3" toytech lift and backspacing issues
+ Reply to Thread
Results 1 to 3 of 3
Thread: 3" toytech lift and backspacing issues
  1. #1
    Rookie aar3546 is on a distinguished road.
    Join Date
    Aug 2007
    Location
    Mandeville, LA
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Default 3" toytech lift and backspacing issues
    I plan to lift my 2000 access cab tundra with the toytech lift kit 3" in front and 1.5" in the rear. I would like to clear 285/75/16 nitto terra grapplers with very minimal rubbing, if any. I plan to stay with the stock wheels and want to know if i need to get new wheels due to backspacing issues to clear the tires. also, what about cv boots? Thanks in advance for any help that is much needed
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Kevo is on a distinguished road.
    Join Date
    Apr 2006
    Location
    Hamilton, Ga
    Posts
    674
    Liked
    1 times
    Images
    3
    Rep Power
    8
    Default Re: 3" toytech lift and backspacing issues
    You will need a diff drop from wheelersoffroad.com, you will probably need a 1.5" wheel adapter (spacer) to cure any rubbing issues.
    2006 Tundra Double-Cab X-SP 4WD
    2.5" piping w/ Magnaflow (clip in gallery) - OBX Pedals - 20% Tint - DEBADGED!
    Pioneer Z1 w/backup CAM & ipod - Painted Brake Calipers - ATE Slotted Rotors + Pads
    2.5 Daystar w/ AAL - 275/55/20 Toyo A/T
  4. #3
    Junior Member rtmccormick is on a distinguished road. rtmccormick's Avatar
    Join Date
    Feb 2008
    Location
    Michigan City, IN
    Posts
    73
    Liked
    0 times
    Rep Power
    6
    personally i would(and am) going with new wheels. i was just in your position looking to lift and upsize, but it's too much of a pain in the *** to space it out and etcetera. 4 inches of BS is good to clear 285/75-16s which are approximately 33x12. you aren't gonna clear those size tires on the stock wheels, which are(correct me if i'm wrong) right at 4.5" BS. you can get a nice new set of wheels for 400-500 shipped without much problem. i ordered these..
    for 500 to my door.
    you can also pick up these steel wheels..
    Custom Toyota Wheels from Wheeler's Off-Road
    ..for dirt cheap. the only downside is that they're a good bit heavier than comparable alloys(they say they're 37 lbs each versus low 20s for a set of 16x8 alloys).
    hope this helps.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
