This is a discussion thread titled "Spring Compressors", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
All a man really needs for happiness in this world is a good woman, a faithful dog, and a big-a$$ed set of tires on his truck.
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Audiovox ACA200W Rear-view camera, Audiovox XM Express Sattelite Radio Receiver, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Large Dog
the pittsburgh. the general would be great, but i dont know if itll fit the stock coil. might be perfect for aftermarket coils without a taper at one end, nice if your aftermarkets are preloaded and the adjusting collar is frozen...
yeah, that's what I used. Get yourself 2 sets, then use 3 per coil. I used 2 on 1 coil and though they didn't bend much, using 3 relieved my anxiety. Though, using 3 does make it a little tricky to get the compressor tabs over the coil. /Mike
2001 2WD Silver Tundra: 4x4 TRD springs, Daystar 1", Carson AAL, red/blue Bilsteins, 265/75 Revo's, IS kit(minus bumper) and rims(hand polished), RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. 176k miles and counting......
Yes buy two sets, I had a similar set; did my 65 springs twice and the truck once, they bent into a nice curve each time, but did not quite return to normal the last time, they're garbage now...they'll work great! I recommend air tools over arm power.
2003 SR5 V8 4x4 Access Cab; SS Autochrome intake; Truxedo cover; Rhino lining; 255/85/16 Cooper Discoverer S/T's; 16x8 Black Steel Wheelers; Ram Air; breather extensions; Viair 380C on board air; Daystar 1.5" lift; Deaver 3leaf AAL; homemade bed rack; 21 gallon water tank
I've used mine 4 times in the last year. The price is pretty steep, but I figured it was worth it for the peace of mind regarding safety alone. If it was going to be a one time thing I would probably take it to a shop and have them replace the shock.
Rick
Black 2002 Limited 4x4
Mods: TRD Supercharger, Boost Guage, Unichip, Clifford AvantGuard 4 Alarm/Remote Start system, Auto Dimming mirror w/compass & temp, Sequoia Power Antenna, Retrax bed cover, Donahoe long travel coilovers, Total Chaos Uniball UCA, Helo Black Maxx 6 wheels w/ 265/70R 16 Michelin LTX/MS tires, Ivan Stewart front bumper cover, TRD headers, TRD dual exhaust, factory LSD, Total Chaos urethane steering rack bushings, Wheelers urethane front swaybar bushings, Helwig rear antisway bar, Goodyear Gatorback serpentine belt, Fumoto engine oil drain valve,Denso IK22 Iridum spark plugs, Eclipse AVN2454 AM/FM/CD/DVD/Navigation system w/ color backup camera, SilverStar headlights and fog lights, WeatherTec in-channel wind/rain deflectors, Ventshade door sill protectors, Toyota hood protector, TracRac sliding rack system with cantilever extension, IPOD integrated with Eclipse AVN2454, PopnLock electric tailgate lock, Sequoia electric condenser fan, Viair 440P portable compressor, ORS manual hub conversion w/Aisin hubs, StubbsWelding SKO rock sliders, 60" hi-lift extreme jack with slider adapter, Odyssey PC1700MJT battery
Coming hopefully - Warn 9.5ti multi-mount transportable winch, ARB lockers front and rear, 4.30 gears
Thanks, Jim.
You're still gonna give me a hand when I do the lift? Just bought me a 33 gal Compressor over the weekend, so running an impact wrench should not be a problem.
Sure thing; as long as its not in October. You need an impact or did you spring for one of those too?
I tried it out and it starting bending before the springs even moved. The seats for the coil wraps do not fit. You need a seriously, heavy duty compressor to work on the Tundra coils.
Whew! That's good to know. I was seriously leaning toward that one. Not now, I guess. Thanks!
Why rent? You can buy the darn things for $8 from Harbor Freight. And then you'll always have them for the future.
I rented a set a few years ago when I replaced the MacPherson struts on a Dodge Colt. The things were so worn, I was afraid they would slip off the threads. I went ahead and used them anyhow, because I was too dumb to know any better, but I'd never rent again.
