Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 03-17-2002, 07:18 PM
Last Online: 05-18-2003 11:37 PM
crashedtundra may have some regrets.
crashedtundra's Photo Albums
Default will these wheels fit the tundra?
www.eaglewheels.com/146
in the 6 on 5.5 pattern? thanks...
chris
Old 03-17-2002, 08:47 PM
Last Online: 10-19-2007 11:23 PM
Ghoti may have some regrets.
Ghoti's Photo Albums
Default Re: will these wheels fit the tundra?
Which size wheel? The offset needs to be +20mm, I believe. So the 15x8 or the 18x9's should work. Not sure... but yo uneed to stay near the factory offset.
Old 03-18-2002, 04:00 AM
Dealer : Kolosso Toyota
Last Online: 07-10-2009 11:10 PM
ra1nman may have some regrets.
ra1nman's Photo Albums
While i'm not sure on offset, but I think you need at least 4 5/8 backspacing or 4.625 to clear the calipers. I've herd 4.5 wont cut it and you'll need spacers.
Old 03-18-2002, 01:34 PM
Last Online: 09-04-2006 07:30 PM
OooWeee428 may have some regrets.
OooWeee428's Photo Albums
yeah those eagle alloys will fit. my friend has a green tudra with those wheels and it looks tight
Old 03-28-2002, 11:39 AM
Dealer : Hamer Toyota
1995 Toyota 4Runner LE,
- Other - 07 Eclipse GS
Last Online: 12-05-2008 12:24 AM
2DaMax may have some regrets.
Send a message via AIM to 2DaMax Send a message via Yahoo to 2DaMax 2DaMax's Photo Albums
I have the exact wheel on my Tundra, this is the spec that fit:
16 x 8, 6 on 5.5 bolt pattern, +2mm offset, 4 1/2 backspace"
Also, click on link below to see pic:
http://nerdcities.com/todamax2k/wheels.jpg
-Dennis
Old 03-28-2002, 12:06 PM
HockeyFreak's Avatar
Dealer : Leith Toyota
Last Online: 04-27-2009 07:06 AM
HockeyFreak may have some regrets.
Send a message via MSN to HockeyFreak HockeyFreak's Photo Albums
I have those wheels on my tundra also!!! I absolutely love them. Mine are the same specs as 2DaMax.
hockeyfreak
"If your not obsessing about something, you're probably not into it enough." - Chris Thile
2001 Tundra Limited *SOLD* :cry:
2005 Ford Excursion Limited PSD
1996 Ford F-250...Runnin' on Veggie Oil
1946 John Deere A
MODS: Hellwig, Custom Duals w/ Flowmaster 40 Series and Dr. Gas X-pipe, Daystar Bushings, Cornfed 2" Front Spacers, TRD AAL, K&N FIPK, 16x8 Weld Outbacks, 285/75R16 Yokohama Geolandar's, Access Cover, BedRug, Putco Bed Rails, PP Bull Bar, WeatherFlectors, Prodigy Brake Controller, Brown Bread Sound Deadener, '05 Taillights, AMSOIL ATF
Shawn
Southeast Region Forum
Old 03-28-2002, 12:07 PM
2002 Toyota Tundra
Last Online: 12-01-2008 12:45 AM
jkreese may have some regrets.
jkreese's Photo Albums
Yo 2DaMax!
Do you have the chrome or the polished? And, what is the difference? Finally, do you have a lift or spacers or...?
Thanks.
Ciao.
Old 03-28-2002, 12:19 PM
Although on the pic it looks chrome, it is actually polished. The truck was detailed the day I took the picture. The difference between chrome and polish is the looks and the price. It takes more work to maintain the chrome finish. It just depends on how much time you have to keep your wheels spotless and shiny.
I have Fabtech coilovers adjusted for 2.75" of lift.
Originally posted by jkreese
Yo 2DaMax!
Thanks.
Ciao.
-Dennis
Old 03-28-2002, 01:55 PM
2002 Toyota Tundra
So...do you need to have a lift to use those wheels, or can you use them with the "stock" suspension?
They look really nice!
Ciao.
Old 03-28-2002, 02:02 PM
jkreese,
I have my wheels mounted on the stock suspension with the OEM 265/70R16 BFG tires and have no problems.
hockeyfreak
1946 John Deere A
Shawn
Old 03-28-2002, 02:09 PM
2002 Toyota Tundra
By the way...those Eagle #146's (16X8) usually list for $176 (polished) and $227 (chrome) each. The Eagle website has a special for all 16" chrome wheels at $173 each. Shipping for a set of 4 is $55.
Ciao.
Old 03-28-2002, 02:36 PM
I got my polished 146's from discount tire for $110/ea. I got a special deal though. They screwed up my first set of wheels that I ordered so they said that he would sell me the 146's for their cost!
Note: I am on my second set of 146's, they couldn't get the first set to balance properly, but this second set is as smooth as glass and I couldn't be happier.
hockeyfreak
1946 John Deere A
Shawn
Old 03-28-2002, 02:58 PM
The only time you'd need a lift of some kind is if you are going for bigger tires. You can use this wheel with the stock tires and the only difference is that the tire's sidewall will be sticking out more.
Ciao.
-Dennis
Old 04-02-2002, 07:14 AM
jkreese,
I put the pic of my truck in the my photos section. Just look under tundra pics and look for "hockeyfreak's truck"
hf
1946 John Deere A
Shawn
