This is a discussion thread titled "so why does it pull to the right???", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
05 Tundra DC...just had it aligned at toyota...it's not bad but it still pulls a bit...bringing it back tomorrow...thought you 'experts' might have some ideas
I'm no expert but some of my friends are mechanics and they have heard many times that guys at dealerships don't always do a "real" alignment. They simply fill the tires (which can effect alignment) and adjust just the camber i think? I may be wrong on what exactly it is but I have been told that some cheap guys may not do a full alignment.
If they get payed flat rate, they can work 15 min on your truck and still get payed for an hours job. It's a sad truth.
I payed $58 for my recent alignment and it was great! It was done on a Hunter alignment machine, and I saw the exact before and after numbers printed out from the machine. There is no lying in that! Plus the guy complimented my truck when it took it for a before and after test drive . Said it sounded great and it drove very nice too!
Find a small shop and a guy with a trusting face. It's strange but I'm telling you it pays off. Make some friends and the life of your truck will be extended greatly! JUST STAY AWAY FROM DEALERSHIPS!!!!!
__________________ David~2001 Toyota Tundra 4X4 TRD SR5~SSautochrome headers~Single 2.5" exhaust w/ Flowmaster 50 series delta flow muffler~K&N FIPK intake system w/True-flow filter~ASP underdrive pulley~Hellwig Anti-Sway Bar(removed)~Powertrax No-slip~Bilstein 5100 front and rear w/AAL~Diff breather mod~255/85 BFG M/T on Wheelers Black Steelies Type B~Custom Rocksliders~Skid Row front skid plate~Custom Transfer case skid plate
Could be a few things...before i got my TC UCA's mine would always pull to the right from a bad upper ball joint. Once i fixed that and got it aligned it was good.
Current Mods: 3" Body Lift -- 3" Fabtech Coilover w/ AAL -- Unichip -- Flowmaster Dual exhaust w/o resonator -- K&N Aircharger kit -- Total Chaos UCA's -- 1" Diff Drop -- TC Steering Rack Bushings -- Pro Comp Alloys w/ Cooper Discoverer STT 315/75-16's -- 20% window tint -- FOX Emulsion shocks (Rear) -- Black Euro Tail lights -- Line-X Bedliner -- Superlift Truspeed Calibrator
I second that. I did it for mine and it has been great!
Anybody ever hear of a "tire pull"? I never have, but was told that sometimes the tires will cause this dilema even though everything else is right on. ???
Yup, a tire can generate a "pull" all by itself. It's called "coning" because the tire rolls along as if it's a cross-section of a cone.
You can identify it be swapping your tires, one at a time, with the spare. If the pull stops, then the tire causing the pull is the one the spare has replaced. It's easy and you can do it yourself.
Ditto DJ's comments on tire pull. I'm battling my own alignment/wheel balancing issues (sordidly layed out in another thread) and during one of my failed re-balancing attempts the tech swapped the front tires. Yow, talk about a pull to the left! I swapped them back and the pull was gone, so, yes, tire wear can definitely influence perceived alignment.
Erik
Swap your front tires, one at a time, with the spare. You can quickly identify which tire causes a pull.
This is probably a dumb question but will this work if tire sizes are different? I have 285's on!
It's not a dumb question. 285's are not remarkably bigger than 265's, but the size difference might induce a small effect of its own. Haven't been there, haven't done that. But, a pull caused by tire conicity would likely still stand out like a sore thumb. I'd give it a try.
Tell me if this makes any sense. My alignment was fine and the truck tracked fine. I could let go of the steering wheel and it would travel a long distance in a straight lline. I get the tires rotated and the truck pulls to the right MOST of the time but not always. Sometimes at high speed on the interstate you release the wheel and it seemed to slightly "glide" left and right but still track straight before veering off - always to the right.
Ray Kane If you don't try, nothing happens
Reason: spelling
A tire with a conicity problem that is on the rear can't generate a pull to the side because the rear axle can't be steered by the forces the tire generates. But, that same tire can generate a pull to the side if it is rotated to the front. Likely that's what's happened. I suspect you've got a front tire with a very slight conicity problem.
