Re: A few questions about the racerunner coilovers
they wont bolt up, the top mounting serfice is different. but yes u can make them work, get the total chaos upper coilover mount for the tundra. they will be soft on the tundra if you dont change the valving, also teh spring might not be heavy enough. depends on the coilover look and see wht the spring rate is.
 mods:
donahoes,camburg uppers,MT classic II's,BFG AT KO's 285 75 16, spintech sportsman street dumped,braided steel brake lines,powerslot rotors,energy suspension sterring rack bushings, 10 pack deavers, 2.5x8 sway aways with resi (rear).
