This is a discussion thread titled "Still confused on wheel spacer choices", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-04-2006, 05:28 PM
Brandon1's Avatar
Dealer : Leith Toyota
2003 Toyota Tundra
Brandon1's Photo Albums
Last Online: Today 01:35 PM
Brandon1 will become famous soon enough.
Send a message via AIM to Brandon1
Default Still confused on wheel spacer choices
I have called several companies that sell adapters. Some range from $114 for 4, to $360 for hub and wheel centric adapters. Fred Girsk (sp?) spacers says his are the best in america. I am wondering, do I really have to pay $360 for 4 wheel spacers? That sounds like alot of money for a piece of aluminum. Do I really need hub and wheel centric, neither?
The only thing is that the Fred Girsk adapters are wheel and hub centric and can be shipped tommorow, other companies need as much as 20 days!!!!
2003 Toyota Tundra V8 4x4 AC
Exterior: Trd Off-Road package, Trd Skid Plate, Borla Side Exit Exhaust, 30% Lumar tint, Enkei Deep Six 20's, 275/60/20 Cooper Zeon LTZ, Bilstein 5100's, Toytec add-a-leaf, UWS Lo-Pro Toolbox
Interior: Alpine 9851, CDT 6.5" components, Alpine MRP-F240, MRD-M300, Kicker Comp 10", Ruger SR9 9mm in the console...
Showroom Shine Details- Owner/CEO
www.autogeek.net Tell them "TS.com" sent you!
Old 09-06-2006, 01:42 AM
Imdone's Avatar
2004 Toyota 4Runner,
My eBay Imdone's Photo Albums
Last Online: Yesterday 05:30 PM
Imdone is on a distinguished road.
Default Re: Still confused on wheel spacer choices
Everyone that keeps saying the toyota is hub centric needs to read this:
Hub Centric vs
this too:
American Racing
Our trucks are Lug centric, which means the lugs center the wheel not the hub.
I would say go with whatever you can get as fast as you need, just make sure that they are lug centric not hub centric.
Work in progress...
Old 09-06-2006, 10:53 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Yesterday 04:30 PM
i noticed you have two threads with similar questions...
everybody is gonna say theirs are the best. there is no appreciable difference between steel and aluminum adapters, or spacers. mine are steel from aor4x4, i almost got a set from cali which were aluminum, i was ordering from aor at the time anyway and the shop in cali was out. they are LUG CENTRIC. so are the rims.
dont run spacers. only run adapters. they are not the same.
that is reasonable for adapters. they tend to run around 175 per pair, almost all that cost is machining, very little is material so theyre all gonna be a similar price.
when you get them, install and torque to 85 ft-lb in a star pattern, then do it again. put the wheels on the adapters and do the same thing. next day, pop the wheels off and retorque the lugs on the adapters, reinstall the wheels the same way. do this a few times, youll see that the lugs/nuts on the factory hub dont change much (if at all--shouldnt change at all). the lugs on the adapters will settle in, keep retorquing daily until they dont move. just leave the torque wrench in the truck and check every time you drive.
GFX by FreedomEagle50
Manual Hubs
Old 09-07-2006, 02:16 AM
Imdone's Avatar
Have to make an edit here.
If you still have OEM wheels they are hub centric but if you have aftermarkets they could be either.
I have been through 3 sets of aftermarket wheels and they have all been lug centric.
for your spacers though it will make it difficult to get the OEM wheels centered on the new lugs because they are not lug centric, if you are putting lug centric aftermarket wheels on these then it won't be an issue.
So for your question about the guy selling hubcentric spacers you would be best to use these if you have OEM wheels, but if you have aftermarket wheels it may not matter.
Work in progress...
Old 09-07-2006, 09:36 AM
Brandon1
This message has been deleted by nhparrot. Reason: Links/redirects to eBay are not permited per site policy - please see the FAQ
Old 09-07-2006, 02:07 PM
Dealer : Keyes Toyota Scion
2005 Toyota Tundra
TundraTaylor's Photo Albums
Last Online: 09-16-2008 04:35 PM
TundraTaylor is on a distinguished road.
How do these work? they push the wheel out further away from the body?
Old 09-07-2006, 02:12 PM
IStan's Avatar
Dealer : Findlay Toyota Scion
2001 Toyota Highlander,
- Other - '06 Boosted 350ZR
IStan's Photo Albums
Last Online: 10-23-2008 06:56 PM
IStan is on a distinguished road.
The adapter act like mini rims. They attach to the truck as your rims would. The adapters have a new set of studs which then your rims would attach to as if it were the truck. The adapters are 'safer' than spacers because spacers decrease the amount of thread on the stud for you to attach your rims to the truck.
In short. Yes, they push the wheel further from the body.
Tundra is gone...*Map Light mod *Keyless Upgrade *Monster ICruze *Nitto Terra Grappler AT 285/75/16 *Black Helo Maxx 8 16x8 *4x4 TRD Coils *4x4 TRD Shocks *Daystar 2.5" Spacer Kit *Bilstein 5100's *P.A 3" Body Lift *Toyota Drop-in Bedliner *Toyota LSD *Toyota Hood Protector *VentShades *Debadged *Tint *Flowmaster 50 Series Single Exhaust *Clear Corners *Chrome Nerf Bars*
Nissan 350ZR is here...350zen,org
Old 09-07-2006, 08:08 PM
2005 Toyota Tundra
Is that their entire function to push the wheels out, or does it allow you to mount different bolt pattern wheels on?
Old 09-07-2006, 08:40 PM
IStan's Avatar
Both.
Old 09-08-2006, 01:19 PM
2005 Toyota Tundra
so can you get adapters in any bolt pattern? if so, can we then run any type of wheel as long as the hub size is the same?
Old 09-08-2006, 02:17 PM
longwoodklon's Avatar
2001 Toyota Tundra,
2005 Toyota Sienna
longwoodklon's Photo Albums
Last Online: Yesterday 03:12 PM
longwoodklon is on a distinguished road.
Looks to me like if you ran the adapters, then the hub size of the rim wouldn't matter.
Brandon, you should just spring for the UCA's to get some extra clearance. Or get the adapters, then next set of tires get a 285 or 275 width so you can get rid of the adapter then.
/Mike
2001 2WD Silver Tundra: 4x4 TRD springs, Daystar 1", Carson AAL, red/blue Bilsteins, 265/75 Revo's, IS kit(minus bumper) and rims(hand polished), RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. 176k miles and counting......
Old 09-09-2006, 08:47 AM
Brandon1's Avatar
2003 Toyota Tundra
I went with the ebay adapters I posted earlier.
I like the 305 size tho.
Old 09-13-2006, 09:05 AM
Dealer : Koons Westminster Toyota
2008 Toyota FJ Cruiser Vodoo Blue,
2007 Toyota FJ Cruiser Vodoo Blue
CTL lll's Photo Albums
Last Online: 05-23-2008 01:23 PM
CTL lll is on a distinguished road.
Brandon1 Did You Recieve Your Spacers From ebay Without Problem?
Old 09-14-2006, 12:08 PM
Brandon1's Avatar
2003 Toyota Tundra
They arrive tommorow.
Old 09-16-2006, 12:18 AM
superdave's Avatar
Dealer : Ray Brandt Toyota of Metairie
superdave's Photo Albums
Last Online: 11-07-2008 02:47 PM
superdave is on a distinguished road.
Just my .02 if anyone is interrested. There is absolutley nothing wrong with running bolt on, one piece spacers. Two piece spacers go beyond sketchy (my friend had a set on his dodge). I ran my 1 piecers for about a year with relatively little problems (lost one wheel bearing impart of some water and added leverage). I may be revealing my level of sanity with this, but the spacers were 2.5". oops. Anyway, bolt on spacers are good as far as I'm concerned, as long as they clear your trucks' lugs (any shorter and you have to grind 'em down). If you want to go this route, I strongly recomend performancewheel.com
Old 09-17-2006, 03:18 PM
Brandon1's Avatar
2003 Toyota Tundra
well, I put my spacers on fri. and the tires did not rub anymore on the control arm or the frame, but rubbed horribly on the fenders. I tried to cut a little, but it would take alot of cutting for these to work.
I guess I need 1" spacers. I was under the impression that 1.25-1.5" spacers would work just fine.
Similar Threads for: Still confused on wheel spacer choices
Are wheel spacers any good? keninsb Suspension & Axle 8 02-08-2008 08:09 PM
Wheel choices - help me spend money kelltl Tires and Wheels 2 06-14-2006 11:30 PM
Steering Wheel Color Raider Man Interior & Exterior 0 11-09-2005 09:49 PM
Keeping 4wd active: Dry road use o.k.? molex Engine & Drivetrain 14 12-22-2003 04:05 AM
