This is a discussion thread titled "Help installing LSD", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-21-2006, 12:23 AM
Dealer : Fremont Toyota
2002 Toyota Tundra
Triple BB's Photo Albums
Last Online: Yesterday 11:35 PM
Triple BB is on a distinguished road.
Default Help installing LSD
I'm installing a limited slip diff on the rear axle of my Tundra. Pulled the third member out and took it to a drivetrain shop so they could do the technical stuff. I have a Haynes repair manual, but it has nothing relating to the differential. Was wondering if anyone knows the torque specs on the third member nuts and is there a pattern tightening sequence? My truck only has 13,000 miles on it, so I decided to do the short cut method. I didn't disconnect the brake lines and just slid the axles out far enough to pull the third. It works real slick if you decide to go this route as you don't have to change the seals or do the brake bleed. I put a hydraulic jack under each brake drum so neither axle is touching the seal. It'll be ready to put together in a couple days.
Old 08-21-2006, 12:42 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
dyogim's Photo Albums
dyogim will become famous soon enough.
Default Re: Help installing LSD
Are you talking about the 10 nuts that hold the carrier to the axle? The manual says 54 ft lbs. I just went around all the bolts twice after I tightened them.
Mike - http://dyogim.blogspot.com
Old 09-01-2006, 01:17 AM
mit42ls's Avatar
Dealer : Fred Anderson Toyota of Sanford
mit42ls's Photo Albums
Last Online: 07-30-2008 09:40 PM
mit42ls is on a distinguished road.
Anyone know about how much labor cost to get the TRD LSD installed?
Old 09-01-2006, 01:51 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
$200-$400.
Old 09-01-2006, 03:22 PM
2002 Toyota Tundra
DG, thanks for the torque info.
I pulled the third member without disconnecting the brakes or replacing the seals, etc. The cost to pull the third member and take it in and have a drivetrain shop install was $115. A new gasket was $7. I reassembled everything. So far, no leaks and I am impressed with the unit.
Similar Threads for: Help installing LSD
Auto LSD vs. Std LSD SuperBusa Tacoma 14 08-10-2005 01:07 PM
Hellwig Anti-Sway and LSD confederate2 Suspension & Axle 15 05-01-2004 01:52 PM
Electronic LS Questions scottl Suspension & Axle 3 12-17-2003 01:21 AM
synthetic in LSD calitundra Engine & Drivetrain 2 05-13-2003 01:37 PM
03 lsd vs trd lsd r80255 Engine & Drivetrain 2 04-19-2003 08:08 PM
