This is a discussion thread titled "UCA Creaking like mad!", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-07-2006, 10:06 PM
Mack4's Avatar
Dealer : Classic Toyota
2001 Toyota Tundra,
2003 Toyota Tundra
Mack4's Photo Albums
Last Online: 03-20-2008 01:34 AM
Mack4 is on a distinguished road.
Default UCA Creaking like mad!
I have the Camburg UCA's and they creak whenever I turn, I can actually feel the vibration in the steering wheel. Can I just hit it with some wd-40 or should I grease them up with an automotive grease?
-Mack
2003 Phanton Grey 4x4 Limited Tundra
2.5 King Coilovers
Total Chaos UCA
Bilstein 5100's
Wheeler's add-a-leaf
33" Mickey Thompson MTZ on Classic Locks
Magnaflow Exhaust
Outlaw Intake
JBA Headers
4.56 Gears
Rear Diff. Extended Breather
Skidrow Skidplate
Custom Front and Rear Bumper
Trimmed Bedsides
Old 09-07-2006, 10:10 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Yesterday 04:30 PM
Default Re: UCA Creaking like mad!
If they have grease fittings, hit them liberally with the gun. If not, put it on jack stands and remove the long bolt holding the UCA in place. Grease between the large washers and the bushings and the squeaking will stop (and then start again next season).
-S
GFX by FreedomEagle50
Manual Hubs
Old 09-08-2006, 07:08 PM
Dealer : Claremont Toyota Scion
2003 Toyota Tundra Silver Sky,
- Other - 2003 GSXR1000
ferretboy's Photo Albums
Last Online: 11-17-2008 06:37 PM
ferretboy is on a distinguished road.
Don't they have built-in zerk fittings?
If so... LUBE them bad boys up already!
If they haven't been lubed, you may want to check the condition of the bushings... they may be damaged from operation in dry conditions (i.e. - the absence of lubricant).
2003 SR5 TRD Silver Sky AC:
Current Mods: Full Leather Interior (Dark gray leather with black perforated leather centers) / Power Webasto Sunroof / XM Satellite Radio / Alarm modification / Magnaflow Dual exit cat back system / Trenz Perimeter Grille / Trenz Perimeter Bumper Insert / Hornblasters.com Train Horns / Hornblasters.com Old Style "OOGAH" electric Horn / VIAIR Dual 420C Compressors, Dual VIAIR 2.5 gallon air tanks / Dual Pneumatic Quick Connects for onboard air use / RCD 6-inch suspension lift / TC rack bushings / Camburg Uni-ball upper control arms/ToyTec billet spacers/35-inch Nitto Mud Grappler tires (35x12.50x20) / 20-inch Bonspeed Alloy Intense 6 Wheels with dark pewter centers / Westin Platinum Series side bars (black powdercoated stainless steel)
Near Future Mods: Line-X Bedliner / FabTech flat mount tire carrier / Tonneau cover / Precision Gear swap
Old 09-08-2006, 09:05 PM
drewbush's Avatar
Dealer : Manhattan Beach Toyota
2001 Toyota Tundra,
2000 Toyota Camry
drewbush's Photo Albums
Last Online: 11-19-2008 08:57 PM
drewbush is on a distinguished road.
-Mack
Its your uniball in the upper control arm. Wipe out the dirt(if any) and spray it with triflow. Mine do the same thing.
Old 09-09-2006, 09:56 AM
Dealer : Poway Toyota
2004 Toyota Tundra
dezert_rida's Photo Albums
Last Online: 11-19-2008 01:35 AM
dezert_rida is on a distinguished road.
Send a message via Yahoo to dezert_rida
-Mack
That can be annoying. I have to lube my uniballs every 6 months. Ive been using Moly grease. I clean the area, apply liberally with the truck jacked up under the arm so i can turn the wheel by hand side to side and get the grease distributed top and underneath. Then I jack the truck up by the frame so the arms hang down and get the rest.
Interstingly enough, I havent lubed the zerks for the bushings since I installed the arms 2 years ago. Not a squeak. Its on my to do list.
Similar Threads for: UCA Creaking like mad!
Another UCA question. chan 1Gen-Tundra 3 02-25-2006 07:02 PM
Creaking brake pedal arm riggs 1Gen-Tundra 11 09-01-2005 02:54 PM
Clunks in 4WD boody Engine & Drivetrain 26 08-23-2005 11:25 PM
Creaking sound between dashboard and front window jimberry Interior & Exterior 2 02-19-2005 12:41 PM
Total Chaos UCA and caster setting ? tundra61 Suspension & Axle 1 07-25-2004 09:15 PM
