This is a discussion thread titled "camburgs, errrrr!", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-09-2006, 06:22 PM
Dealer : Arlington Toyota Scion
2006 Toyota Tacoma
Kelly Repper's Photo Albums
Last Online: 02-27-2008 10:17 AM
Kelly Repper is on a distinguished road.
Default camburgs, errrrr!
got an 06 tacoma, put on the camburg coilovers and for the last two weeks i have been adjusting, adjusting, and adjusting, i just cant seem to find a height, about stock height there awesome, and when i go up there is a knocking, yes there is nitro in em, anyone have them on a tacoma, and about how may inches are you showing on the coilover with out haveing that anoying knocking and what height did it give you, i did have some measurements but there all shot cause i have don it so many times.
Help
Old 08-10-2006, 05:41 PM
cleanb13's Avatar
Dealer : Boch Toyota South
cleanb13's Photo Albums
Last Online: 11-20-2008 09:34 PM
cleanb13 is on a distinguished road.
Default Re: camburgs, errrrr!
Did you call the place where you bought them and ask what the problem might be? I have them on my truck and they don't make any noise. Did you put the aluminum spacer bushings on the shocks at the bottom? I know on the Tundra, the bigger spacer is supposed to be installed towards the rear of the truck. Is everything tight?
2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 Revos on Wheeler's black alloys, True Flow intake tube and filter with a modded air box, JBA titanium coated headers, Aero 2525 muffler with stainless steel pipes and resonator removed, Skidrow front skidplate, EBC "green" brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Wheeler's polyurathane front swaybar bushing kit,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Silverstar fog light bulbs, , Viair 300P air compressor
Wish list: Line X'd front and rear bumper, rock sliders
Old 08-10-2006, 09:12 PM
2006 Toyota Tacoma
yeah its all tight, i have gone threw and threw, i called scott and asked him over at camburg, he was suppose to call me back, i guess i should give him another call, i know your a tundra but how much thread are you showing on your shocks?
Old 08-11-2006, 02:53 PM
cleanb13's Avatar
To compensate for the gas tank being on the drivers side, I have 2 3/4" on the drivers side and 2 1/2 on the passengers side.
Old 08-11-2006, 03:02 PM
OnePremiere's Avatar
2007 Toyota Tacoma DC Sport 4WD
OnePremiere's Photo Albums
Last Online: 09-05-2008 03:45 AM
OnePremiere is on a distinguished road.
Help
How long have you had the coilovers installed? You could have recieved a bad batch of springs. The knocking you are hearing could be coil bind, coil bind will cause the spring to disfigure, a rough ride, and constant adjustment to keep thhe height you are happy with.
I have have the Camburg C/O's on my Tundra and I was showing 3.5" of thread on the coilover and I was barely clearing my 285's, after the new spring I set it at 2.5" and haven't touched it since. Rides great and the ride height hasn't moved.
Call up Scott at Camburg. He will take care of you. And if you did get a bad set of springs, they will be replaced free of charge.
In this picture you can see how much the spring had compressed and was becoming disfigured.
Here is my small write up of my coil spring replacement....
SoCalTundras - SAW Spring Replacement
http://www.cardomain.com/ride/2467017
2007 Tacoma DC TRD Sport 4WD "Batman"
Similar Threads for: camburgs, errrrr!
c clips for camburgs algunn45 Suspension & Axle 9 03-03-2005 10:52 PM
