Re: Stock 4wd TRD ride height?
You should measure from the center of wheel to the bottom of flares. Cause then someone with stock tires can give you a measurement you can use. Taller tires raises the bottom of the flare off of the ground. But if you measure from the center of wheel that should give you the overall difference without the tire hieght variable.
My 03 Tundra v6 AC SR5 mods: URD lightened crankshaft pulley(soon) | Xtreme Alloy 1079 | 285/75-16 BFG's | Spintech ProStreet dumped | Total Chaos str/rck bushings | Camburg UCAs | TRD 4X4 v8 coil | Daystar 2.5" spacers | TRD yellow-blue shocks | 5100's | No-Slip Locker w/Mobile1 synthetic dif. oil | B&M transmission cooler | 911 performance brake pads | Hellwig swaybar(need quick disconnects) | Front seat covers | 35% Tint 2 front windows | Drop-in bed liner | clear-red-clear tail lights | Clear corners | AMI 21" polished antenna | Challenger steps | Toyota skid plate | Demello bed bar w/ cheapo fogs re-wired and running 100w H3's | Color matched mirror covers | Debadged | PermaShield teflon
Old 08-05-2006, 11:39 PM
mtcheral's Avatar
2005 Toyota Tundra,
2007 Toyota Sequoia
Good idea- actually I think that's what i did a long time ago when i put everything on but it has been a while- Thanks. I'll do it again and post mine tomorrow to compare. Thanks
Similar Threads for: Stock 4wd TRD ride height?
What is the biggest tires I can fit under a stock height 4 X 4 TRD Tundra ?? ZIGGY454 Tires and Wheels 9 08-16-2006 09:25 PM
K&n Gen Ii Intake Kit nhparrot Engine & Drivetrain 2 07-06-2006 11:19 PM
TRD Package RIDE ROUGHER THAN NON TRD ? toyotaboy 1Gen-Tundra 13 05-28-2006 08:51 PM
Ride Height Change 16" vs. 17" rims squalor 1Gen-Tundra 4 09-09-2005 03:37 AM
Ride height? chase_5 Tires and Wheels 1 04-19-2005 11:42 AM
