in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
Tundra Forums
1Gen-Tundra
Suspension, Axles, Brakes
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Lifting
Kits, tire fitment, gear ratios, general discussion and advice on lifting your 1gen Tundra.
15.3K
5.4M
Nov 2, 2023
15.3K
5.4M
Nov 2, 2023
Lowering
Drop kits, air bags, general lowering discussions for your 1gen Tundra.
717
395K
Mar 20, 2023
717
395K
Mar 20, 2023
1Gen-Steering System & General Handling
Steering components, payload handling, swaybars, and other hardware. Please post alignment discussions under "Tire, Wheel, Alignment".
3.6K
1.8M
Aug 16, 2023
3.6K
1.8M
Aug 16, 2023
T-Case, Driveshaft, Diff, Axle, Hub
Hub, axle, CV boot & joint, driveshaft, differentials, transfer case. Maintenance, repairs, and upgrades. Everything from restoring rusted axle housings to installing manual hub kits or wheel lugs.
8.6K
5.5M
Jan 24, 2024
8.6K
5.5M
Jan 24, 2024
1Gen-Brakes
Brake maintenance, ABS, VSC, upgrades.
9.2K
6.7M
Dec 5, 2023
9.2K
6.7M
Dec 5, 2023
Filters
Show:
Loading…
1
1 of 28
Go to page
Go
28
D
Upper Control Arms
dwil4
Feb 6, 2024
2
164
Feb 8, 2024
by
cheapskate
E
Please respond so I can place parts order. Correcting “Tundra lean”
EricZ
Dec 23, 2023
9
616
Jan 11, 2024
by
EricZ
Inoperative speedometer after wheel bearing replacement--Solved
grw800
Dec 27, 2023
3
699
Jan 4, 2024
by
Trident39
E
Anyone confirm 6112’s & JBA UCA’s on 1st Gen with around 2” lift?
EricZ
Nov 30, 2023
0
116
Nov 30, 2023
by
EricZ
E
UCA’s finish durability on salted roads
EricZ
Nov 25, 2023
3
388
Nov 29, 2023
by
marksebek
E
Please spec front spring rates and new rear leaf packs for 2.5” to 3” lift
EricZ
Oct 29, 2023
3
466
Oct 30, 2023
by
because_v8
Z
2006 AC V8 2WD - time for suspension refresh?
zzyzx85_714
Oct 10, 2023
8
780
Oct 18, 2023
by
zzyzx85_714
Sponsored
Front Brake Reviews and Recommendations
06Tundra208
Sep 29, 2023
3
665
Oct 4, 2023
by
TomsCigars
K
Height control compressor not kicking on
Kedmon
Sep 7, 2022
1
1K
Aug 15, 2023
by
Tundra Enthusiast
Dent in my LCA crossmember
CrewmaxMike
Jul 22, 2023
0
566
Jul 22, 2023
by
CrewmaxMike
P
Sway bar link part number
Pucks18
Jul 1, 2023
23
2K
Jul 11, 2023
by
fraukzsent
Catastrophic ball joint failure
Tundramedic20
Jun 19, 2023
9
2K
Jul 11, 2023
by
Tundramedic20
A
Nightmare leaks?
Americollin
Jun 6, 2023
3
844
Jun 6, 2023
by
Professional Hand Model
HD leaf springs opinion after putting weight in
plys
Apr 30, 2023
4
1K
Apr 30, 2023
by
plys
N
Grease cast-off around CV joint, Boot not damaged. What should I do?
NW Tundra
Dec 20, 2022
12
3K
Apr 24, 2023
by
lowyoda
Creaking front end
JQ3
Feb 18, 2004
14
13K
Apr 4, 2023
by
neumannbruce
N
2004 Tundra Suspension Replacements
ndknoy
Jan 1, 2022
9
3K
Mar 30, 2023
by
Davido49
Rear brake Proportioning Valve
BroHon
Jan 26, 2023
1
984
Jan 26, 2023
by
Mr.Bee
2000 Tundra Rubber Body Mounts
RyGuy72
Mar 27, 2022
11
3K
Jan 18, 2023
by
BDiefAZ
W
Drive shaft coupler movement.
Wild duk
Jan 9, 2023
10
2K
Jan 14, 2023
by
BroHon
J
Leaf Springs question
JKLedbetter
Dec 21, 2022
0
757
Dec 21, 2022
by
JKLedbetter
Hard brake pedal with high revving motor
Oldhead
Nov 4, 2022
1
1K
Nov 7, 2022
by
BroHon
T
1st Gen Ride Quality: How to Improve the ride quality
tariqansari
Oct 19, 2022
10
4K
Oct 26, 2022
by
Chappy R
E
Realistically how hard are 1st Gen UCA’s to remove?
EricZ
Oct 25, 2022
3
1K
Oct 25, 2022
by
festerw
Welding front knuckle
Gasman675
Oct 1, 2022
2
1K
Oct 3, 2022
by
Gasman675
Engine noise filtering through torn steering shaft boot?
Leathernuts
Mar 26, 2006
4
5
6
149
103K
Sep 18, 2022
by
MasterB
Suspension clunk
makethedrop
Oct 13, 2021
4
2K
Aug 31, 2022
by
BDiefAZ
C
Abs axle shaft vs non abs axle
crownapper
Aug 28, 2022
0
808
Aug 28, 2022
by
crownapper
T
2002 Tundra V8 Front Struts and Shocks.
tariqansari
Nov 23, 2019
3
5K
Aug 26, 2022
by
tariqansari
E
Am I overthinking this? What shape are stock Tundra front sway bar link bushings? Cylindrical or tapered?
EricZ
Jul 31, 2022
4
2K
Aug 1, 2022
by
RUSTYNUTS
E
Lucas Green HD grease out of stock everywhere? What is compatible?
EricZ
Jul 31, 2022
3
2K
Aug 1, 2022
by
2007 tundra 6inch lift
831Luke
Jul 7, 2022
0
715
Jul 7, 2022
by
831Luke
R
SPC ball joint worn out, NO WARRANTY
rusterfarian
Apr 6, 2022
3
3K
May 17, 2022
by
Chappy R
2WD/4WD Front Strut Interchangeability
JacobBosarge
Apr 29, 2022
0
901
Apr 29, 2022
by
JacobBosarge
KYB front new struts
RyGuy72
Feb 22, 2022
2
2K
Apr 14, 2022
by
RyGuy72
1
1 of 28
Go to page
Go
28
45.6K
posts
23.7M
views
Stock and modified suspension, lifts, lowering kits, handling improvements, CV joints, axle and driveshaft maintenance, repairs, and upgrades.
Show Less
Join Community
Grow Your Business
Forum Staff
View All
cheapskate
Super Moderator
Remmy700P
Super Moderator
Admin
Administrator
Recommended Communities
AVS Forum
1M+ members
Toyota Land Cruiser
240+ members
2024+ Toyota Tacoma Forum
1K+ members
Home
Forums
Tundra Forums
1Gen-Tundra
