Right Rear Axle Seal Leaking. Need Some Help
+ Reply to Thread
Results 1 to 6 of 6
Thread: Right Rear Axle Seal Leaking. Need Some Help
  1. #1
    Join Date
    Jun 2004
    Location
    Ankeny, IA
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Default Right Rear Axle Seal Leaking. Need Some Help
    Hello need some help here. After reviewing some other posts, about their rear axle seals leaking, finally found out that is what is wrong with my 01 Tundra. Just got done reading T.S.B. on rear axle seals.
    I was wondering since just the right one is leaking, should I only get that one replaced on both of them. It appears that their could be something wrong with the original seals, or should I just get the right one repaired, and hope the left side doesn't start leaking.
    2nd Question is: Will I need to get new brakes on the rear since it appears the axle grease has been leaking along time, and just noticed the leak seeping through on the front side of my wheel.
    Does the dealer need to do this repair since the T.S.B. mentions a special Toyota Tool to insert the new seal without damaging it, or can I have a different shop repair.
    How much does a Toyota Dealer charge for this type of repair. Very nervous about the cost of this repair with a possible brake job. Any help would be appreciated.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jun 2005
    Location
    Everett WA
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    I'm not sure about the Tundra, but I have had problems on older trucks with plugged/malfunctioning vent/breather/check valve on rear axle.
    One seal leaked and there was sustantial pressure in differental when I drained oil. Opened up vent check valve and wheel seal leaks stopped.
  4. #3
    KLS
    KLS is offline
    Supercharged Member KLS's Avatar
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,492
    Liked
    4 times
    Rep Power
    17
    Be sure to have the shop check the axle for straightness. If it is not straight, the new seal won't hold for long.
    If gear oil is on the brakes, they must be renewed. I'd only fix the leaking seal, but do brakes on both sides. New shoes don't cost that much.
    Ask any good repair shop. They'll likely do a very good job for less than the dealership.
    Ken
    You get what you inspect
    Not what you expect.
    Gibson exhaust system
    Hellwig Rear Antisway Bar
  5. #4
    Join Date
    Mar 2005
    Location
    Jacksonville
    Posts
    16
    Liked
    1 times
    Rep Power
    0
    Default Rear seal leak
    I just did the one in my '02 Sequoia. There is a TSB on a up graded seal. Not a hard repair having drum brakes on Tundra. A little more difficult on Sequoia. Change brakes making sure that you get all the axle grease out of the brake area using brake cleaner and not air. I changed out both sides since there is a known problem.
    Quote Originally Posted by gas4man/servicman
  6. #5
    Rookie 13bmini's Avatar
    Join Date
    Aug 2003
    Location
    orange county
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    man thats why mine went out then. what happened to toyota, i thought they where good. this will be my last toyota for a very long time. the only good thing about it is i blew my rear end and got a new one that was regeared and it is awsome. now if the o2 sensor wasn't out every 4 months it would be cool.
  7. #6
    Veteran Member Mike Donofrio's Avatar
    Join Date
    Feb 2002
    Location
    Jersey
    Posts
    1,479
    Liked
    1 times
    Rep Power
    15
    I suppose warranty coverage is out of the question? Just clarifying.
    Heed what the other guys above have said, check out this thread and post up any questions.
    Rear oil seal leaking-repeated failure
    Basically once the seals go it precipitates other failures and they can be costly.
    -Brakes contaminated with oil HAVE TO be replaced. $25-$50
    -When the oil goes past the seal, it also contaminates the bearing, which must be repacked (and preferably replaced if it's sloppy) Bearing $50
    -A good shop can press the bearing without ruining the ABS ring (if so equipped) Dealer will charge you about $100 more per axle for this. But parts would be another $60 or so.
    -IMO, you should only fix the side that's bad, but that won't likely be what the dealer tells you.
    If you can get them replaced per the TSB do it. If not, be sure to use Toyota seals--they only have the post TSB version available now.
    If you are a DIY kind of guy, you can drive the seals with a seal driver from Harbor Freight ($14) and pull the old seal with a claw hammer. Take the axles to a shop and get them pressed like I did. If not, my advice would be to take it to a reputable independent shop. Expect Toyota to charge you about $800-$1000 or therabouts if they do both sides, inner and outer seals, brakes, and presswork.
    -Have a reputable shop check for axle run out with a dial indicator IN ANY CASE!!! Anything over 3/1000ths of runout and you'll need a new axle shaft ($300-400)
    Anyway, let me know if I can be of assistance. I was just on this for the past two weeks and I am just about 100% recovered...but a lot poorer.
    Mike D
    Lost traction? Lock it up!!! Front locker install instructions here: http://www.teddnet.com/LockRightInstall.pdf
    2000 Tundra with 175,000 miles and still going!
    Upgrades: PA 3" Body Lift, Powertrax No-Slip rear, Detroit ezLocker front, Fabtech/Fox front, Wheeler's AALs, TC Front Diff Drop, 16 x 8 MB Wheels, 285/75R16 Goodyear Wrangler MT/Rs, Pioneer Head Unit, Infiniti Reference speakers [front and rear], 150 W bridged amp to bandpass enclosure, 6 CD changer with IR remote, iPod mini and xm hardwired into stereo, Toyota drop in bedliner, and Tonneau cover
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. 01-04-2009, 06:37 PM
  1. Rear axle seal leaks caused by syn. gear oil
    By Dude Boy in forum T-Case, Driveshaft, Diff, Axle, Hub
    Last Post: 05-07-2013, 10:35 AM
  2. HELP!!!! Leaking rear axle - fixed 3 times, still leaking.
    By Francois in forum T-Case, Driveshaft, Diff, Axle, Hub
    Last Post: 08-27-2009, 10:58 PM
  3. Need help! Rear Axle Bearing & Seal
    By Mike Donofrio in forum T-Case, Driveshaft, Diff, Axle, Hub
    Last Post: 05-01-2009, 09:34 PM
  4. rear axle seal TSB READ THIS!
    By TRDKEAU in forum T-Case, Driveshaft, Diff, Axle, Hub
    Last Post: 03-03-2005, 06:32 PM
  5. Replies: 18
    Last Post: 01-06-2004, 09:06 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
