What tire size? NEED HELP
+ Reply to Thread
Results 1 to 4 of 4
Thread: What tire size? NEED HELP
  1. #1
    Junior Member whinton is on the right track. whinton's Avatar
    Join Date
    Apr 2007
    Location
    Lexington Ky
    Posts
    128
    Liked
    0 times
    Images
    5
    Rep Power
    7
    Default What tire size? NEED HELP
    Ok Im going with 20's what kinda off-road tire should I get and how big can I go. My truck does not have a lift on it and it is a 4X4. Thanks for the help.
    Billy
    2007 DC 5.7 cutouts,K&N Intake, throttlebody spacer, weight loss program for the truck, and soon to come nitrous 150 shot
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member mhollack has done just about everything...and then some. mhollack has done just about everything...and then some. mhollack has done just about everything...and then some. mhollack has done just about everything...and then some. mhollack has done just about everything...and then some. mhollack has done just about everything...and then some. mhollack has done just about everything...and then some. mhollack has done just about everything...and then some. mhollack has done just about everything...and then some. mhollack has done just about everything...and then some. mhollack has done just about everything...and then some. mhollack's Avatar
    Join Date
    Jul 2004
    Location
    Bothell, WA
    Posts
    1,656
    Liked
    11 times
    Images
    32
    Rep Power
    852
    Default Re: What tire size? NEED HELP
    275/55/20 is the tire size that comes on the Tundra 4x4's with stock 20's. Thats equal to 31.9"-32" diameter tire with a 10.2" width, depending on what brand tire you got. I would say you could safely go an inch taller or so without lifting. One of the most poplular tires youll see recommended on this site are the BFG A/T KOs. As an example a 285/55/20 in the BFG has a diameter of 32.5", width of 11.7" going up from there a 285/65/20 is 34.7" dia and width of 11.5" and a 305/55/20 is 33.4" dia, width of 12.4" Hope that helps some.
  4. #3
    Join Date
    Apr 2007
    Location
    Lexington Ky
    Posts
    128
    Liked
    0 times
    Images
    5
    Rep Power
    7
    Thread Starter
    Thanks man that is what I needed I think Im going with the toyo tire.
  5. #4
    Leader of Group Evil DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    10,421
    Liked
    48 times
    Images
    22
    Rep Power
    34450
    Seeing as how you're down in Lexington and said "offroad tires"...Interco makes TrXus M/T and SSR TSLs in 20" rim sizes...35R20 for the TrXus and 33R20 for the SSR, or maybe it was the other way around.
    Those BFG A/Ts will pack up in mud and you'll absolutely hate them. They are a dry condition offroad tire that's great for pavement pounding in any weather including deep snow, but for clay and silt mud, soft earth, damp, mossy stuff, they are horrific...most A/T tires will be that way, the lugs aren't designed to shed mud.
    Try an M/T if you need a pavement pounder that'll work offroad on wet clay, otherwise if you need an all-conditions offroad tire that can be driven on pavement look for radial Interco tires that fit 20" rim sizes.
    Or, get an A/T tire and stay on the pavement when it's wet...
    OBTW if you're getting new rims, get 18s not 20s if you're serious about the offroad part.
    -Sean
    GFX by FreedomEagle50
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
Posting Permissions
  • You may not post replies
  • You may not edit your posts
