Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 12-21-2007, 10:49 PM
Dealer : New Country Toyota
2006 Toyota Tundra,
2007 Toyota Tundra Silver Ltd DC w/da w
Last Online: 11-30-2008 08:48 PM
SoCoCrush is on a distinguished road.
SoCoCrush's Photo Albums
Default Disengage Tire Pressure Light '06 DC Tundra
Disengage Tire Pressure Light '06 DC Tundra Got some winter rims/tire without a second set of sensors for my 06 Double Cab. How can I disengage or at least turn off the sensor light? Permanently is fine/preferred.
Thanks for your help,
W
Old 12-22-2007, 08:28 AM
Dealer : Glen Motors
Last Online: 03-30-2009 11:20 AM
giaved3322 is on a distinguished road.
giaved3322's Photo Albums
Default Re: Disengage Tire Pressure Light '06 DC Tundra
I have the same question concering an 07 Crew Max Tundra.
With a wiring diagram you probaly can find the wire going to the low pressure light in the dash. You could find a convient place to cut the wire and tie in a switch. You could mount the switch on or under that dash, whatever is easy. You only would have use the switch twice a year. In the summmer you could switch the TPS warning light on and in the winter, with your winter tires on, it would could be switched off.
Is there anyone out there with a wireing digram for an 06 & 07 Tundra or can describe how to located this wire?
Old 12-22-2007, 10:00 AM
I12BHIR's Avatar
Dealer : Koons Westminster Toyota
2006 Toyota Tundra dc ltd. 4wd
Last Online: Yesterday 09:35 PM
Images: 7
I12BHIR is on a distinguished road.
I12BHIR's Photo Albums
I have a 06' DC and what I did was remove the TPMS valves from your tires and put all of them in the spare tire. Now, I'll have no problem with stock or aftermarket rims and the light went out as soon as it was done.
There was a guy on here who found the wiring diagram to permanantly turn off the TPMS computer, but you would have to search for it. I'm not sure where he found it or what his name is.
thanks,
Rob
06 tundra DC 4wd ltd. 3" toytec spacer lift, truxedo bed cover, 285-70-17 nitto's, factory 17" wheels, 1.25" spidertrax adapters
Old 12-22-2007, 10:14 AM
I12BHIR's Avatar
Images: 7
Actually, I just found the post I was talking about. here you go....
The orginal postee was Bully5.
Re: Tire pressure sensor
Do a search for TPMS. I disabled mine on my 06 DC and have had no problems at all. Here's what I did, from another thread:
"My light started flashing too, after checking all 5 tires repeatedly and trying the reset & waiting 20 min. each time, it would not reset.
The TPMS computer is accessible without taking apart the radio and dash panels.
I took the glove box out (2 screws below glove box), removed the inner liner behind the glove box (3 screws) and if you look up towards the radio you can see the TPMS module, Toyota even labled it for us.
It is tight, but my hands are big and I was able to unplug the connector, cut the Pink wire w/silver bands and ground it to a nearby screw. Plug the connector back in to the TPMS module and guess what? - NO MORE F***ING flashing light!
It took me about 10 min. on my break at work after reading the previous posts. Thanks for the help, thought I would try to clarify and make it easier for the next person.
(note: there are 2 pink wires, both are pink w/silver bands, but one has a thin black stripe on it, this wire has 12 volts! Make sure you cut the pink without the stripe. Luckily I tested the 2 wires first with my meter, they both have voltage going through them. The wire you cut - pink w/silver bands - has about 8 volts but it caused no problems when I grounded it so that must occur in the TPMS module when it isn't malfunctioning?)"
Old 12-22-2007, 09:04 PM
2006 Toyota Tundra,
Love ya long time. That wasn't too bad. Couldn't get the plug out though but the wire sleeve was easy to open to take a peek as to which one to cut.
Thanks alot,
W
Old 12-26-2007, 12:12 PM
Dealer : Lithia Toyota of Springfield
Last Online: 09-03-2008 11:53 AM
Bully5 is on a distinguished road.
Bully5's Photo Albums
You're welcome
Old 01-15-2008, 02:13 PM
Cosmo459sx's Avatar
Dealer : Clearwater Toyota Scion
Last Online: 07-25-2009 07:48 PM
Cosmo459sx is on a distinguished road.
Cosmo459sx's Photo Albums
I assume that all of the sensors are located on the inside of the rim, so that they cannot be taken out unless the tire is removed from the rim, correct?
2006 black Toyota Tundra Access Cab SR5 with 6 speed manual. K&N drop-in filter, RF Power coaxials, upgraded hitch, cargo net, and wrap around tint.
Old 01-15-2008, 03:52 PM
I12BHIR's Avatar
Images: 7
Correct.... just take your truck to the tire shop. And tell them you want to take off the tpms so you can get rid of the wheels. (which you are not going to do) They do not have to dismount the wheels, just break the bead. Then but all (4) sensors in the spare tire. And light will go out as soon as it is inflated back up. That way if you every want them again they are there...
Hope this helps..
Old 01-19-2008, 06:44 PM
Last Online: 11-01-2008 12:23 PM
robk87 is on a distinguished road.
robk87's Photo Albums
Mine had an all pink and a pink with silver bands and black stripe. I guess I need to get my voltage tester fixed and test them both. Anyone else cut the wires and have a solid pink wire? by the way I also have an 06 but Reg. cab
Old 01-22-2008, 09:55 PM
phanham's Avatar
Dealer : J. Pauley Toyota Scion
Last Online: 09-12-2009 07:58 PM
phanham is on a distinguished road.
phanham's Photo Albums
Mine's been on so long now that I rarely notice anymore... Too cold to check the spare, I'll take my chances and do the "electric tape" mod (i.e. cover up the dash light) if it starts to ever bother me
2006 Tundra DC SR5 TRD 4x4. Pretty much stock besides the Extang Trifecta Tonneau, Hellwig sway bar, shorter antenna, & Kel-Tec in the console.
Old 01-23-2008, 07:25 PM
Banned
Dealer : Wesley Chapel Toyota
Last Online: 08-04-2008 08:49 AM
UrbanCowboy is on a distinguished road.
UrbanCowboy's Photo Albums
picture of the kids covering the light works every time! LOL
Old 09-11-2008, 07:41 PM
Nunya53's Avatar
Dealer : North Point Toyota Scion
Last Online: 10-02-2009 06:14 AM
Nunya53 is on a distinguished road.
Nunya53's Photo Albums
Dredging up an old thread...but that is what the search function is for, right?
Anyway, I pulled out the glove box and liner...there are a bunch of wires back there, but I didn't see anything labeled TPMS. Does anyone have pictures of the TMPS and wire bundle they could post? I need to disconnect mine.
Thanks,
Jerry
Old 09-12-2008, 12:46 PM
Dealer : Toyota of Huntington Beach
2002 Toyota Tundra
Last Online: 03-09-2009 01:31 PM
LilCuteSurferGrl is on a distinguished road.
Send a message via AIM to LilCuteSurferGrl LilCuteSurferGrl's Photo Albums
Just a little heads up... it's illegal for shops (or anyone in fact) to disable, or modify the TPMS system per FMVSS 138 and 49 U.S.C. 30122(b).
But if ya do it on your own, I won't tell anyone
MT II's / Hellwig Anti-Sway Bar / IS Kit without Bumper Cover / Yellow/Blue Bilsteins / 32" BFG All-Terrains / BedRug / Clear Corners / RF 10" Sub, Amp and Cap / Pioneer Premier Head Unit / Other Small Stuff and Mods
'02 Tundra
'04 Sequoia
'06 Tacoma 4x4
'07 Z71 Tahoe 4x4
And a 1450/7S Race Truck
Old 10-24-2008, 02:09 PM
pdmted's Avatar
Dealer : Carousel Toyota
2005 Toyota Tundra Crew Cab Limited,
- Other - Nissan 300ZX
Last Online: 09-24-2009 02:15 PM
pdmted is on a distinguished road.
pdmted's Photo Albums
I've done a lot of research on this issue and kind of surprised no one has asked this before.
Please keep in mind, I have not taken my truck appart yet so I may be misunderstanding something. If so, just tell me.
When I cut the wire, which side do I ground? The TPMS ECU end or the end that just goes into the harness?
Has anyone tried just running a jumper off of the wire without cutting it? I was thinking about just using a "trailer jumper" to tap off that wire to a ground (and possibly even get fancy and put a little toggle switch in the top of my glove box to disable/enable the system when I switch between my stock tires/wheels and my oversized tires.
2005 Tundra Crew Cab 4x4 Limited
Bilstein 5100's set to 2.5"
Spidertrax 1.25" Hub/Wheelcentric Adapters
06 Factory TRD 16" Wheels
ToyTec 1.5" Rear Blocks
ToyTec Diff Drop
BF Goodrich 285/75R16 AT's
Old 11-04-2008, 10:02 AM
Dealer : Valenti Toyota
2005 Toyota Tundra
Last Online: 09-20-2009 06:14 AM
dougg is on a distinguished road.
dougg's Photo Albums
If you put all sensors in the spare and EVER use the spare the sensors ($100 each) will be destroyed. doug
