KORE
Free Shipping at Buy.com!
FREE Personal Trainer Program
Tires and Wheels Discussions and experienced advice about tires, wheels, traction control, proper balancing, improving tire life and more.
This is a discussion thread titled "Wheel Spacers", within the Tires and Wheels forum, part of the Technical & Vehicle Assistance Forums category.
  #16 (permalink)
Old 05-30-2007, 08:40 AM
Dealer : Claremont Toyota Scion
sanox's Photo Albums
Last Online: 04-26-2008 12:34 AM
sanox is on a distinguished road.
Default Re: Wheel Spacers
Originally Posted by Cyberbilly View Post
If you have 1/2" clearance between the UCA and the tire, you should be OK.
Here is an idea. Put a dab of washable white latex paint on the edge of the UCA closest to the tire sidewall, then take it for a spin while the paint is still wet. When you get back home, look and see if any paint rubbed off on to the tire. If not, you are probably OK without spacers/adapters.
Yes, I have adapters on the rear as well; not for clearance, but to keep the front and rear wheel tracks more-or-less equal.
Thanks alot, I'll give it a try. How did you know I have gallons of white latex paint at home??? LOL.
I get a little rubbing at full lock but I think its the mud flaps. What about mud flaps? Think I should just remove them, front and back?
  #17 (permalink)
Old 05-30-2007, 08:44 AM
Cyberbilly's Avatar
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Cyberbilly's Photo Albums
Last Online: Today 02:39 PM
Location: Fredericksburg, VA. America's most historic city.
Cyberbilly will become famous soon enough.
Send a message via Yahoo to Cyberbilly
You can try the same paint trick with the mud flaps. You could remove them, but I personally would not recommend that because stuff will get thrown up by your tires and bang up your rocker panels.
Most folks get by with just trimming or grinding down parts of the mud flaps.
All a man really needs for happiness in this world is a good woman, a faithful dog, and a big-a$$ed set of tires on his truck.
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Factory Audio, XM Satellite Radio with P.I.E. Adapter, Shark Fin Antenna, Scion Head Unit coming soon (I hope) Other: Viair 450 compressor, 2.5 Gallon air tank, 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: Two Very Large Dogs
Featured Sites: Truckblog.com Cardomain.com RateMyRide.com Sport Truck.com Truck Trend.com Carlisle 2007 (top center)
  #18 (permalink)
Old 05-30-2007, 09:47 AM
If I do decide on wheel adapters, is it essential for them to be both hub centric and wheel centric or is just hub centric good enough? Also, where is the best place to purchase these without costing a small fortune? Do you know if the ones on ebay are any good? Imports?
Thanks again.
  #19 (permalink)
Old 05-30-2007, 10:34 AM
Cyberbilly's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
Thanks again.
Do you want good ones or cheap ones?
I bought mine from WheelAdapter.com and I'm very happy with them.
You can also buy them off ebay and hope for the best.
  #20 (permalink)
Old 05-30-2007, 12:23 PM
Did you get the hub and wheel centric or just hub centric? About a $85.00 difference for a set of 4.
  #21 (permalink)
Old 05-30-2007, 02:15 PM
Cyberbilly's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
Not knowing any better at the time, I got hub-centric only. If I was doing it over, I would get the H&W centric.
  #22 (permalink)
Old 05-30-2007, 06:55 PM
Okay, I did the white paint test this afternoon and uca/wheel space seems to be fine. The rubbing i'm getting is the tires hitting the frame at full turn lock. Will the wheel adapters cure this?
Thanks again
  #23 (permalink)
Old 05-30-2007, 07:31 PM
Cyberbilly's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
Thanks again
I took a look at your setup again from the earlier posts, and I'm going make a cautious guess and say Yes, the adapters should cure your problem.
I have 285/70-17s on stock wheels with the Bilsteins at full lift. With the 1.5" adapters, I have no rubbing at all anywhere. So if you only have 265s, you should be OK with the adapters. Good luck!
Let me add my usual disclaimer and say that I cannot be 100% certain without seeing it for myself. But based on what you have told me, and if I were in a similar situation, I would go ahead and get the adapters.
  #24 (permalink)
Old 05-30-2007, 07:52 PM
I can't thank you enough for all your help with this. I have already spoken to Fred at wheeladapter.com and I'm going to just drive over to his place in the next few days or so. I'll let you know how it all turns out.
  #25 (permalink)
Old 06-02-2007, 05:02 PM
I picked up the wheel adapters yesterday from Wheeladaper.com (Fred is a great guy btw) and installed them last nite. NO more rubbing anywhere, all kinds of clearance now with the uca and a much better overall stance imo. pics in my photo gallery.
Hub and wheel centric adapters are they only way to go if you're going to use them. I'm glad you convinced me to go that way.
Thanks again cyberbilly
  #26 (permalink)
Old 06-02-2007, 05:36 PM
Cyberbilly's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
My pleasure.
  #27 (permalink)
Old 06-05-2007, 08:41 AM
Cyberbilly's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
I just looked at your pics again, with that wider stance, you may want to invest in some Bushwacker Flares, otherwise, your tires are likely to throw up crap onto your fenders and quarter panels.
Don't want to mess up the paint now, do we?
  #28 (permalink)
Old 06-06-2007, 12:16 AM
KNABORES's Avatar
Dealer : Landers Toyota
KNABORES's Photo Albums
Last Online: 07-10-2008 02:24 PM
KNABORES is on a distinguished road.
BTW toyota wheels are lug-centric not hub centric, meaning the tire seats on the lugs to center properly unlike Silverados which are hub-centric and require the wheel to seat on the hub to center.
Spend the money and do it right the first time!!!!
  #29 (permalink)
Old 06-06-2007, 07:43 AM
HMMMM.....My set up is definitely hub centric. I tried the adapters on both wheel and hub first before installing and I can see the benefits of the hub/wheel centric adapters. I have the Tacoma TRD/4runner wheels. Hub and wheel are both 106mm.
  #30 (permalink)
Old 06-12-2007, 11:21 AM
Dealer : Stevens Creek Toyota
2005 Toyota Tundra
Prettym1k3's Photo Albums
Last Online: 09-09-2007 12:11 AM
Prettym1k3 is on a distinguished road.
Yeah... I test fitted some wheels on my truck (that I'll be buying) on Sunday, and they are definitely hub and wheel centric.
I'll be ordering my WheelAdapters 1.5" Wheel adapter to go with my 17" Crager Soft 8's and Grapplers today.
Thanks for all that advice guys. Very helpful.
Now... anyone know where to get some kind of baja/pre-runner style front fender?
