This is a discussion thread titled "Front end vibration....", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-19-2007, 02:22 AM
Dealer : Desert Toyota Scion Of Tucson
CoyoteAZ's Photo Albums
Last Online: 06-16-2008 01:31 AM
CoyoteAZ is on a distinguished road.
Default Front end vibration....
Got a bit of a weird issue going on with my truck... first off the specs:
01 Toyota Tundra AC
75,000 Miles
4x4
Non TRD Package
Recently, the truck has started a wicked vibration while slowing down. The thing is, it's not a vibration right and left (that can be felt in the brake pedal and the steering wheel).... It's an up/down vibration, to the point that if I pay attention, I can see the front end bouncing up and down as I come to a stop.
This is violent enough to shake the items in my glove box at times.
My thought is suspension/alignment related - in which case I have already ordered some Bilstine shocks and will be getting an alignment when it's installed.
However, Wanted to check with the collective and see if anyone else had other things to check out.
Old 03-19-2007, 11:35 AM
drewbush's Avatar
Dealer : Manhattan Beach Toyota
2001 Toyota Tundra,
2000 Toyota Camry
drewbush's Photo Albums
Last Online: 11-19-2008 08:57 PM
drewbush is on a distinguished road.
Default Re: Front end vibration....
You said it vibrates when braking? Make sure the rotors are not warped. Its very common on the early Tundras. Check the brake forum. Do you set the parking brake everytime you park? It will help adjust the rear brakes so the front do all the work when braking. If the rotors are warped, I would go with a set of aftermarket rotors. Nothing fancy. I actually got a set off of ebay for a $100/pair incl. shipping. I havent had a single problem in 20k miles and no noise.
Similar Threads for: Front end vibration....
Front End Vibration MNSequoia 1Gen-Sequoia 19 07-27-2008 09:56 PM
Dumb question: Front end mask for Tundra on a Sequoia forourspam 1Gen-Sequoia 1 07-27-2005 05:20 AM
Raise the Front End? shshlens Suspension & Axle 3 06-22-2005 11:04 AM
Front End Alignment Issues ? - 2002 Sequoia 2WD gnb Suspension & Axle 3 10-02-2004 01:33 PM
Raise front end? adamkn Suspension & Axle 15 05-31-2004 08:00 PM
