Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
LinkBack (3) Thread Tools Display Modes
  #16 (permalink)
Old 07-12-2003, 10:31 AM
bkoneski47's Avatar
Last Online: 06-27-2005 09:30 PM
bkoneski47 is on a distinguished road.
bkoneski47's Photo Albums
I got these quotes from www.performancewheel.com for the Tundra, and they use nothing but the best. Check them out.
1" $50 each
1.25" $55 each
1.5" $65 each
1.75" $80 each
2" $85 each
2.5" $95 each
  #17 (permalink)
Old 07-13-2003, 06:05 PM
Island_Tundra's Avatar
Dealer : Windward Toyota
Last Online: 06-21-2009 12:44 AM
Island_Tundra is on a distinguished road.
Island_Tundra's Photo Albums
Whats up Native,
Hows it going dude? About the spacers, I have been running them for around 3 years going on four and they are great. When it came time for alignment I just took it to the former RPM and they did it without problems. I think those guys are closed down now though. AK should not have a problem doing the alignment for you even with the spacers on.
Hows your truck? I'v noticed you raised it back up. You still thinking of going prerunner? Looking sweet though. There are a few here on islnad that are starting to sport some dubs but they are running their trucks stock everything. Gotta get them to either drop or lift their trucks . drop me a line later dude. Adios amigo.
John
  #18 (permalink)
Old 07-13-2003, 06:38 PM
03TundraTRD's Avatar
Last Online: 03-15-2007 08:11 PM
03TundraTRD is on a distinguished road.
03TundraTRD's Photo Albums
Would I need spacers to run a 285/50/20 with a drop.
MODS: SpinTech Pro Street Muffler, Panisonic MP3 player, BellTech 1'' Drop Shackle.
  #19 (permalink)
Old 07-13-2003, 08:12 PM
Whats up Zac,
I'm not to sure if you would need the spacer. I guess it all depends on the wheels ie. backspacing, width, offset. Your best bet is to look for someone who is running the exact same wheel or specs as your wheel and see if they need a spacer or not.
I wish I could go the route that you and Native went but I think I'm just gonna fix the truck, build the sound system up and probably throw on some 16X10 on 33's or 35's. Then again I do have a 4X4 and it would kinda suck to take my truck and drop it hehehe But since theres no decent lift kits around that don't cost as much as a Civic I might as well drop it . I just can't leave my truck alone.
  #20 (permalink)
Old 07-13-2003, 09:54 PM
I think your truck will look good lifted or dropped.But if mine was a 4x4 I would lift it.
  #21 (permalink)
Old 06-26-2008, 12:11 PM
Dealer : Keith Pierson Toyota Scion
Last Online: 06-27-2009 04:08 PM
jimmymacx is on a distinguished road.
jimmymacx's Photo Albums
Cool Re: Wheel Spacers - Are they safe?
DJ,
Sounds to me as if the most functional fix for this rubbing problem would be to go with an aftermarket UCA. Do you concur?
  #22 (permalink)
Old 06-26-2008, 01:59 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 02:10 PM
Images: 22
Default Re: Wheel Spacers - Are they safe?
Could you clarify which rubbing issue?
Rubbing on an upper control arm can be fixed this way. Keep in mind the upper control arms on the market are for lifted vehicles, and because the position of the joint is changed, camber and caster will change through a different arc than the manufacturer intended. I have not noticed any undue wear in roughly 50K miles, nor have I had any problems with handling with the upper arm replacements. I do use the alignment specifications DJ recommends.
Rubbing on the wheel well or frame will not be changed by an upper control arm.
-Sean
GFX by FreedomEagle50
Manual Hubs
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tires-and-wheels/16949-wheel-spacers-are-they-safe/
Posted By For Type Date
L.O.S.T. KJ - Liberty Owners Special Team :: View topic - Spidertrax Wheel Spacer w/ No Lift? This thread Refback 06-27-2007 03:23 AM
Fuzion 245/65-17 Tires... - Page 2 - JeepKJ Country This thread Refback 06-16-2007 06:06 PM
L.O.S.T. KJ - Liberty Owners Special Team :: View topic - Spidertrax Wheel Spacer w/ No Lift? This thread Refback 06-02-2007 01:59 AM
