This is a discussion thread titled "Highway shudder over bumps", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-05-2007, 08:56 AM
KBT KBT is offline
Dealer : Tri County Toyota
2004 Toyota Tundra
KBT's Photo Albums
Last Online: 06-26-2007 04:19 PM
KBT is on a distinguished road.
Question Highway shudder over bumps
2004 DC w 39k miles. Bought used at 33K about six months ago. When traveling on the highway and hitting expansion joints or other road "bumps" the truck seems to shudder...Not necesssarily vibrate. It seems like the front wheels shudder left to right for second and the rest of the truck seems to follow. Not having a truck before, I've been thinking that this is attributed to being a truck and not a car.
I rotated the tires at 38K and noticed the front tires are starting to cup.
I have not received the ball-joint recall, but my VIN is listed.
I want to go to the dealer and am trying to educate myself about possible reasons for the cupping and shuddering. The truck is in the Certified program, but the 3 months warranty is up, as is the 3 year/36K. The powertrain warranty is still in affect.
Question: Any ideas on what to look for/discuss with the Stealer?
Old 03-05-2007, 09:33 AM
DJ DJ is offline
Dealer : Fowler Toyota
2001 Toyota Sequoia,
DJ's Photo Albums
DJ will become famous soon enough.
Default Re: Highway shudder over bumps
Likely it needs a wheel alignment. The cupping wear is a dead give-away, but there is more than meets the eye.
When front wheel alignment is off, especially in "total toe", the wheels of the front axle don't necessarily try to roll the same direction. For example, if the left front wheel is pointed a bit to the right, and the right front wheel is pointed a bit to the left, then the two wheels fight each other. They actually scrub sideways a bit as the vehicle rolls straight ahead.
Now suppose the right front wheel hits a slight bump, which knocks it upwards a bit, thereby reducing its friction with the road. The left front wheel then exerts more force to the right than the right front wheel exerts to the left, and so the vehicle lurches to the right a bit. This can happen repeatedly as the bumped wheel bounces, and so the vehicle shudders.
If it were my truck, I would check wheel alignment first.
Old 03-05-2007, 01:00 PM
KBT KBT is offline
2004 Toyota Tundra
KBT's Photo Albums
Thanks for the quick response! I made an appointment with the dealer and have asked for them to use the alignment specs posted. The dealer said they would...as long as they are within Toyota specs.
Old 03-05-2007, 05:26 PM
DJ DJ is offline
DJ's Photo Albums
That's the idea.
Begin with Toyota's specs for your vehicle. Set camber and caster dead on Toyota's recommended settings and set caster right at the upper end of the range Toyota's specs for your vehicle allows. These are within Toyota's limits for your vehicle and will provide the maximum steering stability those specs can provide.
Similar Threads for: Highway shudder over bumps
Poor highway mileage/overactive cruise control TripleTrouble 1Gen-Tundra 6 01-03-2007 10:27 PM
Tranny Shudder on downshift?? Dropthechalupa 1Gen-Tundra 7 11-01-2006 05:57 PM
Would like to gain more control on the highway K-man 1Gen-Tundra 11 03-12-2006 10:19 PM
What do you think of your Tundra's Ride Comfort?? Do you feel the small bumps?? Verndog 1Gen-Tundra 10 02-20-2006 02:02 PM
shudder 2nd to 3rd bugmenot 1Gen-Tundra 1 08-15-2005 11:12 AM
