Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 02-26-2002, 04:14 PM
Dealer : Yokem Toyota
Last Online: 01-06-2008 12:12 AM
Silvertundra01 is on a distinguished road.
Send a message via AIM to Silvertundra01 Silvertundra01's Photo Albums
Default Biggest tires that will fit on Tundra?
Hey, I've got a TRD tundra and am getting cornfed spacers put on this weekend. I was wondering if anyone knows what the biggest tires I can fit on a leveled TRD tundra are?
Old 02-26-2002, 09:00 PM
Bishop
Guest
Posts: n/a
Bishop's Photo Albums
Default Re: Biggest tires that will fit on Tundra?
Hi-Ho, Silver...
Without a larger lift, the biggest you can go are 285/75/16's. Anything bigger than that will require more lift, and will negatively affect your acceleration and gas mileage.
Old 02-26-2002, 11:02 PM
Dealer : Frontier Toyota
Last Online: 01-26-2008 02:35 AM
71spitfire is on a distinguished road.
71spitfire's Photo Albums
I just had BFG AT KO's installed 285/75/16. Even with the Performance Products 1" lift progressive springs, they still rub ocassionally. Worse however, the accelaration is comromised dramatically and apparent fuel economy is down substantially. Take into account that my new tires travel 15% farther per revolution then the stock tires, & the MPG suffers only slightly. My advice is DON'T DO IT! I'm stuck for 50-60K miles before I can downsize to something more realistic. Plan to spend $ to improve performance if you do. Maybe a supercharger is in my future.
Paul
Old 02-27-2002, 09:57 AM
Thanks for the info
Old 02-27-2002, 11:56 AM
Jwitz's Avatar
Dealer : Stokes Brown Toyota
Last Online: 11-12-2009 12:00 PM
Jwitz is on a distinguished road.
Send a message via AIM to Jwitz Send a message via Yahoo to Jwitz Jwitz's Photo Albums
Well, when I get even bigger tires, like 33" or 32" I'm going to get new gears and lockers in both ends! (When I have the money! )
2000 Tundra
4x4
6spd
v6
285 Nitto Terra Grapplers
Donahoe Racing Coilovers
Total Chaos UCA's
arb bumper
12000lb warn w/ amsteel line
optima batt, 130amp alternator, KC daylighters
Poly steering bushings
custom long travel swaybar links
HAM: KI4RXK google me! www.gaprs.net
Old 06-28-2005, 01:29 AM
big-o's Avatar
Dealer : Mark Miller Toyota
2002 Toyota Sequoia Limited
Last Online: Today 01:48 PM
Images: 5
big-o is on a distinguished road.
big-o's Photo Albums
285's on a stock wheel will touch the frame from lock-to-lock.
Old 06-28-2005, 07:45 PM
Imdone's Avatar
2004 Toyota 4Runner,
Last Online: 10-31-2009 02:18 PM
Images: 23
Imdone is a splendid one to behold. Imdone is a splendid one to behold.
Imdone's Photo Albums My eBay
Paul
Regear to 4.56 ratio and your problem w/accel and mileage and anything else performace related with that new tire size will disappear in an instant. Gears are roughly $1k installed and you won't have to go back to a smaller tire size.
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, UNICHIP, TIMBREN, HYPERTECH
Old 06-28-2005, 08:49 PM
Dealer : Stadium Toyota Scion
2004 Toyota Tundra
Last Online: 04-22-2009 12:57 AM
FireMedic is on a distinguished road.
FireMedic's Photo Albums
It also depends on which wheel you have. I ran into a lot of difficulty after installing the FabTech Coilover lift and add-a-leafs in the rear. The stock 17" wheel does not have the sufficient backspacing to allow for the 285s. When I attempted it, it hit the upper control arm. I even entertained spacers, but decided against it. So, I am running 265 BFG ATs on my stock 17" wheels. From the research I have done, you need a 16" wheel with at least 4-5/8" backspacing. The sad reality is, the stock 17" wheel is nice and difficult to replace (for looks and more importantly--cost).
My two cents worth...
Chris
FireMedic
________________
04' Tundra Stepside - TRD Exhaust-Coilover lift 265 BFG AT k/Os
79' Jeep CJ-7 Screamin' 304 V8- 3 Speed- Elderbrock Hilift intake & Carb, Headers, true duals
46' Willys CJ2A - SLOOOOW 134 "Go Devil" Engine - Beautiful antique
Old 06-28-2005, 09:29 PM
Last Online: 06-26-2007 04:07 PM
bocadeoso is on a distinguished road.
bocadeoso's Photo Albums
Default tundra tires
275/70/16's bfg at ko biggest tire to fit stock on 05 tundra limited 4x4 trd. still enough room to kick out mud/snow and give a little extra footprint in the sand.
4x4 shops have also told me the 285/75/16's will rub even with lifts. the 275's give you a speed difference of @ 1.5 mph low on the speedometer at 65mph.
Old 04-04-2007, 12:17 AM
Dealer : Power Toyota Cerritos
2004 Toyota Tundra
Last Online: 05-02-2007 09:51 AM
nono is on a distinguished road.
nono's Photo Albums
just put 285/70/17 on 04 tundra with only a 1.5 inch coil over moto metal wheel & Nitto a/t tire
Old 04-07-2007, 10:17 AM
mtcheral's Avatar
Dealer : Price Leblanc Toyota
2005 Toyota Tundra,
2007 Toyota Sequoia
Last Online: 11-10-2009 11:43 PM
mtcheral is on a distinguished road.
mtcheral's Photo Albums
You have a 2006 Tundra with higher HP than the earlier engines- you won't notice the loss of power as much- I have an 05 Dcab and have 285's on it. I have a heavy foot and it really hasn't been a big deal at all- i've got all the power I need at takeoff and I still tow a 27 ft offshore boat.
___________________________________________
2005 4wd TRD Doublecab- Silver Sky Metallic
2.0" SAW coilovers at 3" with rear 1" AAL, 285/75/16 BFG AT's on MT Classic II's, Pioneer Premier HU with XM, Rhinoliner, UWS aluminum truck box, Husky liners
