I been looking on Craigslist and came across rockstar 20" universal wheels that the guy said he had on his 6 lug Chevy...would they work? And if they did would I need a lift kit?
No. And no.
2002 Tundra V8 SR5 2WD AC
1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
* * * I highly recommend Auto-Rx for your engine and transmission. * * *
* * * O2 Sensor Replacement DIY * * *
Check the lug dimmensions. Your Toyota is a 6 X 5.5. Fairly certain the Chevy pattern is different.
And please post your question in a single forum. You also posted a duplicate in Gen-1.
toyota is 6x5.5 but technically its 6x139.7 and chevy is technically 6x135. i beleive they might fit but they would not be hub centric. i would pass them by.
BAMF #1 2003 AC TRD 4x4--285/70/17 Nitto Trail Graps--Falken ORC 952 17x8.5 -12mm--Magnapack dual exhaust (14416)--15% tint, 50% windshield tint--2'' level--diff drop--AVS in channels--JVC KW-XR610--Tinted taillights--DRL delete--Mud flap delete
