GEAR OIL GL4 or GL5
+ Reply to Thread
Results 1 to 7 of 7
Thread: GEAR OIL GL4 or GL5
  1. #1
    ab
    ab is offline
    Supporter ab's Avatar
    Join Date
    Feb 2003
    Location
    Vancouver Island
    Age
    46
    Posts
    304
    Liked
    3 times
    Images
    5
    Rep Power
    19
    Default GEAR OIL GL4 or GL5
    I am trying to figure out of I can use GL5 gear oil where GL4 is the spec. Does the 5 indicate that it supercedes the 4 and can be used instead or are they only for specific applications? PS thanks KLS for you "GL link" in another thread, but it still isn't clear to me that 5 can be used inplace of 4.
    [SIZE="1"]00 TUNDRA V8 AC LTD / 03 SEQ LTD / 05 TUNDRA V6 Longbed (2) / 06 TUNDRA DC / 07 TACO DC / 93 Mr2 Turbo / 87 MR2
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    KLS
    KLS is offline
    Supercharged Member KLS's Avatar
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,492
    Liked
    4 times
    Rep Power
    17
    GL-5 gear oils are for gears like our differentials where the pinion is below the centerline of the ring gear. You can look at the outside of the differential housing on the front side and see that. There is much sliding on the gear teeth, and the oil has to be blended for that. These are called hypoid gears. A gearbox without hypoid gears, like a transmission, does not need this particular additive package in the oil. GL-4 gear oil works well. Some GL-5 oils used a sulfur based additive to make them GL-5, and the sulfur would damage yellow metals...brass, bronze, & copper...in the transmission. Many modern GL-5 gear oils do not have the sulfur in them and are labeled for both GL-4 and GL-5 applications.
    Ken
    You get what you inspect
    Not what you expect.
    Gibson exhaust system
    Hellwig Rear Antisway Bar
  4. #3
    ab
    ab is offline
    Join Date
    Feb 2003
    Location
    Vancouver Island
    Age
    46
    Posts
    304
    Liked
    3 times
    Images
    5
    Rep Power
    19
    Thread Starter
    Default Gl 4
    Went to the dealer and bought "their" GL4 gear oil for $30 CDN a litre!!! It was totally clear, no color, and after replacing the wrong GL5 with the proper GL4 the whine disappeared. Dealer says that they have seen GL5 wreck those manny trannies.
    Thanks, Ken.
  5. #4
    Junior Member BuckTales's Avatar
    Join Date
    Dec 2004
    Location
    Odenton, MD
    Posts
    106
    Liked
    0 times
    Rep Power
    11
    I am looking to change my differential fluids and replace them with Mobil 1. I know that I need 75w-90 for the front diff. However, it looks like I need 90w for the rear. I can't seem to find this stuff anywhere. Where is a good place to look?
    Also, according the the "Fluids" info page on TS, the transfer case is 75w-90 and GL-4 -OR- GL-5 - which is suggested?
    BuckTales
    2000 Tundra SR5 Access Cab
  6. #5
    KLS
    KLS is offline
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,492
    Liked
    4 times
    Rep Power
    17
    We are having very good results with synthetic 75W-90 gear oil in the rear differentials. Mobil 1 75W-90 works well in both differentials and the transfer case.
    GL-4 gear oil is used only in certain manual shift transmissions these days.
    Ken
  7. #6
    Join Date
    Dec 2004
    Location
    Odenton, MD
    Posts
    106
    Liked
    0 times
    Rep Power
    11
    Quote Originally Posted by KLS
    Ken
    Ken -
    Thank you. I'm happy I can buy all 75w-90 now. I haven't seen it in containers anything higher than single quarts. I'm going to look around for the best prices now. I have a Salvo, AutoZone, and Advanced Auto Parts all near me.
    BuckTales
  8. #7
    Join Date
    Jul 2004
    Location
    Kona, Hawaii
    Age
    29
    Posts
    194
    Liked
    0 times
    Rep Power
    11
    I just replaced the rear diff fluid this past weekend with the mobil 1 syn 75w90. Its certainly not cheap, at the only place that carries it, it was 12 bucks a quart. I know you can order it online too but by the time i pay shipping its only a couple bucks cheaper.
    The fill bolt was a pain to get out, i started rounding off the run so i had to move down to a 15/16 socket and was able break it free. The bottom wasnt as much of a problem. Mine only took about 3.5 quarts till it was oozing out the fill hole and although i jacked up the driver side i might not have done it high enough. Mine is a 2000 so i dont have an LSD.
    Everything Under The Sun Is Eclipsed By The Moon, But The Sun Is Eclipsed By The Moon- Roger Waters
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. synthetic oils - yes or no?
    By nhparrot in forum Engine, Intake, Exhaust, Induction
    Last Post: 06-10-2010, 03:43 PM
  2. Oil Filter Change/Fumoto Oil Drain Valve
    Last Post: 06-07-2009, 04:15 PM
  3. Another Gear Oil Question - '05 2wd LSD
    By rakent in forum T-Case, Driveshaft, Diff, Axle, Hub
    Last Post: 01-29-2008, 02:33 PM
  4. Which BRAND of OIL?
    Last Post: 10-29-2007, 10:43 AM
  5. GEORGE! or anyone else..Whats The Best "DINO" Oil
    Last Post: 03-28-2002, 01:21 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
