This is a discussion thread titled "Wheel hub bearing problem", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-22-2007, 08:00 PM
Dealer : Gene Messer Toyota
FiberodTundra's Photo Albums
Last Online: 11-04-2008 08:04 PM
FiberodTundra is on a distinguished road.
Default Wheel hub bearing problem
I am completely rebuilding the front of our '01 Tundra 4x4. I have the spindles loose and the axles out. My question is are the bearings pressed into the spindle? Is this something I need to take to a machine shop to have swapped out? Same thing with the carrier bearing on the rear. Is it a press fit or slip on?
Old 02-22-2007, 11:54 PM
tundra2501's Avatar
Dealer : Hansel Toyota Scion
tundra2501's Photo Albums
Last Online: 03-16-2008 04:58 PM
tundra2501 is on a distinguished road.
Send a message via AIM to tundra2501
Default Re: Wheel hub bearing problem
I believe the front ones are gonna have to be pressed on by a shop, not to sure about the rear. Sure another member will chime in.
2001 Toyota Tundra: RCD 6inch lift, Total Chaos steering bushings, Clear Corners, Rhino lining, Mickey Thompson rims w/ 35inch Dean SXT's, Flowmaster, Boston Pros front and rear, Q-Logic sub box with 2 JLW3v2's, JL Stealth Box.
Old 02-23-2007, 01:00 PM
Dealer : Fremont Toyota Scion
2002 Toyota Tundra
rlehan's Photo Albums
Last Online: Today 01:17 PM
rlehan is on a distinguished road.
The front bearings are definitely pressed into the spindle. It took over 20 tons of pressure to remove my bearings. Sometimes the spindle breaks when attempting to press out the bearings, even if everything is done correctly. If you don't have the proper equipment you should definitely have it done by a professional. I don't know about the rear bearings.
Rick
Black 2002 Limited 4x4
Mods: TRD Supercharger, Boost Guage, Unichip, Clifford AvantGuard 4 Alarm/Remote Start system, Auto Dimming mirror w/compass & temp, Sequoia Power Antenna, Retrax bed cover, Donahoe long travel coilovers, Total Chaos Uniball UCA, Helo Black Maxx 6 wheels w/ 265/70R 16 Michelin LTX/MS tires, Ivan Stewart front bumper cover, TRD headers, TRD dual exhaust, factory LSD, Total Chaos urethane steering rack bushings, Wheelers urethane front swaybar bushings, Helwig rear antisway bar, Goodyear Gatorback serpentine belt, Fumoto engine oil drain valve,Denso IK22 Iridum spark plugs, Eclipse AVN2454 AM/FM/CD/DVD/Navigation system w/ color backup camera, SilverStar headlights and fog lights, WeatherTec in-channel wind/rain deflectors, Ventshade door sill protectors, Toyota hood protector, TracRac sliding rack system with cantilever extension, IPOD integrated with Eclipse AVN2454, PopnLock electric tailgate lock, Sequoia electric condenser fan, Viair 440P portable compressor, ORS manual hub conversion w/Aisin hubs, StubbsWelding SKO rock sliders, 60" hi-lift extreme jack with slider adapter, Odyssey PC1700MJT battery
Coming hopefully - Warn 9.5ti multi-mount transportable winch, ARB lockers front and rear, 4.30 gears
Old 02-23-2007, 03:45 PM
Thanks for the info. Took them over to the local NAPA along with the front and rear shafts. Had to buy two more lower ball joints too. I mangled them pretty bad getting the spindle loose.
'01 Tundra SR5 4x4 TRD Equipped Access Cab. This truck is currently being rusurrected for company use.
Old 02-23-2007, 03:48 PM
2002 Toyota Tundra
You should have just removed the 4 bolts holding the spindle to the lower control arms. You don't need to do anything with the lower ball joints.
Rick
Old 02-24-2007, 12:57 AM
editmars's Avatar
Dealer : Toyota of Santa Cruz
editmars's Photo Albums
Last Online: 11-19-2008 08:53 PM
editmars is on a distinguished road.
In the monring Ill show you guys some pics of what happens when you try to drive without the axles in the bearing...
Old 02-27-2007, 04:27 PM
Rick
I found that out the hard way. But the problem is is somehow whoever put the lower ball joints in the last time, rounded the shoulders off 6 of the 8 bolts for both sides. They had to be drilled out by the machine shop. As for the bearings, the right side had actually started to fail and pretty much seized up inside the knuckle. You guessed it, the knuckle is ruined. So now I have one coming from Ft Worth. The driver side came apart and went back together perfectly.
Old 02-27-2007, 04:33 PM
2002 Toyota Tundra
Those bearings can be really tough to press out. It's not suprising that one of the knuckles was ruined. When you put it back together remember to put some blue loctite on the four bolts for the lower control arms. You don't want those to come loose later on while you are driving.
Rick
Similar Threads for: Wheel hub bearing problem
Driveline vibration. nhparrot Engine & Drivetrain 4 01-14-2008 01:13 PM
Question About Wheel Spacers mpdcoper Tires and Wheels 23 01-11-2008 01:06 AM
First problem with new Tundra Dr. T 1Gen-Tundra 25 10-03-2006 11:58 PM
Problem With Wheel Lug Bolts and Spare Tire Carrier Picasso Land Cruiser 5 07-04-2005 01:14 PM
Wheel problem someone please help! uracowman Tires and Wheels 7 07-18-2004 11:21 PM
