4 wheel drive problem please help!!!!!!
+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Like Tree6Likes
Thread: 4 wheel drive problem please help!!!!!!
  1. #1
    Join Date
    Dec 2008
    Location
    KAnsas City KS
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default 4 wheel drive problem please help!!!!!!
    I have a 2003 Tundra. When I try to put it in 4 high (or 4 low for that matter). All that happens when I push the button is the 4 wheel drive light just blinks and it does not go into 4 wheel drive. I have tried stopping completely, putting in park, turning truck on and off. Nothing works. I need help winter will be here soon
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supercharged Member RONE's Avatar
    Join Date
    May 2007
    Location
    Merriam, KS
    Posts
    2,533
    Liked
    53 times
    Rep Power
    6465
    Default Re: 4 wheel drive problem please help!!!!!!
    Do you have instructions on your sun visor explaining how to engage 4wd? Do exactly as those instructions specify.
  4. #3
    Join Date
    Dec 2008
    Location
    portapique
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    we are having the same problem, toyota tech worked around 8 hours and didn' t have any answers. There seems to be no power to the actuator on the front diff. wondering where its power supply comes from and what else to check. Thanks
  5. #4
    Veteran Member Boosted27606's Avatar
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    1,071
    Liked
    6 times
    Images
    12
    Rep Power
    1045
    Just a guess here, but most 4X4 are used in 2 wheel drive 99% of the time. A good preventive idea is to activate the 4X4 button every 2 or 3 weeks so that the system gets a work out to keep it in shape. If you haven't activated the 4X4 system in a year or more, maybe the actuator is stuck or something is clogged up in mud.............
    Enjoying the awesome 5.7 L engine
    TRD rear Sway Bar, Billet Grille, Heated Seats, Westin Bull Bar and Skid Plate, HELLA driving Lights, Chrome handles and mirrors,
  6. #5
    Supporter nytrousboy's Avatar
    Join Date
    Jul 2006
    Location
    Tucson, AZ
    Age
    45
    Posts
    270
    Liked
    5 times
    Images
    46
    Rep Power
    78
    i had the same problem and replaced the front actuator per the dealer at $450.00 and that worked for about 2 weeks until it started again...
    the dealer could not find the problem and said the transfercase actuator might be it.
    i then was going to replace the transfercase actuator until i found out the actuator was $1050.00 and required the transfer case to be removed and pulled apart at 12 hr labor for a grand total of $3500.00.
    i took my tundra home and found a simple fix for mine, you can try this with yours it takes 15 mins.
    i took the transfercase actuator cover off (3 bolts a vacuum line, and connector) and the actuator some how got water in it, looked like a bad o-ring to me, the contacts were rusted and not conducting power so i took 800 grit sandpaper and sanded the rust off, put some Dielectric grease on the contacts, and some black rtv on the cover.
    i have had no problems with it after that.
    also the front diff actuator is very similar (4 screws hold the cover on) the same fix can be done with this one as well..
    i have some pic of the cover before and after.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	37093   Click image for larger version.
    wytoyota and rayfromray like this.
    2004 Tundra stepside.
    6" RCD lift, Camburg UCA, 4:56 front & rear, arb air locker, arb Sahara bar with 12000 bulldog winch, custom exhaust, 315/75r/16 km2 mt's
    stubbs sliders, ARE shell, ORS Hub kit.:rockon:
  7. #6
    Veteran Member tundrainorange's Avatar
    Join Date
    Apr 2006
    Location
    orange, ca
    Posts
    919
    Liked
    0 times
    Images
    9
    Rep Power
    1158
    Like was said before, engage the 4wd atleast once a month to keep it lubed properly. I engage mine once i pull out of my driveway, and drive it down my street...and no i don't turn street corners with it engaged...atleast try not to
    If the light blinks, try creeping forward a tad. Then push the button again.
    2005 DC TUNDRA TRD LMT. 4x4
    Better ask sombody.
  8. #7
    Leader of Group Evil DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    11,134
    Liked
    747 times
    Images
    22
    Rep Power
    14113
    If the vacuum lines are damaged, in addition to not engaging, the systems will rust from the inside out...lost the ADD actuator on the front diff that way, it was garbage in side.
    Hit the 4HI button once in a while, to keep the system lubricated...even if that means driving slow in a straight line on a dry road for a ways, hitting the button over and over just to cycle the system.
    GFX by FreedomEagle50
    1-Gen Tundra Offroad Technical FAQ Index
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
  9. #8
    Join Date
    Dec 2008
    Location
    KAnsas City KS
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Where is the front diff acuator located?
  10. #9
    Join Date
    Jul 2006
    Location
    Tucson, AZ
    Age
    45
    Posts
    270
    Liked
    5 times
    Images
    46
    Rep Power
    78
    here is a picture http://pictures.topspeed.com/IMG/cro...-10_380x0w.jpg
    dont forget to check the transfercase actuator as well, that is what caused my 4x4 light blink and not enguage, do not remove the whole actuator just the motor cover.
    Texas Tundra15 likes this.
  11. #10
    Join Date
    Dec 2008
    Location
    Detroit, mi
    Posts
    2
    Liked
    1 times
    Rep Power
    0
    I know this is going to sound lame but my brother in law works the service counter at a toyota dealership and he said they see this problem quite a bit. Their fix is to engage the 4 hi button in park, then when the light starts flashing put the truck in reverse on dry pavement and cut the wheel all the way to the right or left while backing out slowly.
    It fixed my problem. He said for some reason if you do not use your 4 wheel drive regularly that the grease migrates in the mechanism (or something like that). Anyway it was a superquick easy fix for me and after trying to figure this out for about a month of crawling under my truck and tapping the ADD, I am happy to have this behind me.
  12. #11
    Join Date
    Feb 2007
    Location
    FARM
    Posts
    22
    Liked
    0 times
    Rep Power
    9
    ANyone ever hear a ratcheting sound when trying to engage while moving? That's what I get.
  13. #12
    Rookie ames's Avatar
    Join Date
    Apr 2003
    Location
    South Georgia
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    I had the same problem with my 2003 4x4. I followed the directions above
    " took the transfercase actuator cover off (3 bolts a vacuum line, and connector) and the actuator some how got water in it, looked like a bad o-ring to me, the contacts were rusted and not conducting power so i took 800 grit sandpaper and sanded the rust off, put some Dielectric grease on the contacts, and some black rtv on the cover.
    also the front diff actuator is very similar (4 screws hold the cover on) the same fix can be done with this one as well.."
    Cleaned the front AND rear actuator and it worked perfectly. The front one is a little more complicated you will need a 14-16 inch phillips head screwdriver. within the FRONT actuator is a small electrical motor and a drill that turns some gears. the electrical motor in mine was jammed up and the screw was rusted. I removed the motor cleaned and used the dremmel to clean the screw. Works like a champ. Actually works better than it has in 3-4 years.
  14. #13
    Rookie harlanboy's Avatar
    Join Date
    Mar 2010
    Location
    breckenridge
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    did you find your noise problem? my 2003 4 wheel drive will not engage. when it's in 2 wheel drive it makes a grinding noise up in the front diff., when i put it in 4 wheel drive it stops, but it will not kick into 4 wheel drive (light blinks). I wasn't driving when this started happening. my friend said it just wouldn't go into 4 wheel drive for him, and now i am having these problems. I will try this fix.
  15. #14
    Join Date
    Dec 2006
    Location
    Ontario
    Posts
    28
    Liked
    0 times
    Rep Power
    19
    Quote Originally Posted by keiton View Post
    I can't hardly believe it. This fix just worked for me!!
  16. #15
    Join Date
    Feb 2007
    Location
    Peoples Republic of NJ
    Posts
    32
    Liked
    0 times
    Rep Power
    9
    Mine worked fine last Winter, but I tested it after this evening's oil change and got the flashing 4hi light. I found this thread by searching "4hi blink" and started into the various ideas listed here.
    Tried reversing w/ the steering hard over left, then again to the right, no effect.
    Tried tapping both the front diff and transfer case actuator housings w/ a plastic dead-blow hammer, no effect.
    I removed the vacuum hose from the transfer case actuator nipple and it was dry-cracked badly, no way it was sealing. Trimmed 1/2" off the end of the hose to get nice clean rubber, put it back on the actuator nipple, and blammo 4hi was back in service. 4-lo was a different story, wouldn't engage the first try...just blinked 4-lo a few times and then went back to 4hi. 2nd try it engaged with an abnormally-loud audible "clunk" and worked. I drove it a few yards, disengaged it and 4hi, drove ~2 miles, then repeated. 4hi again no problem, 4-lo engaged much more quietly. Disengaged, drove back to the house, repeated 4hi and 4-lo and it was back to a nice normal click during engagement. I hadn't used 4-lo in over a year, possibly two years, so it may have just needed some motion to get the gear lube into the right places.
    Previous transfer case fill was Mobil-1 75W-90 w/ premixed Limited Slip additive and my box didn't like it a bit. Engagement of 4hi was fine, but disengagement had a loud clunk at any speed over ~1mph. I just refilled with Coastal 75W-90 synthetic blend, no Limited Slip additive, and disengagement is back to normal click now. I'm supposing that the friction modifier LS additive is a no-go.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
