Tires and Wheels Discussions and experienced advice about tires, wheels, traction control, proper balancing, improving tire life and more.
This is a discussion thread titled "Bigger Tires for Stock Tundra", within the Tires and Wheels forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-10-2003, 03:52 PM
Inactive Account
csimmons14's Photo Albums
Last Online: 11-09-2003 03:41 PM
csimmons14 is on a distinguished road.
Default Bigger Tires for Stock Tundra
I don't currently own a Tundra, but am planning to trade in my current truck for a new Tundra Double cab next year. When I do purchase my new truck I want to put bigger tires on it. The stock tires are just too small. I will be getting a 4x4 and would like to put 285/70/R17 BFG All Terain tires on it. Will these tires fit on the stock 17" rim, and will this combo fit on the stock Tundra without lifting it? If I have to lift it what would be recommended (would want just enough lift to fit the tires on)? Any idea how much it would cost to be lifted if necessary?
Thanks,
Cory
Old 08-11-2003, 06:49 AM
Inactive Account
Thanks for the info. I am actually wanting to get the factory 17" wheels on the truck. I assume that will make the tires about an inch taller and would definitely need a lift. Would I only have to raise the front end just to level the truck or would I have to raise the rear end as well? As you can tell I have no experience with this.
Thanks for your help,
Cory
Old 08-11-2003, 09:14 AM
Sterlin's Avatar
Dealer : Toyota Center
2003 Toyota Tundra
Sterlin's Photo Albums
Last Online: 08-01-2006 10:42 AM
Sterlin is on a distinguished road.
Send a message via AIM to Sterlin
I'm no pro, but I believe all you would need is a front spacer (1 or 2 inch will do). Many companies make em, Tuff Country, Performance, etc., but a lot of folks here have gone with with the Cornfed spacers.
Go to cornfedspacers.com or tuffcountry.com, and they will have what you will need to "level" the truck and make room for bigger tires.
Old 08-11-2003, 11:51 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
dyogim's Photo Albums
dyogim will become famous soon enough.
It's actually http://www.cornfedsuspension.com/
Cory, you can just lift the front without having to lift the back. Just like the others said, a 1 or 2 inch spacer will allow you to fit those tires without a problem. At stock height, I'm thinking the biggest tire you can fit will be 265-70-17's.
Mike - http://dyogim.blogspot.com
Old 08-13-2003, 11:00 PM
Inactive Account
burby's Photo Albums
Last Online: 11-27-2003 05:07 AM
burby is on a distinguished road.
Cory, you mentioned wanting to get the 17" wheels and that it might make the tires about 1" taller. Actually, going from a 16 to a 17" wheel shouldn't make a difference in tire height. Basically, the sidewall of a 17" tire would be smaller than that of an equal height 16" tire. One reason for this is a stiffer, more sporty ride, especially when cornering as there would be less sidewall flex.
Here's a cool website you can go to that you can put in the different size tire combos to get the "mathematical" tire size. It's basically a metric to standard tire conversion chart. If you put in the 2 sizes that Toyota offers (one 16" size and one 17" size) you'll see that they are very close in height. 265/70/16 vs a 265/65/17.
Well, now that I have re-read your post, maybe you meant that you'll be 1" taller with the 285's? If that's the case, then yes you will and forget everything I just said (but the conversion chart is still pretty cool!)
Looks like I forgot to add the website! Doh! here it is: http://www.4lo.com/calc/gearmetric.htm
Old 08-14-2003, 07:16 PM
Inactive Account
Thanks for the information. Yes, I meant an 1" taller with the 285's.
Hey, has anyone had any luck, or even tried, negotiating bigger tires and lift at the time of purchase with the dealership?
Cory
