This is a discussion thread titled "2.5" of lift and 33's", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-09-2006, 07:40 PM
bingbling's Avatar
Dealer : Longo Toyota
2005 Toyota Sequoia
bingbling's Photo Albums
Last Online: 03-09-2007 01:03 AM
bingbling is on a distinguished road.
Default 2.5" of lift and 33's
Hey All,
I know a lot of you are running 285/70/17 or 305 on 16's with 2.5" of lift c/o's or spacers on your tundras. Are any of you experiencing rubbing issues at the rear of the front wheel wells? Any good remedies for this besides hacking or body lifting? Any help would be greatly appreciated.
BTW Devin67, I recieved your suggestion, thanks, I was just wondering if anyone else has any input.
Thanks all
Old 08-09-2006, 08:00 PM
mtcheral's Avatar
Dealer : Price Leblanc Toyota
2005 Toyota Tundra,
2007 Toyota Sequoia
mtcheral's Photo Albums
Last Online: 11-19-2008 01:33 PM
mtcheral is on a distinguished road.
Default Re: 2.5" of lift and 33's
I have 285's and based on how they fit in my wheel well, sounds like an alignment to push them back should clear that up- I had to take off splashguards though
___________________________________________
2005 4wd TRD Doublecab- Silver Sky Metallic
2.0" SAW coilovers at 3" with rear 1" AAL, 285/75/16 BFG AT's on MT Classic II's, Pioneer Premier HU with XM, Rhinoliner, UWS aluminum truck box, Husky liners
Old 08-09-2006, 08:06 PM
Dealer : Modesto Toyota World
2006 Toyota 4Runner
calitundra's Photo Albums
Last Online: 11-20-2008 02:54 AM
calitundra is on a distinguished road.
I am running 285/65/18's which are the same as 285/70/17's. I use to run 285/70/17 with a bridgestone duelers without problems. I went to a bfg AT and noticed the lugs stuck out further and would rub on the inside framerail at full turn with a 3 5/8 backspace I believe. I changed to a 4 5/8 inch backspace and made it worse!!!! It was tearing up my fenders. I bought a used set which with custom spacing off a tundra member and they are awesome. I don't remeber the offset though. Also if you have a 4x4 2 inches is about the most you want to go with spacers before you start destroying your cv boots. There are some fixes out there such as replacing the bands with clamps.
Old 08-09-2006, 10:21 PM
bingbling's Avatar
2005 Toyota Sequoia
Hey mtcheral,
Thanks for the reply. To clarify, I am getting rub at the rear of the wheel well. Does that mean I should get an alignment to push them forward instead of backwards as you mentioned? Also, I was under the assumption that alignments only fine tune your angles but are not capable of actually shifting your wheels' position forwards or backwards from where they sit in your wheel well. Thanks in advance for any replies.
Old 08-10-2006, 05:21 PM
mtcheral's Avatar
2005 Toyota Tundra,
2007 Toyota Sequoia
I'm not an expert on it but I was there when the mechanic did my alignment after the lift and I'm almost positive he adjusted mine at least a little forward/back. But if you are having your rubbing at the rear, that's normal with a turn. Mine was only rubbing on the splashguards so i just took them off- now none whatsoever
Similar Threads for: 2.5" of lift and 33's
Need Help with lift option? TundraGuy00 Suspension & Axle 0 04-18-2006 06:57 PM
Will 33's fit with a 3" lift? mauibound Tacoma 6 08-19-2005 12:02 PM
Looking to lift my DC 05 Tundra cheaply to fit 33s. therevelation320 Suspension & Axle 9 07-18-2005 10:26 PM
4" or 6" total lift / 33's or 35's triggs75 Suspension & Axle 11 09-17-2004 10:11 AM
PING!! anyone who uses, or has used a Tuff Country Lift RodeThunder Tires and Wheels 8 03-12-2003 10:07 PM
