This is a discussion thread titled "King Coilovers + RCD 6-inch lift?", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-19-2006, 01:19 PM
Dealer : Claremont Toyota Scion
2003 Toyota Tundra Silver Sky,
- Other - 2003 GSXR1000
ferretboy's Photo Albums
Last Online: 11-17-2008 06:37 PM
ferretboy is on a distinguished road.
Default King Coilovers + RCD 6-inch lift?
Has anyone gone this route? What can be expected by using King adjustable coilovers with an RCD 6-inch lift? I'm looking for a little more travel than the 6-inch lift provided.
Anyone have any insight?
2003 SR5 TRD Silver Sky AC:
Current Mods: Full Leather Interior (Dark gray leather with black perforated leather centers) / Power Webasto Sunroof / XM Satellite Radio / Alarm modification / Magnaflow Dual exit cat back system / Trenz Perimeter Grille / Trenz Perimeter Bumper Insert / Hornblasters.com Train Horns / Hornblasters.com Old Style "OOGAH" electric Horn / VIAIR Dual 420C Compressors, Dual VIAIR 2.5 gallon air tanks / Dual Pneumatic Quick Connects for onboard air use / RCD 6-inch suspension lift / TC rack bushings / Camburg Uni-ball upper control arms/ToyTec billet spacers/35-inch Nitto Mud Grappler tires (35x12.50x20) / 20-inch Bonspeed Alloy Intense 6 Wheels with dark pewter centers / Westin Platinum Series side bars (black powdercoated stainless steel)
Near Future Mods: Line-X Bedliner / FabTech flat mount tire carrier / Tonneau cover / Precision Gear swap
Old 09-19-2006, 08:21 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Yesterday 04:30 PM
Default Re: King Coilovers + RCD 6-inch lift?
try a search through the stuck rcd threads...a while back people were talking about combining other kits with the rcd. what you seek may already be in that thread.
the short answer is that unless the kings have an extended shaft, you wont get any more travel than normal. i 'spose that with a longer shaft, shock hoop and uniball upper you could probably get more down and uptravel than normal but im not sure if the rcd kit comes with lower bumpstops or similar.
-sean
GFX by FreedomEagle50
Manual Hubs
Old 09-21-2006, 08:34 PM
Imdone's Avatar
2004 Toyota 4Runner,
My eBay Imdone's Photo Albums
Last Online: Yesterday 05:30 PM
Imdone is on a distinguished road.
RCD reuses the stock bump stops but they "appear" to be lower in position than where the stock ones were.
I just changed my coils to 1" long and added and extra 200lbs to the spring rate and it picked the truck up another inch but I don't get any more travel per-se due to the limited length of the bilsteins if you try to go much more on the down travel you may end up with some cv joint carnage.
Worth looking into none the less. I know that king makes a coilover to fit and I was told that Donahoe may have a set with an extension on their set up to fit.
Either way with the amount of view that the RCD lift gives for the upper control arm and the top of the coilover it will look really good!!!!
Work in progress...
Similar Threads for: King Coilovers + RCD 6-inch lift?
4x4 tundra lift 5 inch- 6 inch lift question louisha Suspension & Axle 8 02-28-2005 03:00 AM
Tuff Country vs RCD suspension lift for Tundra stevenvta Suspension & Axle 8 02-24-2005 10:23 AM
Tundra Offroad Mods and Tech DevinSixtySeven Off-Roading 15 05-24-2004 10:22 AM
Question for those with 2.5 inch coilover lift leadsled Suspension & Axle 17 02-25-2004 10:56 PM
New Custom King Coilovers?? Blk00TRD Suspension & Axle 28 07-29-2003 11:29 AM
