Re: 99 Rav 4 Rear Shock Replacement
You're probably going to limited on shock selection- just visit AutoZone or whatever and get the best they carry.
As for the job itself, crawl under there and take a look. Can you access the top and bottom mounts of the shocks and get a socket on them? If yes, you might be able to get away without jacking it up or taking the wheel off.
If you do need to- BE CAREFUL!!!! Jack up the vehicle using the method and jack points described in your user manual. Spend as little time underneath as you can.
I would also soak both the upper and bottom nuts/thread in P-BLASTER the night before to help break any rust.
Replacing shocks it a very easy job. Probably the most frustating part will be accessing the top shock mount or keeping the upper stud mount from rotating as you try to get the nut off.
2005 Tundra Access Cab 4x4 4.7L - BFG ATs on MT Classic Locks - Warn M8000
