Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 09-04-2003, 09:42 AM
Last Online: 04-23-2007 07:15 PM
DCTundraGA is on a distinguished road.
DCTundraGA's Photo Albums
Default Can I rotate my tires myself?
They were balanced recently but do they need to be balanced each time they're rotated?
Old 09-04-2003, 11:02 AM
DJ DJ is offline
Dealer : Fowler Toyota
2001 Toyota Sequoia,
DJ will become famous soon enough. DJ will become famous soon enough.
DJ's Photo Albums
They should be fine without rebalancing.
The only time rotating tires without rebalancing is likely to be a problem is when they have been "finish balanced" on the vehicle. This is sometimes done when the brake calipers or drums are out of balance, or when the wheel rotates about a slightly different center of rotation on the wheel hub than it does on the off-the-car balancer. The Tundra and Sequoia use hub-centric alloy wheels, which mount very nicely, and their brake components seem to be balanced well, so this isn't a problem.
Old 09-04-2003, 12:48 PM
Thanks DJ.
Old 09-04-2003, 12:55 PM
Simias's Avatar
Dealer : Carson Toyota Scion
2001 Toyota Sequoia 2WD SR5,
2004 Toyota 4Runner 4WD V8 Sport
Last Online: 10-25-2009 11:18 AM
Simias is on a distinguished road.
Simias's Photo Albums
i know that you didn't ask, but just an FYI, invest in a torque wrench if you don't already have one. i used to rotate my tires myself every time i got an oil change and i ended up busting a wheel stud off. so yeah, get a torque wrench if you don't already have one. btw, it's good that you're rotating your tires because you'll get a lot of life out of them.
2001 Sequoia 2WD SR5
Mods:
Rollers - 18x9 JAOS Super Ziga wrapped w/ 285/65 BFG A/Ts, Suspension: SAW 2.0 Adj. Coilovers, UCAs, Rear Coilspacers I.C.E. - Clarion H/U w/ built in monitor, DVD Player, Drop Down, Headrest Monitors, Exterior: - Stock OEM Foglights, Wings West Spoiler, Engine: TRD Drop-In Filter
Old 09-04-2003, 01:09 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 02:02 PM
Images: 22
1/2" drive 3-foot torque wrench, 1/2" drive 3-foot breaker bar, cordless drill with 1/2" drive adapter, two floor jacks = rotate the tires faster than the guys at the tire dealer .
-sean
GFX by FreedomEagle50
Manual Hubs
Old 09-04-2003, 01:51 PM
I was just planning on tightening the lugs with the tire tool that came with it. Am I in danger of breaking something off?
Old 09-04-2003, 03:09 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
Just an FYI on the torque wrench
Next week there is the Craftsman Club week(9/7-9/13). You can get a torque wrench a)1/2" drive 20-150 ft lbs b). 3/8" drive 10-75 ft lbs or c) 3/8" drive 25-250 in. lbs, for only $49. Regurlarly, the price is $69.99. So, if you plan to invest, get one next week.
Mike
Mike
http://dyogim.blogspot.com
Old 09-04-2003, 03:27 PM
Genthar's Avatar
Last Online: 11-05-2009 09:51 PM
Genthar is on a distinguished road.
Genthar's Photo Albums
Depends on how enthusiastic you get about re-tightening stuff. It's far better to use a torque wrench and get the lugs set evenly to the correct level. Otherwise, improper tightening can possibly lead to busted lugs, warped rotors, or stuff working itself loose at speed. All things you generally want to avoid!
Genthar
Old 09-04-2003, 03:40 PM
Simias's Avatar
i agree w/ Genthar. i'd get one just to be on the safe side. even using your arms and your body weight can be enough to over (even under) torque your lug nuts. also, never stand on the lug wrench! i've busted a couple like that as well! D'OH!
Mods:
Old 09-04-2003, 10:41 PM
DW DW is offline
Dealer : Gene Messer Toyota
2003 Toyota Tundra
Last Online: 04-10-2008 01:50 PM
DW is on a distinguished road.
DW's Photo Albums
TundraGA:
If you want to just use the tire tool that Toyota furnished, you'll be okay. Unless you really go goofy with over-tightening, you're not going to break off a lugnut. And, say you DO break one---It's not the end of the world. Lug nuts are readily available, cheap and, 'tho I've never changed one on a Toyota, they shouldn't be any different than other vehicles...they're just not that hard to change out.
What you DO want to do, is to tighten them using a pattern...like the book says; and tighten then about the same amount of torque each. This prevents warping the brake discs.
By the way, some knotheads in tire stores and dealerships use an air gun. It's FAR better to just use the vehicle wrench yourself than to let anyone use an air gun. Personally, I use a torque wrench, but the method you are suggesting works just fine, too.
Old 09-04-2003, 11:36 PM
Dealer : Stevens Creek Toyota
Last Online: 08-16-2009 10:56 AM
akauth will become famous soon enough.
akauth's Photo Albums
Once you've torqued the lugs down with a wrench a couple of time you know how tight they need to be. But until then you can definitely break lugs. Seems like some of the lugs are a little more susceptible to breaking. When I got my tires rotated, they even broke a stud loosening one!
I've put WD40 on all of lugs to avoid any locking of nuts on the studs. As long as you have a wrench you should use it, but if you don't you can borrow one a couple of times and you'll know when you hit 80 lbs. Actually, I think spec. is 82 ft-lbs or something but I only do 80 myself. (Aluminum rules).
alan
Old 09-05-2003, 11:50 AM
Buzzard's Avatar
Dealer : Gulf Coast Toyota
2006 Toyota 4Runner
Last Online: 11-25-2008 05:44 PM
Buzzard is on a distinguished road.
Buzzard's Photo Albums
Mike
dyogim --thanks for the info on the torque wrench, am going to start doing my own tires rotation. Discount dropped my truck off the jack, knocked a hole in my front plastic cover. They replaced the pan cover. Had my front end checked and they said it needed to be realined. Didnt press the point, just paid for it myself. Hard to say if the drop did the damage or not. Never had any problems with Discount before but this has hurt our relationship.---Buzzard
Old 09-05-2003, 03:25 PM
DJ DJ is offline
DJ's Photo Albums
Be careful of doing that. If you lube the threads of a bolt and then tighten it to a specified torque, you've put LOTS more tension on the bolt than if the threads were dry.
Old 09-05-2003, 03:32 PM
Images: 22
any idea by how much, and how bad this could be? i've been putting anti-sieze (or whatever's handy) on my lug nuts for a long time !
i do tighten cross-pattern, not around the hub.
Manual Hubs
Old 09-05-2003, 05:54 PM
Possum's Avatar
Dealer : Tejas Toyota
Last Online: 12-28-2007 10:10 AM
Possum is on a distinguished road.
Possum's Photo Albums
I have always used anti-seize on all bolts and tighten with the supplied lug wrench of the vehicle.
I have never had a problem with them coming loose or breaking. And if I did have to get the tire off on the side of the road I was assured I was able to remove it with that same lug wrench.
BTW...I do own my own torque wrench, but do NOT use it on lug nuts.
DAN
Click on my door and see my interior.
2001 Tundra SR5 V8 Desert Sand Mica
TRD Dual Exhaust | Bilsteins Shocks & HD TRD 4x4 Coil Springs | Hellwig Anti-Sway Bar | Westin Nerf Bars | Stainless Bed Rails | Bed Extender | Bed Liner | Form Fix Hood Protector | Custom Painted IS Grille & Mirror Covers | Stainless Tundra License Plate Frames | Custom Made Receiver Hitch | Totally De-Badged | Super Magnetic Oil Drain Plug | Mobil One Synthetic Oils | Custom Window Etching | Tinted Windows | Muth Signal Mirrors | Door Sill Protectors | Interior Rubber Mats | Gentex Temp & Comp Auto-Dim Rearview Mirror | Weatherflector Ventvisors | TS Decal | Complete Brake Upgrade | Truxedo Tonneau Cover| Michelin LTX M/S Tires
