Tires and Wheels Discussions and experienced advice about tires, wheels, traction control, proper balancing, improving tire life and more.
This is a discussion thread titled "tires on v-6 tundra.....help", within the Tires and Wheels forum, part of the Technical & Vehicle Assistance Forums category.
  #16 (permalink)
Old 03-26-2004, 02:17 PM
PXLpainter's Avatar
Dealer : Carson Toyota Scion
2006 Toyota Camry-Solara V6 SLE Convertible
PXLpainter's Photo Albums
Last Online: 11-30-2008 11:31 PM
PXLpainter is on a distinguished road.
Originally Posted by Mike Donofrio
PXL,
Try this: http://www.4lo.com and click on the object that says "Speedomter Check" in the brown bar across the top. I found that with 33s, my speedo and odo are off by about 1 mph for every 10 (around 9-10%)
Hope this helps.
PS-The grill worked out great! Hope you're feeling better!
Whoa! It says I'm almost 10MPH faster @ 60 on the speedo! I've been "guestimating" around 5mph. And it must be bad when my speedo reads 85 then.
Thanks Mike! And I am feeling great now - surgery went fine. Glad you like the OEM grille okay!
Jeff
  #17 (permalink)
Old 03-26-2004, 03:02 PM
PXLpainter's Avatar
I dunno man - according to that calculator, when an SR5 rolls off the line with 16" steel rims and 245/70/16s on it and the next Limited comes out with the alum rims and 265/75/16s - then there is already almost 5mph difference on the speedo @60mph! Does the factory adjust the speedo for these differences? I know the dealer doesn't give a $hit, so they wouldn't.
That's perplexing indeed.
Jeff
  #18 (permalink)
Old 03-26-2004, 03:04 PM
Mike Donofrio's Avatar
Dealer : Gateway Toyota
Mike Donofrio's Photo Albums
Last Online: 01-14-2008 05:40 PM
Mike Donofrio is on a distinguished road.
Jeff
Ford used to put different colored gears in the kickdown cable to correct for these issues, I think in Toyota's it's part of the ECU...But I am guessing.
  #19 (permalink)
Old 03-26-2004, 03:07 PM
PXLpainter's Avatar
Man - wish I knew of an easy way to correct it - I hate not knowing. I'm going to borrow a buddy's GPS the next trip I take to Las Vegas and find out exactly what's going on! Amazing how accurate those are!
Jeff
  #20 (permalink)
Old 03-26-2004, 04:26 PM
Jeff
There is some sort of a computer module that you can get to correct it, you can do a search and find it. For a $100 or more, I'll try to just do the math for now.
Problem is, with a higher truck you're more likely to lose track of your speed. Just last week my girl was driving my truck and said "Whoo, I hafta slow down--I am doing 80." I said, "No you're not, your'e doing 90."
Yikes!
  #21 (permalink)
Old 08-20-2004, 02:18 PM
PXLpainter's Avatar
Well, I still haven't done the "computer check" - but there are some great calculators online to figure this out. I do notice a slight lack in take-off power with 285/75/16s though.
Jeff
  #22 (permalink)
Old 12-10-2007, 10:38 AM
Dealer : Toyota Scion South
sep1279's Photo Albums
Last Online: 06-28-2008 10:37 AM
sep1279 is on a distinguished road.
Default Re: tires on v-6 tundra.....help
I just put a new set of 265/70/16s on my 2001 Tundra V6. The old tires were a bit dry rotted and had bumps. I put a set of Goodyear Tracker IIs on it and it rides like a Mercedes now.
sep1279
