Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 09-25-2009, 06:00 PM
Last Online: 09-26-2009 12:02 AM
jarod is on a distinguished road.
jarod's Photo Albums
Default 07-09 18 inch alloys on 2010?
Hi
I have a 2010 TRD 4x4 double cab tundra with the 4.6. The truck came with 18 inch alloys and i need to know if the 2007-2009 18inchers will fit my truck. I spoke to the local dealer and they said there was a change in 2010 but they think the bolt battern is likely the same. I would like to hear from someone who has (been there done that).... before i drop $500 bucks on a set of four used rims for my dedicated winter tires. I have no issue with the way the older ones look just concerned for clearances on calipers etc.
Thanks Jarod
Old 09-28-2009, 12:22 AM
mhollack's Avatar
Dealer : Rodland Toyota Scion
2008 Toyota Tundra SR5 DC TRD 5.7L 4x4,
- Other - 2004 Acura TSX
Last Online: Yesterday 08:37 PM
Images: 28
mhollack will become famous soon enough. mhollack will become famous soon enough.
Send a message via AIM to mhollack Send a message via MSN to mhollack Send a message via Yahoo to mhollack mhollack's Photo Albums
Default Re: 07-09 18 inch alloys on 2010?
Bolt pattern hasnt changed, they should fit fine. You should also be able to find 4 used TRD alloys for alot cheaper than $500. Look around, you should be able to pick them up for around $300-$350.
2008 SR5 DC 4WD 5.7L TRD Radiant Red/Black (HM,EC,EJ,OF,RL,V5,R9,CT,LineX)
CBTMA Member
TRD Sway Bar, TRD CAI, TRD Dual Exhaust, Billet Grille, CF Dash Kit, Westin Platinum 4" Oval Nerfs, Low Range Off-Road 3/1 Lift, Rancho RS9000XL's - rear, Wet Okole Seat Covers - Fr&Rr, Toyo Open Country A/T's - 285/75/18 (35's), ProComp 6098s 18x8.5 +19, Hypertech Speedo Calibrator, Lund Genesis Tri-fold Tonneau, OE BackUp Camera, OE Fender Flares, VLeds Interior, Kenwood DNX8120 w/HD Radio and Rear Monitor
Old 10-07-2009, 06:35 PM
SE2000's Avatar
Dealer : Northway Motor Car Corp.
- Other -,
2008 Toyota Tundra DC Blue Streak
Last Online: Yesterday 09:46 PM
SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything.
SE2000's Photo Albums
If you get lots of pot holes, the styled steel wheels may be your best bet. they all should fit
