Free Shipping at Buy.com!
FREE Personal Trainer Program
Tires and Wheels Discussions and experienced advice about tires, wheels, traction control, proper balancing, improving tire life and more.
This is a discussion thread titled "wheel adapters installed, how much plastic did you have to cut?", within the Tires and Wheels forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-23-2007, 11:48 AM
Tundradrenalin's Avatar
My eBay Tundradrenalin's Photo Albums
Tundradrenalin is a splendid one to behold.Tundradrenalin is a splendid one to behold.Tundradrenalin is a splendid one to behold.
Question wheel adapters installed, how much plastic did you have to cut?
I installed the Goeske adapters to avoid rubbing so hard on the UCAs and the frame. That problem is gone now.
BUT, now I have a much louder rub, plastic and rubber. A real head turner.
The inner fender well of the bumper and the mudguard. I trimmed a lot of the plastic of the front fender, it doesn't rub on the small turns now. But it will rub I am certain, when I hit an incline while turned. If you installed an adapter as I did, how much did you trm/shave/grind away? Is it still visibly pleasing or does it look like you took a sawzall to it?
My truck is still in good shape, so I don't want to mangle it like my old '87 p'up. But I do want functional equipment. And rubbin one out on a U-turn, well, it sux. I've read about pinch weld mods, but I don't own or have the knowledge to use that equipment. I do have a nice pair of sheet metal shears that work great on thin to moderately thick plastic.
Recap. At the moment, the trimming is unseen from the side. The tires don't rub on the bumper wheel wells now, but it could still use some shaving. Suggestions on how much more to shave?
Thanks,
Andy
Searching for an answer to your Tundra or other Toyota question? search HERE! or HERE!
Got a question about TS.com site policy? click HERE!
What is Rep Power? read more HERE!
My Truck:
Old 06-23-2007, 05:37 PM
Default Re: wheel adapters installed, how much plastic did you have to cut?
Ok, so check out the pictures. I trimmed the plastic Fender Front (FF Left or FF Right). Both are about as even as I could tell by taking a picture and then doing the same thing on the other side.
The most odd thing is that the LEFT side has less room from the Front Fender to the tire than the RIGHT. You can see in the pics that it is about 1 finger, roughly 2cm.
The space from tire to Fender Rear on each well is the same, about 3 fingers. (nice measuring tool eh?
Is this some kind of caster problem?
or,
am I overreacting and should just trim some more plastic?
My Truck:
Old 06-23-2007, 05:47 PM
Cyberbilly's Avatar
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Cyberbilly's Photo Albums
Last Online: Today 02:36 PM
Location: Fredericksburg, VA. America's most historic city.
Cyberbilly will become famous soon enough.
Send a message via Yahoo to Cyberbilly
or,
What size wheels and tires are you running?
All a man really needs for happiness in this world is a good woman, a faithful dog, and a big-a$$ed set of tires on his truck.
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Scion T1808 Head Unit, Audiovox XM Express, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: Two Very Large Dogs
Featured Sites: Truckblog.com Cardomain.com RateMyRide.com Sport Truck.com Truck Trend.com
Old 06-23-2007, 05:58 PM
aiyo, in my sig
BFG A/T 285/75/16, factory alloy wheels, 1.5" wheel adapters from Goeske, lift set at about 1.25"
My Truck:
Old 06-23-2007, 07:44 PM
Cyberbilly's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
aiyo, in my sig
Hmmm....
I've got almost the same setup, but I've got about an inch more lift. Mine don't rub at all.
Old 06-24-2007, 10:01 AM
you don't hit the back of the well on the mudflap either?
I've got those large stock fender flares. They are really in the way of business.
My Truck:
Old 06-24-2007, 10:39 AM
Cyberbilly's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
I have no rubbing. Period. Zero. Zilch. Nada.
Old 06-24-2007, 10:52 AM
sometimes I hate being the only one.
Check out the pic, the mudflap rub. It's not a problem that will hurt anything, and the hard plastic has already started to burn away, so I might just leave it.
the mudflap rub: a gentle massage of one's mullet or a tire grazing the surface of a mud guard.
My Truck:
Old 06-24-2007, 11:25 AM
Cyberbilly's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
Don't know what to tell you, except mine is about an inch higher.
Linear Mode Linear Mode
