Re: Sequoia Alignment (for the 101st time)
"Cross camber" is the difference between left and right camber. At 0.01 degrees, that's fine, meaning left and right camber are the same. But what are left and right camber? Either they didn't tell you, or you didn't tell us.
It's a similar story with "cross caster". What are left and right caster?
Setting total toe at 0.14 degrees is very poor work when the desired value is 0.08 degrees. It's easy to get toe dead on spec, and incorrect total toe is a severe tire wear factor.
Somebody's got some 'splainin' to do .
