BFG Rugged Trail 275/65/18 tire pressure
+ Reply to Thread
Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By Possum
  • 1 Post By gaijin
  • 1 Post By gaijin
Thread: BFG Rugged Trail 275/65/18 tire pressure
  1. #1
    Rookie CORocks is on a distinguished road.
    Join Date
    Feb 2013
    Location
    CO
    Posts
    17
    Liked
    1 times
    Rep Power
    0
    Default BFG Rugged Trail 275/65/18 tire pressure
    What psi are you guys running for everyday use on the stock BFG 275/65R18 Rugged Trails? I swapped my base steel wheels with the crappy donut tires for the alloys and BFG's when I bought my '13. My door sticker has the recommended psi for the small tires but not the BFG's.
    Supporter Possum is more than famous, they're infamous. Possum is more than famous, they're infamous. Possum is more than famous, they're infamous. Possum is more than famous, they're infamous. Possum is more than famous, they're infamous. Possum is more than famous, they're infamous. Possum is more than famous, they're infamous. Possum is more than famous, they're infamous. Possum is more than famous, they're infamous. Possum is more than famous, they're infamous. Possum is more than famous, they're infamous. Possum's Avatar
    Join Date
    Feb 2001
    Location
    Houston, TX
    Posts
    3,256
    Liked
    10 times
    Rep Power
    3083
    Default Re: BFG Rugged Trail 275/65/18 tire pressure
    I have a 2010 DC TRD with 43550 miles. I put 43 in the front and 38 rear or real close (i do not think every gauge is the same). I rotate about every other oil change and my tires are wearing about as flat as I would expect them to. By what I see as far as wear goes I should get 60 plus thousand miles out of these tires.
    Dan
    CORocks likes this.
    http://www.tundrasolutions.com/forums/signaturepics/sigpic677_1.gif
    DAN
    2001 Tundra SR5 V8 Desert Sand Mica
    TRD Dual Exhaust | Bilsteins Shocks & HD TRD 4x4 Coil Springs | Hellwig Anti-Sway Bar | Westin Nerf Bars | Stainless Bed Rails | Bed Extender | Bed Liner | Form Fix Hood Protector | Custom Painted IS Grille & Mirror Covers | Stainless Tundra License Plate Frames | Custom Made Receiver Hitch | Totally De-Badged | Super Magnetic Oil Drain Plug | Mobil One Synthetic Oils | Custom Window Etching | Tinted Windows | Muth Signal Mirrors | Door Sill Protectors | Interior Rubber Mats | Gentex Temp & Comp Auto-Dim Rearview Mirror | Weatherflector Ventvisors | Complete Brake Upgrade | Truxedo Tonneau Cover| Michelin LTX M/S Tires
  3. #3
    Lurking Member gaijin is on a distinguished road.
    Join Date
    Oct 2011
    Location
    Utah
    Posts
    33
    Liked
    4 times
    Rep Power
    2
    Quote Originally Posted by CORocks View Post
    If you can give me the standard tire size, recommended tire pressure and GAWR Front/Rear (all from stickers on your door jamb), then I can give you the tire pressure(s) for the BFG P275/65R18 Rugged Trail tires which will yield the same Load Rating as stock.
    CORocks likes this.
  4. #4
    Join Date
    Feb 2013
    Location
    CO
    Posts
    17
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by gaijin View Post
    That would be great!
    Standard tire size: P255/70R18
    Recommended Tire Pressure: 30 psi front; 33 psi rear
    GAWR: 4000lb front; 4150lb rear
  5. #5
    Join Date
    Oct 2011
    Location
    Utah
    Posts
    33
    Liked
    4 times
    Rep Power
    2
    Stock P255/70R18:
    Load Rating Front: 2,280 pounds @ 30psi (114% of GAWR)
    Load Rating Rear: 2,390 pounds @ 33psi (115% of GAWR)
    New P275/65R18:
    Load Rating Front: 2,300 pounds @ 27psi (115% of GAWR)
    Load Rating Rear: 2,420 pounds @ 30psi (117% of GAWR)
    By running 27psi Front / 30psi Rear with your new P275/65R18 tires you will have the same recommended Load Rating at each axle as the factory recommended for your stock tires.
    Hope you find the info helpful.
    CORocks likes this.
  6. #6
    Join Date
    Feb 2013
    Location
    CO
    Posts
    17
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Thanks for doing the calculations
  7. #7
    Join Date
    Oct 2011
    Location
    Utah
    Posts
    33
    Liked
    4 times
    Rep Power
    2
    You're welcome. Glad to help
  8. #8
    Junior Member toy4x4boy is on a distinguished road. toy4x4boy's Avatar
    Join Date
    Feb 2002
    Location
    Richland, MI
    Posts
    286
    Liked
    1 times
    Rep Power
    12
    35 front and rear
    Sent from AutoGuide.com Free App
    2010 Tundra Crewmax SR5 TRD 5.7L 4x4 - Corsa Sport exhaust, K&N cold air intake, OEM tow mirrors, Weathertech floor liners, Truxport tonneau cover, Line-X, 20% front tint to match factory, Prodigy P3 brake controller, Equalizer hitch
    2011 Prius II - full 20% tint, Weathertech floor liners
    2005 Forest River Surveyor 233T Hybrid travel trailer
Posting Permissions
  • You may not post replies
  • You may not edit your posts
