Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 05-20-2008, 02:21 PM
2002toytundra's Avatar
Dealer : Jim Norton Toyota
2002 Toyota Tundra Black SR5 2WD Access
Last Online: 09-22-2009 02:15 PM
2002toytundra is on a distinguished road.
2002toytundra's Photo Albums
Default Tire air loss
Hey guys I have a tire that seems to slowly lose air over a month or two it mught lose 10 to 15 lbs. I have had it off and checked for holes/nails and have checked the valve stem, it is fine the needle is tight. Any ideas? Will shifted belts cause this? I would have thought that the ride or noise level would have gotten worse if that happened though.
Old 05-20-2008, 04:06 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 02:02 PM
Images: 22
Default Re: Tire air loss
Could be who knows what. Will they give you a new tire?
I have one tire that loses 8psi overnight ...
GFX by FreedomEagle50
Manual Hubs
Old 05-21-2008, 12:50 AM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Today 09:46 AM
Images: 12
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
take it to a dunk tank and air it up to max psi on sidewall and submerge it! only have to be 10% smarter than air leak! if ya can't find one just get a big bucket and fill it with sopay water and a wash mit and start slowly and work your way all the way around the tire and rim. you will find it if it's leaking! dunk tanks the absolute best method!!
Old 09-08-2009, 08:17 PM
JTs02Tundra's Avatar
Dealer : Hudson Toyota
2002 Toyota Tundra
Last Online: Today 08:31 AM
JTs02Tundra is on a distinguished road.
JTs02Tundra's Photo Albums
Old Thread, but I just found out that the slow leak in my drivers side rear tire was not due to a nail, screw or whatever, but The OEM Rim was corroded due to road salt getting in between the tire bead and the rim. Well, that's a new one on me! The garage Tech dismounted the tire and cleaned the rim, but he said I should dump the rims.
OK I park on the street in the winter and road salt must have done it. Gash Darn it! Now I have to find new rims. Any suggestions?
JT
2002 SR5, Thunder Grey, Access Cab, 4.7, Off Road pkg, 4WD, Toyota Bedliner, Bed Extender, Limited Slip Diff, ABS
Add Ons: Toyota Tube Steps, Leer 700 Lid, Curt Front Mounted Receiver Hitch, WeatherTech Window Vents, WeatherTech Front Floor Liners, Cabela's Aux Back Up Lights, Hellwig Rear Anti Sway Bar, Skid Row Front Skid Plate, Fumoto Valve, SP Rotors and Hawk Pads, SnowSport SnowPlow
Have on workbench: Total Chaos Steering Gear Bushing kit, Autoxray 6000
