Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 09-10-2007, 10:24 PM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 32
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
Default Alternative to ARP extended wheel studs?
I plan on upgrading to longer wheel studs,so far my research found ARP part # 100-7715 being a direct fit. But at $35 for a set of five,multiplied by 5 (you'll have a spare) it's looking quite pricey
If I convert to SAE thread,7/16-20,the ARP studs in that size is less than a third the price of the metric ones ($10). I'd like to stay metric.
Has anyone found a more reasonable alternative (price-wise) to the ARPs? I found a Dorman replacment,but it's not that much longer than stock.
And the search continues...
Old 09-15-2007, 09:53 PM
Eddie's Avatar
Moderator
2000 Toyota Tundra,
Images: 32
Default Re: Alternative to ARP extended wheel studs?
I might have found something for $2.00 each. The company is Ichiba USA,they're known for their car wheel spacers (although they do offer 6-lug truck spacers too). It's a 50mm stud,emailed them to see if that's total length (threads + knurls) or just threads.
And some info on the Dormans. The front studs are 40mm and rears 45mm,both available locally for $1.99 and $1.29 (funny,the longer ones cost less). I'm not sure if that's thread length or total length though.
I should have measured the stock wheel studs when I inspected the brakes this week...doh! Rears are definitely longer than the fronts.
broken wheel studs tedrow Tires and Wheels 14 06-11-2005 12:12 PM
Alignment Setting Recommendations Alan Tires and Wheels 9 04-12-2003 08:15 AM
Trouble with wheel dealer whizzer Tires and Wheels 6 07-11-2002 01:24 PM
Worried about vibration when new tires are installed Al_G Tires and Wheels 21 05-15-2002 11:14 AM
DJ's Alignment Setting Recommendations nhparrot Knowledgebase Archive 0 04-10-2002 06:50 AM
