Tires and Wheels Discussions and experienced advice about tires, wheels, traction control, proper balancing, improving tire life and more.
This is a discussion thread titled "Biggest tires allowed on stock rims", within the Tires and Wheels forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-19-2002, 07:35 AM
Dealer : Northridge Toyota
2006 Toyota Tacoma
DeMello OR's Photo Albums
Last Online: 08-15-2008 12:06 PM
DeMello OR is on a distinguished road.
Default Biggest tires allowed on stock rims
I know you can fit a 305(33) on a stock rim but will the rim fit on the truck without rubbing the a-arm?
Who has the biggest tires on there truck on stock rims?
Old 02-19-2002, 12:03 PM
Inactive Account
Dan8844's Photo Albums
Last Online: 03-03-2005 03:53 PM
Dan8844 is on a distinguished road.
Default Re: Biggest tires allowed on stock rims
Some TS member posted that he had some rubbing with 285/75 tires. The narrowest rim recommended for the 33"/ 12.5" tire is 8.25.
Old 02-20-2002, 01:00 PM
big-o's Avatar
Dealer : Mark Miller Toyota
2005 Toyota Tundra
big-o's Photo Albums
Last Online: 08-11-2008 12:01 AM
big-o is on a distinguished road.
Does'nt anybody read the lift info we have been talking about the past few months. You can fit any size of tire you want on the stock rim! I've just seen a guy here in Salt Lake running a set of 315's. The only thig is, how much do you want to alter the truck to make them fit! He had to notch, and patch the frame, and relocate the upper control arm, and run a Daystar 2" puck. With just a 2" puck, you can run a 255/85/16 (33x9.50). With no lift at all, you can run something like a 265/75/16 on the stock rim. If you change the width of the rim, the bigger tire will fit!
Old 02-20-2002, 11:24 PM
2006 Toyota Tacoma
Thanks.. I had the same thing with my Tacoma I'm sure it would be fine.. Thanks!
Old 03-26-2007, 12:11 AM
Dealer : Carson Toyota Scion
2005 Toyota Tacoma,
lbrito's Photo Albums
Last Online: 10-05-2008 05:38 PM
lbrito is on a distinguished road.
I have the TRD 17" wheels on an 05 A-Cab. I got a set of BFG 285/70/17's and they would not fit without a wheel adapter to seperate it a bit from the A-Arm. The tires fit on the rim though. I put them on now, and there was only very, very minor rubbing on the mudflap. I just cut the piece (part of the inside liner) and the rub was gone. This only happened at full turning though.
Old 03-26-2007, 05:51 AM
jim65wagon's Avatar
Dealer : Palmiero Toyota
2003 Toyota Tundra SR5 4x4
jim65wagon's Photo Albums
Last Online: 10-07-2008 04:19 PM
jim65wagon is on a distinguished road.
Send a message via AIM to jim65wagon
My rims aren't stock and I do have a small lift but...The 255/85 (which is slightly taller than a 285, but slightly narrower than a 265) will fit on stock rims if you modify the pinchweld (bfh) and you may have to cut the front of the fender flair a little.
2003 SR5 V8 4x4 Access Cab; SS Autochrome intake; Truxedo cover; Rhino lining; 255/85/16 Cooper Discoverer S/T's; 16x8 Black Steel Wheelers; Ram Air; breather extensions; Viair 380C on board air; Daystar 1.5" lift; Deaver 3leaf AAL; homemade bed rack; 21 gallon water tank
Old 03-26-2007, 06:00 AM
Cyberbilly's Avatar
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Cyberbilly's Photo Albums
Last Online: Today 11:25 AM
Location: Fredericksburg, VA. America's most historic city.
Cyberbilly will become famous soon enough.
Send a message via Yahoo to Cyberbilly
What he said.
I have 285/70-17s on stock rims and I added a 1.5" wheel adapter to put some breathing room between the sidewall and the A-arm. Without the adapter, the sidewall made contact with the A-arm even at a standstill. This was with a 2.5" lift.
As for tires on a stock rim with a stock suspension, (and as has been repeated many times), you can go with a 265/75-16 or 265/70-17 with no problems. That's it.
All a man really needs for happiness in this world is a good woman, a faithful dog, and a big-a$$ed set of tires on his truck.
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Scion T1808 Head Unit, Audiovox XM Express, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: Two Very Large Dogs
Featured Sites: Truckblog.com Cardomain.com RateMyRide.com Sport Truck.com Truck Trend.com
Old 03-26-2007, 12:24 PM
Dealer : Toyota Scion of Roswell
2004 Toyota Tundra,
2004 Toyota Sequoia Limited 4X4
aspenh1's Photo Albums
Last Online: 08-26-2008 08:49 PM
aspenh1 is on a distinguished road.
Originally Posted by Cyberbilly View Post
What he said.
Cyberbilly,
Do you have any issues with the tires rubbing the frame since you added the 1.5 spacer? I am running 285/70/17 BFG KO and at full turn I hit the frame. Someone else here mentioned the spacers but said it then made their tires rub the wheel well opening. What is your take? I get tired of it hitting the frame and considered downsizing ( but might look terrible with the lift).
Base:: 04 Double Cab, 4x4, Natural White, Oak Leather, Heated Seats, Headrest DVD, 6 Disc Changer, Sirius Sportster 4, VSC
The GOOD STUFF: Unichip, Borla Performance Duals, Camburg Upper Arms, Teamwest Coilovers, 3" Front lift, 1.25 blocks, 285/70/17 Bridgestone Dueler AT Revos, 1.5" wheel adapters, Cornfed Differential drop, Hellwig sway bar, Line-X, Folding tonneau cover,TRD mesh grill, Chrome stainless nerf bars, Chromed Stainless bull bar
2nd 04 Sequoia Limited 4X4,Natural White
Old 03-26-2007, 06:32 PM
Cyberbilly's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
Originally Posted by aspenh1 View Post
Cyberbilly,
I have no rubbing whatsoever.
Old 04-12-2007, 12:40 PM
The Phoenix's Avatar
The Phoenix's Photo Albums
Last Online: Today 01:28 PM
What if I decided to run a 275/60R17 or 285/60R17 tire instead of the 265/65R17 that currently is on my truck?
I know the tire would fit but would I experience rubbing? I don't think I would since I'm lowering the sidewall.
Old 04-13-2007, 07:05 PM
Cyberbilly's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
Rubbing where? There are a lot of places the tire can rub.
If you run 275s or 285s on stock rims, you will still have rubbing on the UCA no matter what sidewall height. Why? Because the tire is too wide. So what you have to do is, move the whole tire outward; away from the UCA.
You can accomplish this two ways: You can buy rims that have a smaller backspacing, or you can use spacers/adapters to push the whole wheel/tire farther away from the hub.
Bottom line: If you are running stock wheels, you shouldn't try any tire wider than 265. If you are just going for the "big tire" look, consider maybe a 265/80.
Old 04-17-2007, 11:03 AM
I'm looking for something wide, not big really. I guess I'd have to opt for spacers then.
Old 04-17-2007, 01:23 PM
Cyberbilly's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
I highly recommend: WheelAdapter.com
