This is a discussion thread titled "Tundra Springs on the front of a Tacoma", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-31-2007, 06:02 PM
Dealer : Prime Toyota
2001 Toyota Tacoma
countrybunkin's Photo Albums
Last Online: 09-06-2007 12:18 PM
countrybunkin is on a distinguished road.
Default Tundra Springs on the front of a Tacoma
Is anyone using Tundra Springs with TRD shocks on the front of their gen1 Tacoma's? I've been told it provides a decent ride and 2" of lift.
Also, can someone explain the pros and cons of an add-a-leaf vs. a set of shackles for a rear lift?
Thanks.
Old 03-31-2007, 06:18 PM
Dealer : Kern Toyota
2003 Toyota Tundra 4.7 with duals
Jetes03tundra's Photo Albums
Last Online: 11-19-2008 01:27 AM
Jetes03tundra is on a distinguished road.
Send a message via AIM to Jetes03tundra
Default Re: Tundra Springs on the front of a Tacoma
you wont find the answer on TS. check out ttora and search as they have all the info you need. Yes you can and it gives about 1.5 to 2" of lift in the front. Its also a great way to support a aftermarket bumper.
2006 Chevy Silverado 4wd 5.3 4.10 gears
- Dual flowmaster 40's out back exiting at the sides
- Blackbear 89/93 octane tune (good for 25hp and its amazing, no more torque management)
- LT headers
14.41 @98mph
A REAL truck.
Old 04-03-2007, 06:05 PM
Dealer : Beaverton Toyota Scion
2000 Toyota 4Runner,
mrmojorisinphan's Photo Albums
Last Online: 05-01-2008 04:36 PM
mrmojorisinphan is on a distinguished road.
Thanks.
I put tundra springs and OME shocks (TRD shocks will work too) up front on my 00 4Runner, and it provided about 2" lift and a great ride on and off road. I would highly recommend this setup. If you want a ton of info on the front setup, search yotatech.
Old 04-03-2007, 06:39 PM
yeah, yotatech and ttora are pretty much the same guys. I believe what you want to do is use, 2wd trd tundra front coils, and you could use either the 2wd tundra shocks or the OME (old man emu) front shocks like the N91. But def. do a search on those two sites and you will find EVERYTHING.
- LT headers
14.41 @98mph
A REAL truck.
Old 04-03-2007, 08:04 PM
2001 Toyota Tacoma
Thanks for the help guys. I've been reading here TTORA and Yota tech for 2 weeks now. I wish there was just one option to lift, that way there the choice would be easy .
Old 04-05-2007, 10:29 PM
dcab03's Avatar
Dealer : Lakeside Toyota
2005 Toyota Sequoia
dcab03's Photo Albums
Last Online: 07-29-2008 10:51 PM
dcab03 is on a distinguished road.
Most people on the CT board advise against putting AAls on a Tacoma. I made shackles for the rear of my Tacoma but the only problem is getting the driveshaft lined back up to get rid of any driveline vibration. But once you get that right then you shouldn't have any problems with the shackle. Do you have a Double, xtra or regular cab?
1998 Chevy Tahoe
2005 Toyota Sequoia
1993 Acura Integra
1995 Ford F250
Old 04-06-2007, 10:34 PM
2001 Toyota Tacoma
Thumbs up Re: Tundra Springs on the front of a Tacoma
Doublecab.
Old 04-06-2007, 11:38 PM
CT? custom tacos? they wouldn't use an aal as they are mostly street queens. Shackles can be bad, if you haul anything as they will create a negative arch on your rear leaf springs. Shackles are great if you are off roading only, and an AAL and shackle combo works too!
- LT headers
14.41 @98mph
A REAL truck.
Similar Threads for: Tundra Springs on the front of a Tacoma
sporttrcuk.com reveiw the Tundra zzrguy Tundra 0 03-30-2007 09:35 PM
Tundra CrewMax Reveal - Remarks by Jim Lentz TS Support Toyota, Scion & Lexus News 0 01-07-2007 04:38 PM
Tundra Access Cab V6 vs. Tacoma Double Cab Intensity 1Gen-Tundra 21 09-10-2006 09:30 AM
Jim Press/Jim Lentz - 2007 Toyota Tundra Press Conference nhparrot Toyota, Scion & Lexus News 0 02-10-2006 11:28 AM
Tacoma, 4Runner, Tundra '05 V6 differences j4x4ar3 Tacoma 2 02-25-2005 08:41 PM
