Question 275/60/20 tires with 3/1 level kit?
+ Reply to Thread
Results 1 to 5 of 5
Thread: 275/60/20 tires with 3/1 level kit?
  1. #1
    Join Date
    Jan 2011
    Location
    Tulsa, Ok
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default 275/60/20 tires with 3/1 level kit?
    Hey everyone, love the forum so thank you in advance for your help. I have a 2007 Tundra SR5 4x4 Crew Max. I am wanting to install 275/60/20 tires. Will a 3/1 level kit be too much....I don't want the tires to look small and out of place. I just want my truck to look slightly more aggressive, nothing overkill. Any advice would be appreciated.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member jgalanti's Avatar
    Join Date
    May 2006
    Location
    Sharpsburg, GA
    Posts
    174
    Liked
    14 times
    Rep Power
    36
    Default Re: 275/60/20 tires with 3/1 level kit?
    I just installed a 3/1 kit and went with 305/55's. They fit with no rubbing and no trimming. I would think that is a bit much for just 275's. Just a 2 inch front would probably suit the tires best. What are you more set on going with? The size tires or the size lift?
    If you go to the thread below this one "INSTALLED...." you will see pics of the 3/1 with 305's
    Super White Limited Crew Max 4x4 Redrock Interior. 7-Inch BDS Suspension with Fox Racing Adjustable Coil Overs, ICON Billet UCA's, Custom Atlas Suspension full rear leaf springs, King Racing rear reservoir shocks, 20x9 Fuel "Pump" Wheels, 37x13.50-R20 Toyo Open Country M/T Tires, Nitro 4.88 gears with Auburn Pro limited slip, AMP Research power steps, Corsa Exhaust, TRD Rear Sway Bar, Undercover Bed Cover, Bed Rug, Oracle HID's, Rigid Industries D2 Fog light conversion, Rigid Industries grille with 30-inch SR light bar, Tint.
  4. #3
    Join Date
    Nov 2010
    Location
    Birmingham, al
    Posts
    22
    Liked
    0 times
    Rep Power
    5
    jgalanti's setup does look very nice but I think that 305/55/20 is about a 33.2" tire and the 275/60/20 is about 33". My calcs could be off but I don't think there would look to much of a difference except the width of the tire.
  5. #4
    Rookie SlappnBass's Avatar
    Join Date
    Oct 2010
    Location
    Austin
    Posts
    16
    Liked
    0 times
    Rep Power
    0
    You need min 305/ 55R20. You could also go 33" tire and it will nice and clean.
    I ran 33's BFG AT with a 3/1 kit. Good set up.
    275 size tire is too small.
    11' Crewmax Platinum 4x4 | JL Audio 2x 13TW5 in Stealth Box | 2x JL Audio HD 600x1 | KN Air Intake 77 | WeatherTech Floor Liner | Sprayin Bed Liner|BDS 7" Lift | Mickey Thompson Baja Claw ATZ SLT 35x13.50x20 | 20" MotoMetal 951| ST Carrier Bearing Bracket | Icon AAL | Hypertech Speedo | 2" schackles | Corsa Sport Exhaust
  6. #5
    Join Date
    Jan 2011
    Location
    Tulsa, Ok
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks everyone for responding. I also prefer the looks of the 305's over the 275/60/20. I prefer that little extra width with the 305, I am just not sure I want to spend that much. Also, I have been told by two tire shops here to avoid 10 ply tires at all cost due to the quality of ride (I know that is purely opinion). I think at the moment I am leaning towards a level kit only, not the 3/1, with 275/60/20 tires. Hopefully I won't regret not going bigger.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
