Old 03-04-2008, 07:44 PM
Dealer : Bob Howard Toyota
Last Online: 10-08-2009 05:05 PM
Empire12 is on a distinguished road.
Empire12's Photo Albums
Default 295/70/17
I am going to buy new wheels & tires for my 2000 tundra 4x4 with bilsteins on highest setting. I was wondering if 295/70/17 would fit with american racing crater wheels, the backspacing= 4.5 & offset=-12mm. I also have 1.5in wheel adapters if I need to use them
Old 03-05-2008, 03:50 AM
Dealer : Tustin Toyota
Last Online: Yesterday 09:13 PM
Tundra Truck Driver is on a distinguished road.
Tundra Truck Driver's Photo Albums
Default Re: 295/70/17
Search around. I had Toyo M/T 295/70/17s and it rubbed like mad with aftermarket wheels with same backspacing/offset. Those wheel adaptors might help some though.
2006 Toyota Tundra DC SR5
Old 03-05-2008, 07:50 AM
TundraSurfBum's Avatar
Dealer : Wesley Chapel Toyota
Last Online: 03-09-2009 07:27 AM
Images: 5
TundraSurfBum is on a distinguished road.
TundraSurfBum's Photo Albums
they will work if you don't plan on turning
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
285 Nittos on OEM Alloys
Flowmaster Delta 40
LUND Genesis Tri-Fold Tonneau
WADE in-Channel Visors
Lil Boom under the seat compliments of RF
Full LED conversion
Nothing too fancy, just better than stock!
Old 03-05-2008, 09:30 AM
jamesjr4750's Avatar
Dealer : Rodland Toyota Scion
2003 Toyota Tundra
Last Online: Today 09:53 AM
jamesjr4750 is on a distinguished road.
jamesjr4750's Photo Albums
I have a winter set of tires in a 275/70/17 that are 32.2" tall x 11.2" wide and those don't rub mounted on 17x9 Centerlines with the 4.5" backspacing and -12mm offset ( clears caliper with those wheel specs) There is alittle room of about 3/4" or more at full lock. Who knows they may work with those 295's, order up a 1/4" wheel adapter/spacer from Wheelers Offroad, but then you aren't going to have many threads left for the lugs. It would then probably be necessary to get longer ARP studs so you dont end up snapping the stock ones off. If it ends up not clearing like you said, you've got those wheel spacers
I say just get the 295s with the 17x9 with the given wheel specs and go for it. Then tell us if it works or not. Most people aren't clear enough on "Aftermarket wheels" and their specs to help on issues and where it rubs like mad. What kind of tire and especially what brand has a lot to do with if it rubs or not. Mud Terrains for instance have outer lugs on the sidewalls and usually rubs the inner frame as what I experience on my 305/70/16's (33.1x12.3) using 16x8 Wheelers Offroad steelies with the 4" backspacing wheels. And even with my coilovers set at 2.5" of Lift it still rubbed the pinchweld before trimming as well as the plastic inner fender, mud flaps. Have fun fitting those 295's. Its going to take some work
03' Access Cab Toyota Tundra V-8 4.7L, 4x4
305/70/16 BFG Muds on 4" B/S Wheelers' Offroad Steel Rims
Donahoe Racing Coilovers (cranked 2.5")
Total Chaos Upper Control Arms and Rack Bushings.
ORS upper mount shock hoop kit / FOX Racing 2.0" Reservoir 11" travel shocks w/ Deaver G57 10 pack rear springs
ARB Sahara Bumper with Fog Light Kit and KC SlimLites in Front
Old 03-05-2008, 12:39 PM
I would run nitto terra grappler a/t's. Also, how hard is the pinch weld mod? or could i just beat it flat?
Old 03-06-2008, 07:32 AM
2003 Toyota Tundra
I suppose you could beat it flat. But that isn't going to do the trick. You have to take your inner fenders off and mud flaps. They're are many screws and some bolts holding these parts on. Then You got to have or aquire a saw-z-all and cut. Then a grinder for smoothing it down and taking excess off so there are no sharp edges.Then making any further changes by more grinding if you didn't cut enough.
Then some sealing and waterproofing needs to be done or water will find its way into the trucks interior flooring. Don't half @ss it. Do it right. Then put all your inner fenders back in place. Test fit the mud flaps finding out what needs to be trimmed next. I had to trim the mud flaps of mine down. You can use some shears. Then the inner fender liner can be molded with a heat gun to soften the plastic to mold to the newly modified pinchweld. but mine I just pushed it in and bolted it down. Without doing that you're mostly likey going to rub the pinchweld as your 295's on 17's are equivalent to my 305/70/16s in height and width and I had to do eveything I just mentioned to get them to fit on my 03' if I wanted to turn the wheels without rubbing the old plastic bumper and pinchweld/mudflap/inner fender plastic. Put those wheel spacers on first and see what you got going on.
And let us know what happens, Alright? Also..What do you got for a lift.
Old 03-06-2008, 08:32 PM
I just went with moto metal 951's & nitto all terrains 285/75/16! Thanks for the help. Heres some pictures...
Old 03-07-2008, 04:05 AM
2003 Toyota Tundra
That was fast. Did you get skeeered on the 295's and all the cutting involved?
So how do they fit. No rubbing with that setup, right?
Old 03-07-2008, 11:00 AM
I didn't want to start cuttin up my truck unless i really needed to. They fit really nice, no rubbing at all
Old 03-09-2008, 03:09 PM
I12BHIR's Avatar
Dealer : Koons Westminster Toyota
2006 Toyota Tundra dc ltd. 4wd
Last Online: Yesterday 12:07 PM
Images: 7
I12BHIR is on a distinguished road.
I12BHIR's Photo Albums
looks good....
06 tundra DC 4wd ltd. 3" toytec spacer lift, truxedo bed cover, 285-70-17 nitto's, factory 17" wheels, 1.25" spidertrax adapters
