Old 11-23-2008, 10:52 PM
Dealer : Moose Jaw Toyota
2003 Toyota Tundra White Regular Cab,
1995 Toyota Tercel 1994 base tercel,
2009 Toyota Matrix Pontiac Vibe
Last Online: 10-20-2009 03:43 PM
file014 may have some regrets.
file014's Photo Albums
Default Titan or GM 6 lug rims fit 1Gen Tundra?
Instead of springing for new tires on my 03, I might just buy some craigslist rims and tires take-offs. Do Titan and Silverado/Sierra rims fit 6 lug tundras?
Old 11-25-2008, 06:32 PM
Default Re: Titan or GM 6 lug rims fit 1Gen Tundra?
ne1 ?
Old 11-25-2008, 06:42 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 02:00 AM
Images: 204
Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything.
6 lug, 5.5" hub. If it meets those requirements you should at least drive over for a test fit.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full VLED's Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead Sound Deadener
Cosmetic: Line-X Bedliner & Mirror covers, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve,
Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 11-25-2008, 08:15 PM
Imdone's Avatar
2004 Toyota 4Runner,
Last Online: 10-31-2009 02:18 PM
Images: 23
Imdone is a splendid one to behold. Imdone is a splendid one to behold.
Imdone's Photo Albums My eBay
Titan = NO
GMC/Chevy = Yes, sometimes... I have seen some GM wheels with smaller hubs than the Gen 1 Toyotas. Check the fit at the dudes house before you throw them in the truck and take them home.
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, UNICHIP, TIMBREN, HYPERTECH
Old 11-30-2008, 08:49 PM
Sizematters75's Avatar
Dealer : Toyota Scion of Stuart
2005 Toyota Tundra,
2007 Lexus IS250 -other-,
2006 Toyota RAV4 -wife's family car-
Last Online: 11-06-2009 12:30 AM
Images: 6
Sizematters75 is on a distinguished road.
Sizematters75's Photo Albums
The Titan wheels will fit a 1st Gen Tundra. The lug pattern is the same except you need to make sure the rims have the correct size hub spacing or you will need spacers to offset the rim. This is the problem I am running into right now. I had to send mine off and have the hub spacing resized to fit my Tundra because the rims came off a Titan.
2005 Tundra Dbl Cab Desert Sand
20" Enki Deep Six w/ 305/55R20 Cooper Zeon LTZ A/T
Flowmaster 50 Series Cat Back Dual Exhaust
Airaid Cold Air Intake
Airaid Throttle Body Spacer
Alpine w505 InDash Navigation w/ Blackbird
Kicker Comp VR12 Solobaric in custom over seat box
Kicker 1000.1 ZX Mono Amp
ARE Fiberglass Topper
XenonWorks 8,000k UltraWhite H.I.D.'s.
Hertz Mille' MLK 2 Components Hertz Mille' ML1600's 6.5's
Bilstein 5100's set a 2.0" in front
Wheeler's 1" lift blocks, Rancho RS9000XL in rear
Recon Bed Lights
Old 12-02-2008, 12:21 AM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: 11-06-2009 05:41 PM
Images: 22
Check whether the rim centers using a ring on the hub, or uses tapered lug nuts, or uses lug nuts with a heavy shoulder to locate the rim.
If the rims are 6 lug, 5.5" bolt circle, then they will fit, period. You just need the correct lug nuts.
Late model Toyota axles don't have "hubs" in the usual sense that you may be used to seeing...they are set up more like a FWD car, and the rears are semi-float rather than full float with a large hub and drive ring like a Dana axle.
In other words, if they don't appear to fit, make sure you have the right lug nuts for the rims, knock the centering cones off your truck, and test fit the rims. You should be able to seat them using the proper lug nuts, whether the centering cone is in place or not...you can get a different centering cone later if you want one.
-Sean
GFX by FreedomEagle50
Manual Hubs
Old 12-03-2008, 12:17 AM
Imdone's Avatar
Images: 23
There was apparently some confused Titan owners...
Bolt Pattern - Nissan Titan Forum
Titan wheel bolt pattern - Nissan Titan Forum
These are what I saw innitally, apparently that is not the case though since there are many others that show it is a 6x139.7mm.
Nice, that means I have chrome rockstars that will fit a Titan!!! SWEET!!!
