Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 12-05-2008, 08:06 PM
Dealer : Toyota of Keene
Last Online: 10-30-2009 05:30 PM
navigator is on a distinguished road.
navigator's Photo Albums
Question anybody put spacers on your wheels?
As I said I just wanted to know if anyone has put spacers on their trucks? Would this look good?
Old 12-06-2008, 08:36 PM
Door-Kicker's Avatar
Dealer : Springhill Toyota Scion
Last Online: 11-16-2009 11:31 PM
Images: 36
Door-Kicker is on a distinguished road.
Door-Kicker's Photo Albums
Default Re: anybody put spacers on your wheels?
yep
I have these:
WheelAdapter.com > Wheel Spacers
08 Crew Max SR5 4x4 5.7
REMOVED Pro Comp 6" Stage I REMOVED
3 + 2.5 (rear 1" block + 1.5" AAL)
BFG AT KO 305/65/18
Retrax bed cover
Warn Trans4mer w/ muti- mount
4 PIAA ATP's
Old 12-18-2008, 01:42 AM
Dealer : Toyota of Puyallup
Last Online: 10-11-2009 02:51 AM
Rafael is on a distinguished road.
Rafael's Photo Albums
I just ordered me a set for less than half of above listed price. $160 for the set. free delivery. CJBARGINS on ebay has them. I trust sellers with 99.9% customer satisfaction.
Old 12-18-2008, 01:03 PM
Dealer : Neill Sandler Toyota
Last Online: 01-01-2009 12:46 PM
Dorado77 is on a distinguished road.
Dorado77's Photo Albums
Originally Posted by Door-Kicker View Post
How thick are your spacers? What size are your BFG's.
Did you loose mpg, acceleration, handling or ride quality?
BTW your crewmax looks just right
Old 12-18-2008, 01:42 PM
Dealer : Toyota of Whittier
Last Online: 10-20-2009 10:05 PM
Rex Wayne is on a distinguished road.
Rex Wayne's Photo Albums
I don't understand ... how can a !/4" thick spacer help your truck. ?
Rex
Old 12-18-2008, 06:03 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Rex
How will the spacers help? they may help with your turning radius if you've added a taller tire and can't get them turning at full lock without hitting the frame or Control Arm. Spacers or wheel adapters are mainly for correcting improper backspacing and asthetics.
Wheel spacers won't change your mpg's, acceleration, or ride quality. Changing your tires will though.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 12-18-2008, 11:02 PM
bilztrd's Avatar
Dealer : Carson Toyota Scion
Last Online: Today 02:10 PM
Images: 5
bilztrd is on a distinguished road.
bilztrd's Photo Albums
With these spacers could you use cables(snow) on the front tires?
Old 12-19-2008, 11:53 AM
Dealer : Charles Maund Toyota
Last Online: 11-19-2009 04:29 PM
Schmeckle is on a distinguished road.
Schmeckle's Photo Albums
In my experience spacers are generally a no-no. Can someone comment on the wheel stud length and safety of this?
Also, from what I see here, a 1 - 1.5" spacer is offered with new studs. Any downside to that? Is that what you have Door-kicker?
07' Slate Crewmax Ltd 4x4 TRD
KORE|AFE|Zoomers
Old 12-19-2008, 03:48 PM
Images: 205
thread moved to Tires & Wheels forum.
Old 12-19-2008, 03:57 PM
Images: 205
there are big differences between wheel spacers and wheel adapters, aside from the common misconception and wording mixup.
Spacers are generally less than 1" in width and are used for very minor wheel spacing to compensate for incorrect wheel offset. Spacers are typically a large washer that fits over your studs and is not held in place by anything other than the torque of the lug nuts. These are probably what you've heard are a "no-no". I would never run them on my truck.
Adapters are generally over 1" in width and are used to compensate for major incorrect wheel offset. The adapters are a spacer with new studs and countersunk holes to attach your factory studs. The factory hub studs attach on with conical lug nuts and disappear from the surface. The new studs, built into the wheel adapter, protruding from the adapter are what you now mount your wheel to, thus creating a slightly longer wheel base on your axle. Never get a wheel adapter with anything less than grade 8 studs. SpiderTrax.com and WheelAdapter.com are great sources for wheel adapters.
Does that help explain the difference?
If not, I have pictures of both.
Old 12-23-2008, 11:25 AM
Dealer : Toyota West
Last Online: Today 12:38 PM
gipperkid is on a distinguished road.
gipperkid's Photo Albums
The only problem I see with adapters is when brakes or axles need worked on. Normally red loctite is used to secure the spacers with the lugs, correct? Well doesn't red loctite need heat to help break it loose? Would it be safe to use blue loctite?
Old 12-24-2008, 04:52 PM
Images: 205
I had more of a problem removing them due to the aluminum adapter circle binding to the iron of the hub. The nuts came off without a hitch.
Old 12-26-2008, 03:21 PM
Another good point. That aluminum oxidizes with the steel rotor and makes it a PITA to get off.
Old 01-11-2009, 11:57 AM
Anybody have pictures of their trucks with them on. I would like to see how it looks.
