Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 01-06-2009, 02:58 PM
Dealer : Ira Toyota of Manchester
2008 Toyota Tundra DBL Cab SR5 Off-road
Last Online: 03-21-2009 11:49 PM
abfield is on a distinguished road.
abfield's Photo Albums
Default 20" on 2008 Tundra SR5 (novice question)
I'm buying my first truck and certainly not a gear head so please go easy on me. I'm about to purchase a new 2008 Tundra SR5 4.7L 4x4 with the off-road package. I don't need the off-road package but that's what's left on the lot so that's that. I want to add 20" wheels/tires to it. I want to know if this is generally possible without making modifications to the truck. Will I run into turning issues? I know this may increase the turning radius which is fine but will it cause the tire to hit the frame of the truck?
Any info is helpful. For instance, if you think low profile tires work but not normal 20" off-road tires, etc. I don't plan to do any off-roading. I'm a light truck user. Thanks for your help.
Adam
Old 01-07-2009, 02:36 AM
los211's Avatar
Dealer : Piercey Toyota Scion
2007 Toyota Tundra,
2005 Toyota Sienna The wifes "bus"
Last Online: Today 05:38 AM
Images: 6
los211 is on a distinguished road.
los211's Photo Albums
Default Re: 20" on 2008 Tundra SR5 (novice question)
The only thing you have to make sure of is that the new wheels are hubcentric. I recently added 22" wheels to mine and the center bore is 110.5 mm the toyota hub is 110. Now I have an issue with vibration at highway speeds. Toyotas are very finicky about the hubcentric wheels as I have now learned. I have now a set of wheels that are a problem. The other thing to consider is the offset and back space but most wheel dealers have access to all that and will help you find the wheel that will work. Turning radius should not change much unless you go with bigger tires or an extreme offset. My tires are 305/45/22 with an offset of +35 and the turn radius has increased but still near what the stock tires would did. Remeber the hub is what keeps the wheel centered on these trucks not the lug nuts like most others so the center bore is absolutly critical.
'07 SR5 DC 5.7 silver sky metalic
5% tint rear windows, 2 Flowmaster 40 series w/ dual tips out the back, Carriage Works polished grill overlay w/emblem, 3-piece bumper inserts (not CW), Airaid, Ground Force rear shocks, DJM 3" arms, belltech flip kit, 22" BOSS 329 w/ 305/45/22 General grabber UHP, G2 bakflip.
Old 01-09-2009, 06:09 PM
rudeelanda's Avatar
Dealer : Toyota of Temecula Valley
Last Online: Yesterday 08:01 PM
Images: 9
rudeelanda is on a distinguished road.
rudeelanda's Photo Albums My eBay
I upgraded from the 18"TRD to the 20" optional "Carved" wheels. No problems.
07 Tundra DC SR5 5.7L
20" Carved Wheels
TRD Package
TRD Cold Air Intake
TRD Sway Bar
Old 01-09-2009, 07:42 PM
mhollack's Avatar
Dealer : Rodland Toyota Scion
2008 Toyota Tundra SR5 DC TRD 5.7L 4x4,
- Other - 2004 Acura TSX
Last Online: 11-19-2009 09:59 PM
Images: 28
mhollack will become famous soon enough. mhollack will become famous soon enough.
Send a message via AIM to mhollack Send a message via MSN to mhollack Send a message via Yahoo to mhollack mhollack's Photo Albums
No issues at all. The trd wheels/tires you have are 18x8 with 275/65/18 tires on it. The standard 20" alloys that come on alot of the limiteds are 20x8 with 275/55/20's.
2008 SR5 DC 4WD 5.7L TRD Radiant Red/Black (HM,EC,EJ,OF,RL,V5,R9,CT,LineX)
CBTMA Member
TRD Sway Bar, TRD CAI, TRD Dual Exhaust, Billet Grille, CF Dash Kit, Westin Platinum 4" Oval Nerfs, Low Range Off-Road 3/1 Lift, Rancho RS9000XL's - rear, Wet Okole Seat Covers - Fr&Rr, Toyo Open Country A/T's - 285/75/18 (35's), ProComp 6098s 18x8.5 +19, Hypertech Speedo Calibrator, Lund Genesis Tri-fold Tonneau, OE BackUp Camera, OE Fender Flares, VLeds Interior, Kenwood DNX8120 w/HD Radio and Rear Monitor
Old 01-10-2009, 08:04 PM
Thanks for the replies.
