This is a discussion thread titled "Protecting front Coilovers from road salt", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
I just received my Sway-a-way front coilovers for my 06' Tundra DC and have a big concern - road salt here in Chicago. I tried searching the forums for suggestions and other than removing them in the winter or smearing them with Green grease, does anyone have any other suggestions to keep the road salt from coroding these things? I called Race Runner and they said road salt WILL corode them and suggested just spraying them down with WD-40. I know that will last about a week.
They look awesome.... Can't wait to get them on.
I am pairing these up with the Camburg UCA's and a 1" differential drop.
Well, I'm kind of surprised no one here was able to come up with this, but I found something that I believe will work in protecting the front coil overs from winter road salt:
2003 Tundra Imperial Jade TRD offroad Performance modifications
2.5 Camburg C/O w/ King 14" 600lb springs, Skidrow Automotive Skidplate
285x75x16 Goodyear Wrangler ATS, 16x8 Ivan Stewart Wheels
4.30 ring and pinion gears, Stock exhaust w/ Magnaflow 18" muffler, TrueFlow filter, Superlift TruSpeed Cosmetic modifications
Debadged, De-decaled and De-labeled sun visors
Pace Edwards Retractable Cover, Toyota Sport Grille
TRD radiator cap, TRD oil cap
RS 3200 Plus Upgrade Modification wishlist
TRD or JBA titanium headers
JBA or possible custom y-pipe
TRD supercharger
IPT valve body mod
Custom Offroad Bumper
Demello offroad sliders
rear disc conversion
Moonroof and power sliding rear window
Where does it ever end
you would not believe the tenacity of saltwater. bags are a great first line of defense, that and boeshield on the exposed threads and grease under the threads will keep them adjustable.
the corrosion on the exposed threads doesn't really matter, it's electrolytic corrosion between the steel body and aluminum collar that causes so much trouble. keep that full of grease and put a bead of RTV above the adjusting collar to keep saltwater from penetrating down between the threaded interface and ignore the rest.
I take mine off for the winter. I will try to find something to protect them next winter when I leave them on. Another problem you'll run into is the aftermarket control arms. The uniball joint is unprotected as well and will create problems when sand and salt get between the ball and socket. Keep that in mind also. This is why I don't have aftermaket UCA's on my truck.
2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 Revos on Wheeler's black alloys, True Flow intake tube and filter with a modded air box, JBA titanium coated headers, Aero 2525 muffler with stainless steel pipes and resonator removed, Skidrow front skidplate, EBC "green" brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Wheeler's polyurathane front swaybar bushing kit,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Silverstar fog light bulbs, , Viair 300P air compressor
Wish list: Line X'd front and rear bumper, rock sliders
I have the dirtbagz also. Only problem with them is, when you secure them tightly and dirt/sand accumulates between the bag and the coil. And will start to rub the paint of the coils like fine sandpaper. Had mine on for a few desert trips and when I got back decided to pressure wash my suspension. At that point I noticed the paint from the coils had rubbed off onto my dirtbagz.
I also sprayed my coilovers with triflo every other week, it didnt help protect them from corrosion. The shafts are pitted and rusting, and also the threaded body is rusting. Not much you can do. Thats why they are named Rust-A-Ways.
Makes me wonder if it's really worth putting the aftermarket high $$ parts on if they are just going to rust off. Is this stuff designed for desert use areas only or what??
O.K. now that I vented, I am still looking into this. I am now looking into manufacturers that make rubber boots - industrail and automotive applications. It appears that you can get boots made to just about any size and specification. The only question now is what they cost and if I can find some that are off the shelf.
I am going to find something for this and when I do I'll post it....
