This is a discussion thread titled "06 alignment", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-17-2006, 01:35 PM
Dealer : Kolosso Toyota
2006 Toyota Tundra Trd dble cab
Jfleku's Photo Albums
Last Online: 04-19-2007 08:37 PM
Jfleku is on a distinguished road.
Default 06 alignment
I have a 06 Tundra dble cab it has had a alignment done about 1000 miles a go it was chopping the passenger front tire on the out side. It was checked by the dealer and I was told it was in spec and there was nothing they could do about it. I still continues to chew up the pass front is there any other alignment specs out there that can help thanks for your info.
Old 09-17-2006, 01:57 PM
rambrush's Avatar
Dealer : Findlay Toyota Scion
2006 Toyota Tundra,
2003 Toyota Avalon
rambrush's Photo Albums
Last Online: Today 07:53 AM
rambrush is on a distinguished road.
Send a message via AIM to rambrush
Default Re: 06 alignment
Need to learn to use search function
Heres your link to get the alignment correct. DJ will be the GURU on alignment issues and concerns.
http://www.tundrasolutions.com/forum...es/#post511737
Tire wear is caused by either a camber or toe in problem, Caster will not affect wear.
Chopping on outside? not feathered across? any cuping?
wear on outside sounds like a camber problem. Need to get set like DJ suggests in his posts.
Similar Threads for: 06 alignment
Tacoma Alignment problem kbshadow Suspension & Axle 12 01-05-2006 10:19 PM
Desperate need of alignment help...d'oh! DevinSixtySeven Suspension & Axle 3 09-28-2005 11:59 AM
Need advice on of Tacoma alignment. kbshadow Tires and Wheels 3 04-23-2005 09:21 PM
Alignment Setting Recommendations Alan Tires and Wheels 9 04-12-2003 08:15 AM
DJ's Alignment Setting Recommendations nhparrot Knowledgebase Archive 0 04-10-2002 06:50 AM
