This is a discussion thread titled "Lowered truck problems", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-05-2006, 02:32 AM
Dealer : Keyes Toyota Scion
2005 Toyota Tundra
TundraTaylor's Photo Albums
Last Online: 09-16-2008 04:35 PM
TundraTaylor is on a distinguished road.
Default Lowered truck problems
I've been running the SOS 2"/4" drop kit for a few months. It was installed by a local shop, not by myself. I recently took it into a different shop because the rear of the truck made a horrible klunking sound and I noticed that a nut was missing off one of the rear shackles. The new shop said that who ever installed the kit originally failed to tighten and lube the truck properly. So after I drove away from this shop the truck rode great. Now a few weeks have passed and I am hearing some type of creaking from the rear and the front is squeaking with each bump. Not speed bumps mind you but any time the shock is compressed even by simple freeway driving. In short my truck sounds like I drive a 1960's International farm truck. The truck is going back to the shop when I get a chance, or should I take it to Toyota? Anyone else who has lowered their truck experienced similar sounds? Or anyone with a knowledge of lowering kits have any idea what is causing this?
Old 09-05-2006, 02:33 AM
2005 Toyota Tundra
Default Re: Lowered truck problems
For what it's worth if your're trying to trouble shoot, I'm still running stock 16" wheels and tires and I upgraded to the Tokico shocks that SOS hypes.
Old 11-24-2006, 02:40 AM
Dealer : Don Jacobs Toyota
n2oiroc's Photo Albums
Last Online: 10-05-2007 01:36 PM
n2oiroc is on a distinguished road.
the problem is the rear shackles in the kit. my creaks and groans all the time. this summer its going back to the stock setup except ill remove a leaf and use 1" shackles if i have to, to keep it lowered. im just not sure how to keep the spring pack i one piece after removing the clamps.
Old 11-27-2006, 03:46 PM
Dealer : Yokem Toyota
2006 Toyota Tundra,
2003 Toyota Celica
big_mike's Photo Albums
Last Online: 10-18-2007 10:16 AM
big_mike is on a distinguished road.
What about lubing the bushing with some grease?
Old 11-29-2006, 10:07 PM
2002toytundra's Avatar
2002toytundra's Photo Albums
Last Online: 11-14-2008 10:33 PM
2002toytundra is on a distinguished road.
The bushings must be greased I used a synthetic chassis grease (rear drop shackles), additionally the torque applied to the bolts must be correct. If the bolts are over tightened in the front or rear this will cause the squeeks and groans. Not sure about the Tundra front end but on the traditional coil spring and A-arm set ups, the upper coil isolator (doughnut shaped pad) can shift or wear out and it will have a metal on metal squeek that is ungodly.
Old 11-30-2006, 10:20 AM
grease only works for a couple weeks and i tried everything from just seated to torqued to stock spec. its just not a very good design. im not saying sos is junk, the tundra just inst lowering friendly.
Old 11-30-2006, 01:24 PM
maudib's Photo Albums
Last Online: 02-02-2008 05:38 PM
maudib is on a distinguished road.
Yep, same here. Had the SOS drop for over a year now, always creaks and groans even with constant lubing.
Old 11-30-2006, 09:43 PM
Dealer : Ron Carter Toyota
2003 Toyota Tundra
Supercharged03's Photo Albums
Last Online: 08-15-2008 10:28 AM
Supercharged03 is on a distinguished road.
I have had the SOS drop kit on my truck for several months now without squeaks. In fact, I had squeaks BEFORE installing the kit and now the sqeaks are gone.
There was a TSB or something posted a couple of years ago regarding squeaks that resulted from the shock absorber bushings being installed backwards. You might try looking at this as the source of your squeak.
Old 12-07-2006, 12:18 AM
There has also been some postings about the leaf spring packs creaking. If I remember correctly some had replaced the pads in the packs with Polyeurethane ones.
Old 12-14-2006, 09:44 PM
yotso's Avatar
Dealer : Servco Auto Center
2004 Toyota Tundra
yotso's Photo Albums
Last Online: Yesterday 12:50 AM
yotso is on a distinguished road.
i just got the sos 2/4 drop installed and it looks great other than the fact that the front looks higher than the rear.looks like an inch or two higher. the perches seem to be installed correctly. is this normal? does the front springs need to get settled in for awhile then it will lower? anyone had/has this problem?
Old 12-14-2006, 10:13 PM
2005 Toyota Tundra
yotso...i want to say that i thought the same thing at first. now i dont. dunno if they settle or its an optical illusion since youre used to seeing the back end raised. what kind of wheels are you running? or planning on running?
Old 12-15-2006, 02:59 PM
yotso's Avatar
2004 Toyota Tundra
yeh the truck looks level but space in the between the fender makes it look higher. but im running the stock 16's for now and planning to get some 20's or 22's. I saw your truck pics and it looks fine. mine in the other hand, is very noticeable. ill try to get some pics up soon.
Old 01-10-2007, 01:37 AM
yotso's Avatar
2004 Toyota Tundra
finally got the pix of my drop loaded...still needs work. rides well, but very sensitive on the bumps. the rear bumpstops hit and something squeaks but all in all looks good, just waiting for the 22's...
http://www.tundrasolutions.com/photo...0&ppuser=34590
Old 01-16-2007, 06:01 PM
2005 Toyota Tundra
looks good. i like the height of this kit a lot. low but still looks stock like a lightning or ss. bugs me that guys i work with have stock chevys that look like this off the lot. oh well.
Similar Threads for: Lowered truck problems
Went to the Track for this?(long post) Hodgeee Off-Topic 17 05-05-2008 11:18 AM
Bugs, TSB's, problems worked out on 06' Tacos??? paulphilly Tacoma 11 10-18-2005 02:22 PM
Guy in Africa bought my Truck, Scam? 00TRDTUNDRA Off-Topic 23 02-15-2005 06:11 AM
Powertrax No-Slip install tips? batman Engine & Drivetrain 9 10-27-2003 02:53 AM
Problems Starting Truck! BT-22 Engine & Drivetrain 11 03-21-2002 03:08 PM
