Tires and WheelsDiscussions and experienced advice about tires, wheels, traction control, proper balancing, improving tire life and more.
This is a discussion thread titled "tires on v-6 tundra.....help", within the Tires and Wheels forum, part of the Technical & Vehicle Assistance Forums category.
I just bought a brand new tundra and the tires and rims are pretty small, 245/70/16, i know that 265/75 mounted on a 16x8 rim will fit under a TRD offroad truck fine, but will they fit under mine? It is a Sr5 also if that makes any difference... Any suggestions would be greatly appreciated.
I am almost 100% sure you can run 265/75/16's on your stock rims with no lift. You should have no rubbing at all with that setup.
The only difference in your SR5 and the TRD is the front springs and shocks, but that still should not matter as far as tire size goes. The 265 is a 31" tire and will fit your stock 16x7 rims fine. It would have a wider footprint on a 8" wide rim but I wouldn't worry about it. The TRD Tundra's come with a 265/70/16 on the same rims as yours. The 265/75/16 is about an inch taller that stock. Go for it and enjoy the new look.
I have an SR-5, installed 17x8 with BFGoodrich KO 265-70-17 tires, it would rubbed specially on the passenger side with a person on. I had to buy NWOR progressive springs for the front and TRD Yellow shocks and the problem was solved.
I've got an 01 V6 with an eagle alloy 16X10 rim and BFG 265/75/r16s. Believe the offset to be +10mm on the rim. I get a slight rub on the back side of the fender, right at the mud flap. Only hear the rub in reverse and at full turn but concerned about suspension travel. Wondering how they will do if I bottom out the suspension. We'll see this weekend since I'll be in Mexico for the Baja Mex 300 just south of Ensenada.
Has anyone put 285s on a v6 access cab? Would that turn my truck into a snail?
Matt
2003 Stratosphere Mica SR5 Access Cab
Shocks: Bilstein 5100 coilovers and 5100s in the rear.
Wheels: Toyo Open Country A/T 275/70/16s on MB Blitz rims
Matt
It will change your odometer/speedometer reading alright, but I've not noticed any performance loss whatsoever! I can still bark the tires with the V6 AT if I'm not careful.
My speedometer (mpg) is off 7% with the 265s. Never checked the speed. Checked it with the mile markers. In 100 miles (by the mile markers) my speedometer reads 93--Buzz
Does anyone know if there's a chart/list of what the actual speedo ratings are with the different size tire diameters? I haven't officially measured mine, just that it's reading somewhere around 5-6 mph slower than actual speed at around 60mph. Like I said, I haven't done any actual testing yet.
I have an '00 Tundra and an '01 Sequioa, both with 265/70R16 tires. I use a GSP mapping receiver on long trips, so I've checked the speedometer and odometer against the GPS hundreds of times.
The Tundra speedometer is dead on up to 85, but its odometer reads about 0.9% low, meaning it reads nine miles low on a 1000 mile trip.
The Sequioa speedometer reads dead on at low speeds, but it reads 1.5 mph high from 55 on up. Its odometer matches the GPS to better than 0.1 mile difference on a 1000 mile trip.
I have 285's Mud tires on my V6 and I can spin those puppies pretty damn good. One thing I havent been able to do tho is chirp it in 2nd. I had been able to do that with the 265's...
__________________ SR5 V6 4X4 5Spd Modifications Include... ACT performance clutch, Bassani Split Side Duals, Fabtech Shocks and front Coilovers, IS Kit, Grillecraft Grille, BBS Wheels, 285/75/16 Firestone Destination M/T's for wheelin, 20" Enkei RT-6's w 295/50/20's for street , Air Box Mod, Pro Comp Boost GaugeTRD Supercharger, URD Fuel kit, URD 2.2 Pulley ALL GONE - Now Audi S4 Avant
Hey Gary - you must have the 5-Speed, eh? I have the 33's on my truck and I get plenty of corner squeal when I'm pushing it - in fact, enough to catch a cops' ears/eyes the other day when I was rushing through a yellow light! Damn, if I didn't feel like a foolish teenager again when he pulled me over! It's been over 15 years since I've gotten stopped for anything - 'bout time I guess! Luckily he just gave me a warning to slow down, even though I fully deserved a ticket IMO.
After you get that SC don't forget to get the heavier clutch, and I'd bet you could do more than "chirp" in 2nd.
Jeff
PXL,
Try this: http://www.4lo.com and click on the object that says "Speedomter Check" in the brown bar across the top. I found that with 33s, my speedo and odo are off by about 1 mph for every 10 (around 9-10%)
Hope this helps.
PS-The grill worked out great! Hope you're feeling better!
