Lug Nut Torque? Tire Rotation
+ Reply to Thread
Results 1 to 9 of 9
Thread: Lug Nut Torque? Tire Rotation
  1. #1
    RWB
    RWB is offline
    Join Date
    Aug 2002
    Location
    EAST COAST
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Question Lug Nut Torque? Tire Rotation
    I hit 5000 miles on my 2003 SR5 Sequoia and considering rotating the tires. The truck has the 16" alloy wheels and I need the lug nut torque specs. I looked in the owner's manual and the only information I could find was to " check that wheel nuts are tight ". I've also heard of owners ending up with vibrations for various reasons after rotating the tires. My truck is driving perfect now, should I leave it alone and forget about extending the tire life or am I missing something? Thanks in advance.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Dude Boy's Avatar
    Join Date
    Feb 2000
    Location
    Northern Oregon
    Age
    69
    Posts
    1,462
    Liked
    6 times
    Rep Power
    1078
    The Tundra owner manual lists the torque. Seems like you should be able to find in there somewhere. If not in the section on changing a tire, maybe in the back of the book, or under the spec section?
    ADDING POWER HAS NEVER BEEN SO FAST!
  4. #3
    Assistant Administrator nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    23 times
    Rep Power
    1673
    81 ft lbs
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  5. #4
    Join Date
    Feb 2000
    Location
    Northern Oregon
    Age
    69
    Posts
    1,462
    Liked
    6 times
    Rep Power
    1078
    Hey Glenn, does your owner's manual say 81 ft. lbs. or 83? Mine says 83 for the 2000 Tundra.
  6. #5
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    23 times
    Rep Power
    1673
    I was going by the Repair manual which says:
    2000 - Torque: 110 Nm (1,150 kgfcm, 81 ftlbf)
    However,
    2001 - Torque: 110 Nm (1,150 kgfcm, 83 ftlbf)
    2002 - Torque: 110 Nm (1,150 kgfcm, 83 ftlbf)
    2003 - Torque: 110 Nm (1,150 kgfcm, 83 ftlbf)
    ~Glenn
    Yes I am a pirate!
  7. #6
    RWB
    RWB is offline
    Join Date
    Aug 2002
    Location
    EAST COAST
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for the quick reply.
  8. #7
    KLS
    KLS is offline
    Supercharged Member KLS's Avatar
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,492
    Liked
    4 times
    Rep Power
    17
    Which of us has had his torque wrench recently calibrated and knows that it's accurate within 2 ft-lbs?
    Ken
    You get what you inspect
    Not what you expect.
    Gibson exhaust system
    Hellwig Rear Antisway Bar
  9. #8
    Junior Member Orange Peel's Avatar
    Join Date
    Apr 2003
    Location
    Nashville
    Posts
    140
    Liked
    0 times
    Rep Power
    13
    Ken
    I even calibrated the equipment I use to calibrate with.
    They do need to be calibrated on a fairly regular basis.I guess that depends on the amount of use/abuse the wrench is getting.
  10. #9
    Junior Member maxtorqe's Avatar
    Join Date
    Feb 2003
    Location
    Woodbridge
    Posts
    52
    Liked
    2 times
    Rep Power
    981
    Default Re: Lug Nut Torque? Tire Rotation
    Where can I take or send my torque wrench to be calibrated? I have a very nice one that I picked up from Tire Rack a few years ago. Thanks.
    Maxtorqe
    2003 Tundra Access Cab SR5 V8 4X4
    No real mods just:
    NGK IX Iridium Spark Plugs
    Michelin LTX/MS2 - 265/70 R17s
    Bilstein HD shocks (non TRD)
    Hellwig Anti-Sway Bar
    10 Years - 160,000 miles and counting...
    2013 Highlander 4WD Limited V6
    (The wife's ride, but I do admit to liking it too.)
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
