This is a discussion thread titled "How about a Bilstein 5100 Adjustable shock update", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
  #91 (permalink)
Old 03-29-2007, 09:18 PM
Dealer : Courtesy Toyota
2004 Toyota Tundra
jaegermeister's Photo Albums
Last Online: 09-21-2008 02:32 PM
jaegermeister is on a distinguished road.
Default Re: How about a Bilstein 5100 Adjustable shock update
Holy crap!! 3+" on a double cab??? Wonder what my little v6 access cab will get!!!
I wonder if you just ground the weld down a little or ground your own recess into the spacer if that would work. However, I have no knowledge of this situation - I haven't got to doing mine yet.
By the way - that's a super sharp pic right there!
2004 Tundra Access Cab V6 4X4 5speed
Bilstien 5100's set on middle groove, 305/70/16's on DC-1's
1973 Jeep Wagoneer w/4.6L jeep I-6 stroker!
  #92 (permalink)
Old 03-29-2007, 09:59 PM
sbsyncro's Avatar
Dealer : Toyota of Santa Maria
2005 Toyota Tundra
sbsyncro's Photo Albums
Last Online: 09-16-2008 02:41 PM
sbsyncro is on a distinguished road.
I'm wondering if maybe it is because I have a non-TRD, and before the lift it was REALLY low in the front. (like a '70's funny car). Now it is about 1" higher in the front, which looks a bit goofy but not too bad. Hopefully when I get the Deaver AALs installed tomorrow it will level it out (which means nose in the air while towing a trailer...).
2005 4WD Tundra Double Cab Limited
Salsa Red Pearl
Bilstein 5100 front & rears
TC Diff Drop
TC Steering Rack bushing kit
Deaver rear AALs
OEM 2005 Solara Navigation
VSE Bazooka Sub
Peragon aluminum folding tonneau cover
  #93 (permalink)
Old 04-01-2007, 09:33 PM
jmevans_2's Avatar
Dealer : Bondys Toyota
jmevans_2's Photo Albums
Last Online: 05-27-2008 06:51 PM
jmevans_2 is on a distinguished road.
I got mine put in over spring break. I think I did pretty good on my budget. I got the front shocks(5 settings:used highest setting) and rear 1" blocks put in for $100 and an alignment that was $45. Also instead lighting my money on fire and buying blocks from wheelers, I just bought them from autozone. Blocks and U-bolts were $34. I spent roughly $374 on everything installed.
My truck has an agressive stance with the front 1/4" higher than the back. Now I have to use the OS handle on the driverside column to get in my truck.
I have done some light offroading and they are very comfortable. Still need to get the rear shocks to finish it off but I'm ok right now.
Here is the instruction sheet that Shane emailed me. Hopefully I can attach it.
Engine: TBS
Accessories: Lowpro Black toolbox
Tires: 265/70/R16 Eldorado ZTR Sports
Suspension:
Front: Bilstein 1500 Adjust. 2.5"
Rear: 1" blocks
  #94 (permalink)
Old 04-05-2007, 09:09 PM
Dealer : Hamer Toyota
2005 Toyota Tundra
climberpm's Photo Albums
Last Online: 10-15-2008 03:15 PM
climberpm is on a distinguished road.
Default Re: Measurements from Install on top groove...
Originally Posted by sbsyncro View Post
On another note, I had the fronts installed today on the top most groove (of the 5 grooves) and parked in the same spot in my driveway, here are the before and after measurements:
Driver's Side
Before: 19 5/8"
After: 22 7/8"
Pax Side
Before: 20"
After: 23 3/4"
Yikes! As you can see it raised the front 3-1/4" to 3-3/4" Yowza!
No wonder my passenger side CV boot starting spitting grease immediately on the drive home. Hopefully they will settle over the next couple of days - otherwise I'll be pulling them out to drop them down a notch or two, or else risk destroying my upper ball joint and CV joints... (Or do I just buy some Camburgs..... bwahaha! )
So how are things settling out? I'm getting things lined up to do pretty much the same lift you just did. Wondering about the grease/cv problem? How about the diff drop? I read another post that said they had issues too with the TC diff drop. Sounds like you just have to work through it? Longer bolts for the skid plate?
Anyone know if there are there other diff drops available that supply these items?
Paul
  #95 (permalink)
Old 04-06-2007, 11:28 AM
jclark01's Avatar
Dealer : Appleway Toyota
2004 Toyota Tundra
jclark01's Photo Albums
Last Online: 04-08-2008 07:55 PM
jclark01 is on a distinguished road.
So will these give me u just as much lift as my 3" toytec spacers?
REZ TOY
2004 4X4 DC 38,550 Mi.
3" toytec W/ add a leaf,
17" ultra type 160 rims wrapped W/ 285/70/17 Wrangler MT-R,
Custom Hood,
& Clear corners
  #96 (permalink)
Old 04-06-2007, 11:42 AM
Cyberbilly's Avatar
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Cyberbilly's Photo Albums
Last Online: Today 12:01 PM
Location: Fredericksburg, VA. America's most historic city.
Cyberbilly will become famous soon enough.
Send a message via Yahoo to Cyberbilly
Paul
That's the problem I ran into. Fortunately, my installer had longer metric bolts in stock and with a couple of old shock bushings to act as spacers/cushions, we solved the skid plate problem.
You could, of course, just get your own longer skidplate bolts as long as they were automotive grade hardware (nothing from Home Depot, etc.)
I'm sure there are DD kits out there with the longer skidplate bolts, but I don't know of specifics.
All a man really needs for happiness in this world is a good woman, a faithful dog, and a big-a$$ed set of tires on his truck.
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Audiovox ACA200W Rear-view camera, Audiovox XM Express Sattelite Radio Receiver, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Large Dog
Featured Sites: Truckblog.com Cardomain.com RateMyRide.com SportTruck.com TruckTrend.com
  #97 (permalink)
Old 04-06-2007, 11:58 AM
Dealer : Jay Wolfe Toytota
2002 Toyota Tundra,
- Other - 1991 4-RunnerCrawler
gbetzbikes's Photo Albums
Last Online: 10-30-2008 09:42 PM
gbetzbikes is on a distinguished road.
I hear that the new Donahoes have a "IVD coating" supposedly to protect from harsh environments? I live in Wisconsin/Minnesota a lot of road salt up here. Any advice? Do other Coilover brands SAWs etc.. hold up in harsh climates?
  #98 (permalink)
Old 04-06-2007, 02:07 PM
cleanb13's Avatar
Dealer : Boch Toyota South
cleanb13's Photo Albums
Last Online: 11-20-2008 09:34 PM
cleanb13 is on a distinguished road.
I have my C/O's at SAW and they told me that they have a new body coming out that was tested against the elements and passed without a problem. I'm going to switch my bodies and see if it's true.
2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 Revos on Wheeler's black alloys, True Flow intake tube and filter with a modded air box, JBA titanium coated headers, Aero 2525 muffler with stainless steel pipes and resonator removed, Skidrow front skidplate, EBC "green" brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Wheeler's polyurathane front swaybar bushing kit,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Silverstar fog light bulbs, , Viair 300P air compressor
Wish list: Line X'd front and rear bumper, rock sliders
  #99 (permalink)
Old 04-15-2007, 02:01 PM
TRDDave's Avatar
Dealer : Miller Toyota
TRDDave's Photo Albums
Last Online: 10-20-2007 06:30 PM
TRDDave is on a distinguished road.
I just put on a pair of the 5100 Pre Load Adjustable shocks yesterday and they are awesome!! The install was really easy (I have access to a commercial, floor mounted strut compressor), it took about 2.5 hours to install. The ride is great! I haven't hit any dirt yet, but my Tundra is a 2wd so it won't see much dirt anyways. Here are a couple pics with 17" Helo Maxx 6 wheels, and 285/70/17 BFG Mud Terrains. Left the rear completely stock, sits just like I wanted it too!
  #100 (permalink)
Old 04-15-2007, 06:06 PM
sbsyncro's Avatar
2005 Toyota Tundra
Don't suppose you took before and after measurements, by any chance?
Salsa Red Pearl
TC Diff Drop
Deaver rear AALs
VSE Bazooka Sub
  #101 (permalink)
Old 04-15-2007, 09:59 PM
D.B.'s Photo Albums
Last Online: 03-01-2008 03:28 PM
D.B. is on a distinguished road.
TRDDave,
The Bilstein's look like they did a great job of leveling out your truck. I have a 2006 2wd AC V-8 Tundra and would like to achieve the same leveling stance. Do you remember what settings you used on the 5100's? Any before and after measurements? Did you notice any change in the handleing after the install?
Thanks in advance for your reply.
DB
  #102 (permalink)
Old 04-16-2007, 11:29 PM
TRDDave's Avatar
No measurements, sorry. I was too anxious to install them!
The ride is great. A little stiffer than stock, but it feels like a truck now, not a camry!
I have the shocks on the highest setting.
  #103 (permalink)
Old 04-17-2007, 12:46 AM
jmevans_2's Avatar
TRDDave, What did you use to lift the back?
Looks like you lifted the rear 1" like I did. Did you use the Bilsteins in the rear as well?
I like the aggressive stance, especially the wheel and tire combo. I will probabaly get some black rims like those.
Engine: TBS
Suspension:
Rear: 1" blocks
  #104 (permalink)
Old 04-17-2007, 05:15 PM
Dealer : Fred Haas Toyota Country
jpphill_2000's Photo Albums
Last Online: 11-18-2008 11:53 AM
jpphill_2000 is on a distinguished road.
FYI Guys, I have found front and rear Bilstein 5100 for $315 for both including free shipping on ebay. Waiting for mine to come in and get installed.
  #105 (permalink)
Old 04-17-2007, 11:46 PM
TRDDave's Avatar
Absolutely nothing in the back. I bought a 1" block thinking I would need it, but like it just the way it is. It has the stock Bilsteins out back.
2006 Tundra DC, 2WD TRD
Bilstein 5100 Pre-Load Adjustable Shocks
Helo Max 6 Chrome Wheels
BFG 285/70/17 Mud Terrains
Limo Tint
Rhino Liner
Gibson Headers (Courtesy of Gibson Performance)
Gibson Performance Cat Back Exhaust
Similar Threads for: How about a Bilstein 5100 Adjustable shock update
TRD coils vs. bilstein 5100 coilovers? blahlah Suspension & Axle 7 01-11-2008 07:56 AM
Has anyone used BILSTEIN 5100 Series Front Adjustable Coilovers? Elrod1529 1Gen-Tundra 14 03-19-2007 02:08 PM
bilstein 5100 leveling shock help langtown 1Gen-Tundra 1 10-10-2006 10:20 PM
TRD coils vs. bilstein 5100 coilovers? blahlah 1Gen-Tundra 0 06-12-2006 12:31 PM
