Unichip.com
Old 06-13-2008, 11:57 PM
Erik the Red's Avatar
Dealer : Toyota Scion of Vallejo
Last Online: 06-08-2009 01:25 AM
Images: 1
Erik the Red is on a distinguished road.
Erik the Red's Photo Albums
Question Michelin LTX A/T2 or LTX M/S
[I screwed up and posted this on the suspension forum, so my apologies for double posting this to the tire forum.]
Costco is once again having a sale on Michelins so it's time I finally punt my gawdawful Toyos for something--I hope--better. Quick background: After my OEM BFGs buggered out, I decided to go up a size and bought Toyo LT265/75/16 Open Country A/Ts. I figured that the size and 6C load rating would better suit my truck, though I don't typically go off road or carry heavy loads. But ya know, better to have it and not need it....
Fast forward to 63,000 miles later and endless attempts by Les Schwab, Costco, and Toyota to balance the darned things--chronic shaking and steering wheel twitching, noisy, and overall miserable driving experience. Simply terrible tires that even balancing beads couldn't cure. I could never figure out if I basically had bad tires, if Tundras don't work well with higher load rated tires, or if the step up in size had something to do with my problems.
So now I've decided (actually, Costco's liability averse fitment policy decided for me, but that's another story) to go back down to OEM size and try either the Michelin LTX A/T2 (P265/70/16) or the LTX M/S (P265/70/16). The former seems stronger while the latter sounds like it would give a nicer ride. Both have load index of 111 and the same max load weight, though the A/T2 will go to 44 lbs while the M/S maximum pressure is 35 lbs.
Can anyone give me advice on which Michelin might be better suited for my truck? I guess I'm concerned that the A/T2 won't be very smooth or vibration free.
Thanks,
Erik
'01 Tundra 4WD Limited Access cab
Old 06-16-2008, 09:37 AM
Dealer : Gullo Toyota Scion of Conroe
Last Online: 04-08-2009 03:26 PM
cchang52 is on a distinguished road.
cchang52's Photo Albums
Default Re: Michelin LTX A/T2 or LTX M/S
I just changed my stock Dueller H/T's for Michelin LTX A/T2 in LT275/65/18 LRE. Even though I went from a P-metric tire to a 10ply E rated tire, the ride is still as smooth as before. I can definitely tell the tires are much heavier though (about 10 pounds more rotating mass per wheel), but there is no more road noise than stock, and the truck feels much more stable. I like mine so far. Shop a few different places and get them to compete price wise. It's pretty easy to save a few bucks just by doing that.
Chris
Old 06-16-2008, 10:08 AM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Today 02:14 PM
Images: 12
HOGWILD will become famous soon enough. HOGWILD will become famous soon enough.
HOGWILD's Photo Albums
AT Michelins & any Higway tire will have a difference in ride, but not too much. i dumped a set of Bridgestones on my 06 recently and it is night and day difference in the 2! It is not too bad but there will be differences, i like the aspect of not getting stuck in a 4x4 on wet grass Bridgestones are a HT and they are made to ride smooth! The LTXAT2's are a good AT Tire, never used LTX MS not too much Mud & Snow here in NM, but lotta people run them here! really depends on your application and where you will be doing most of your driving! Have not been on wet grass yet but the AT2 should be better than any MS on wet grass. 2 complete different applications!
Old 06-18-2008, 12:15 PM
Dealer : Toyota of Huntington Beach
2002 Toyota Tundra
Last Online: 03-09-2009 12:31 PM
LilCuteSurferGrl is on a distinguished road.
Send a message via AIM to LilCuteSurferGrl LilCuteSurferGrl's Photo Albums
Erik. I'm a Costco Tire Center Supervisor. I can help you out. What kind of driving do you do a majority of the time? City, Highway? Do you use service roads a lot? I'll be honest, the LTX A/T2 is not a very popular tire. Michelin has really messed up with the make of this tire. However, it IS designed to look give you that "rugged" look but also perform both on and off-road, while still giving you the quiet comfort ride on city streets and highways without the annoying road noise. They tried to compete with the BFG All-Terrain and have it's strong point against it by saying it's quiet, but ANY off-road enthusiast knows that the All-Terrain has stood up to it's name and in all reality, doesn't care about the little road noise that comes along with it because when it comes down to it, it's worth it. The A/T2 is more based on looks.
Getting to be a little more technical, the A/T2 is made of a different rubber compound than the LTX M/S. It is a little softer, more silica based to help lessen the road noise of the bigger tread blocks, giving it that "quiet ride"... which means LESS miles for the life of the tire. The LTX M/S is a little harder rubber, giving you more miles, with a tread pattern that will give you a quiet ride. So like i said, it all depends on the type of driving you and what your preferences are.
If you're worried about balancing problems, either one of these tires should be fine. However, if you WERE to run into any problems and un-even wear, the first would be is the A/T2 because of the tread blocks/pattern. With the LTX M/S, you'll have less of a problem with un-even wear.
My suspicion with your toyos is that they were balanced improperly from day one. They sucky thing with tires is that once you have set a bad wear pattern, there's no fixing it unless it's caught in the early stages. And with LT tires, it's not hard to set a bad wear pattern. Wherever you happen to purchase next set of tires, ask for a DYNAMIC balance. DO NOT ALLOW ANY TIRE SHOP TO STATIC BALANCE YOUR TIRES. You could possibly run into the same problem you did with your toyos. Dynamic means that there is weight on the outside and inside of your wheel, and is used to balance the up and down, as well as side to side movement of the tire. Static is a weight on the inside, used to balance only the up and down movement. If you're picky and you do not like seeing weights on the outside of your wheel, ask for a dynamic balance but ask them to hide the weights on the outside. They should use a hammer weight for the inside lip and sticky weights on the backside of the face of the wheel. Make sure you BALANCE and ROTATE EVERY 5-7,000 miles. Also, it's recommended that you get a FOUR wheel alignment after you get your new tires put on. "Mechanical" (alignment) wear is one of the leading causes of premature and irregular tire wear and will void any manufacturer's warranty and sometimes costco's warranty.
PM me if you have anymore questions about tires or Costco's tire center. I'll be more than happy to help you out. If you wan't to upsize to the LT265/75/16 with Costco, i'll let you know how to get around that .
Tiff
MT II's / Hellwig Anti-Sway Bar / IS Kit without Bumper Cover / Yellow/Blue Bilsteins / 32" BFG All-Terrains / BedRug / Clear Corners / RF 10" Sub, Amp and Cap / Pioneer Premier Head Unit / Other Small Stuff and Mods
'02 Tundra
'04 Sequoia
'06 Tacoma 4x4
'07 Z71 Tahoe 4x4
And a 1450/7S Race Truck
Old 06-18-2008, 05:17 PM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 31
Eddie will become famous soon enough.
Eddie's Photo Albums
LTX M/S would be my vote.
Read this thread Michelin LTX M/S or Bridgestone Dueler Revo's? specifically DJ's posts. I'm sure an engineer from Hunter knows a thing or two about tires...I also posted some info on that thread
Old 06-23-2008, 12:21 PM
Images: 1
Thanks for all the input guys. It was a real toss-up but in the end I had to admit to myself that I just don't go much off road (despite my best intentions). So...I went with the LTX M/S. I poured through the reviews on Tirerack but even there I couldn't draw many solid conclusions of which tire is better, although the M/S reviews reflected many, many more miles driven than the A/T2 by virtue of the A/T2 being relatively new to the market. I was fortunate to find a Costco tire technician in the Rohnert Park store who took the time to explain the technical nuances of the tires, and his opinion was to go with the M/S. In light of my type of driving and type of problems with my Toyos, I think the M/S will be the way to go.
